Question about Dryers
I have a two year old Bosch Ecologixx 7 Tumble Dryer (WTW86581FF/01) whose condensation compartment full indicator is being activated increasingly early, to the point where I am needing to empty the compartment 4-5 times every time I dry a load of washing, even though it is virtually empty each time. I have cleaned the condensation filter several times as per the User Instructions . Please can you help
2 Suggested Answers
SOURCE: I have a two year
I had exactly the same problem and got it fixed by the Bosch repair service today.
The culprit is that in certain areas there may be algae in the air that thrive to grow in the main water reservoir and clog up the water pump that fills the condensation compartment.
(note: There are two water tanks in the Ecologixx 7 - one user serviceable condenser tank up top and the non-user serviceable main water reservoir sealed inside the machine)
This is main water reservoir is located sealed under the water pump under the tumble dryer drum.
Dismantling instructions: 1. remove the top of the tumble dryer first (two screws at the back 2. remove the right side panel with another few screws (looking from the front) 3. disengage the multi-tooth elastic band by twisting the spring loaded roller at the bottom).
After this you have access to the water pump and the Styrofoam float that triggers the empty condenser tank warning.
If the pump is entirely clogged you might need to replace it and the float.
Then clean the bottom water reservoir from the algae infested water with a pump+hose and a bottle washing brush and circulate clean water through the machine (re-engage the elastic band before running the engine) with the Warm-program.
To kill the algae you need to run about 250ml of clear raw vinegar through the pump system by running the machine in the Warm program for 10min and then rinse the excess vinegar out by putting about half a condenser tank of warm water into the machine and running the Warm-programme for 30min. (this will release the clean water into the condenser unit for the self-cleaning function and then pump it back up into the condenser water tank and dilute and circulate the raw vinegar out of the machine).
You should also do a vinegar sanitization run before all extended periods of disuse of the machine by pouring 250ml of vinegar into the large round hole under the top condenser tank (this is where the condensed water is poured for the self-cleaning run).
Run the Warm-program without the condenser tank in place until you can verify visually that the pump is circulating the vinegar through the hose in the top left back corner of the condenser tank opening (there is a overflow drain at the back so everything coming up goes promptly back down into the main reservoir (small hole in the back corner bottom).
Then place the condenser water tank half full with hot water (not boiling) and let the Warm-programme run for 30min to dilute and circulate the vinegar-water solution out of the machine back into the condenser reservoir.
Posted on May 30, 2011
I have a 4 year old Bosch Ecologixx 7 self cleaning condenser dryer, WTW86561GB/02. The problem is after 10 minutes the machine just switches off, and the display panel goes dark
sounds like the thermal safety overload is cutting the power due to overheating hence why it just turns back on after a certain time, when the safety overload reaches a certain temperature it will cut the power to the machine or in some cases just the heating elements, once it cools down it resets and power is restored and by using the warm setting it obviously isn't as hot so its not overheating, its highly likely it is all blocked up internally with lint (i know it says self cleaning but they never work for more than a few years before requiring a proper clean and service)
Jan 30, 2017 | Bosch Washing Machines
Bosch WTL5200SN/04 condense Tumble Dryer
you have to open the cover to check it seem the water tube is dissconnected or there is an blockage in the tube.
Jul 07, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Ecologixx 7. Why does it keep switching itself off?
could be the door switch has failed . try leaning on door when starting .
Sep 13, 2015 | Bosch Washing Machines
Bosch WTE84122BY Condenser Tumble Dryer dosen't starts
Did you check the res to see if it was full? Might be clothes inside the door and it aint shut all the way? never even seen a condenser dryer.
I have the model service manual though HERE
Dec 11, 2013 | Bosch Axxis WTA4400 Dryers
My Bosch wtl6304 condenser tumble dryer keeps indicating empty filter light and bleeps rapid. It warns me twice like this then trips the thermostat out. I have cleaned filter, washed the condenser out and...
never really heard of a condenser model dryer before however it does seem like internally its full of lent inside of the dryer housing itself around the heating elements if you have a large air compressor open it all up and spray air into everything in the dryer where you see lent build up this will force any lent out of the dryer and it should hopefully run as the day you first got it ;P found this to be an issue even with an LG TROMM dryer i opened up and wasnt drying very well
May 06, 2017 | Bosch Axxis WTL 6307 Electric Dryer
I have a two year old Bosch Ecologixx 7 Tumble Dryer (WTW84560GB/02) whose condensation compartment full indicator is being activated increasingly early, to the point where I am needing to empty the...
Feb 05, 2011 | Dryers
How do you remove the water pump on an indesit idc75 condenser drier?
This easy to use white Indemnity condenser dryer will make a welcome addition to any kitchen. The 10 minute cool tumble and reverse tumble option will help keep creases in your fabric to a minimum. Energy efficiency ratings & performance: Energy efficiency rating: C. Maximum drying capacity 7kg. Condenser dryer features: 160 minute timer. Including 10 minute cool tumble. 2 dryness levels. Manual control. Reverse tumble option. Reservoir full indicator. Fluff filter. Size H85, W59.5, D58.5cm. Drying programmes Freshen up cycle. Manufacturer's 5 year parts and 1 year labour guarantee. Technical specifications: Energy consumption: 4.48kWh per cycle based on dry cotton cycle. Energy consumption: 336kWh per year based on dry cotton cycle.
please comment on my post or vote for the solution.
Dec 21, 2010 | Indesit Dryers
Bosch tumble dryer
I've sorted mine this morning. First, disconnect from the mains - VERY important! Pull out the metal condenser unit at the bottom, and behind it, there's a small hatch in the bottom to the reservoir. This can get gunked up with water, and is very difficult to clean - HOWEVER - I've found a really easy way of cleaning it. I've got a VAX carpet washer with a hose attachment, and I simply sucked all the water out using that. If you don't own a carpet cleaner maybe borrow one. I did this this morning, and my tumble-dryer's still running happily after an hour! It is possible to clean it out without vacuum, but it takes a LOT longer, and the vacuum of the cleaner pulls out gunk that is hard to access. Another place where gunk collects is behind that hatch right at the back - there's a tube up to the right. I pulled out quite a long chunk of lint. However, that wasn't the solution on it's own, I still had to clean out the reservoir as above.
Jul 03, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Zanussi Tumble Dryer
Sounds like the condense pump is bad. Replace it, or look if there is lint in it. ;)
Dec 30, 2007 | Dryers
Dryers Logo
Top Dryers Experts
