Question about Whirlpool Genuine Oven Stove Range Gas Bake Igniter 74007399
I have dropped something behind the lower part of the stove where you store your pans.......i do not think i have room to pull it out , can the drawer come out somehow ,how to i get the item out ,i cannot close drawer entirely.it is a whirlpool gas stove aboout 3 yrs old
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
By chance were you born at night ??? the drawer pulls then lifts out...
Posted on Dec 28, 2013
Got wrong rings or something my saucepans and pans are destroyed with black soot after cooking ?
If you're using a gas stove, the gas air mixture is wrong. If you're using electric or induction, it's the residue left on the pans when cleaned.
Sep 20, 2015 | Cooktops
Oven doesn't let steam out
Thank you for your inquiry, friend!
From the information you have provided your Frigidaire range is not allowing steam to come out. If your vent is blocked it will not release the hot air or steam. Could you provide me with your model number? You can locate the serial tag (which lists your model number) on the door frame of the lower drawer. With the model number I can provide you further assistance. -Matt
Mar 15, 2015 | Frigidaire Stove/Oven/Range Cooktop -...
AGR5844VDW oven not lighting
Most modern ovens have a glow bar ignitor, not a spark ignitor. It will glow a bright orange and then the oven valve will click open and allow gas through and the burner lights. Many gas ovens have a small shutoff handle located on the silver appliance regulator, which is located either behind the stove or at the bottom behind the oven drawer. Make sure it has not been accidentally closed. It will cut off gas to the oven only.
Apr 16, 2014 | Amana AGR5844VDW 5.0 cu. ft. 30" Self...
I have a Wolf gourmet 30" stove. it's about 10
Interesting, I'm looking for a solution to a similar issue. Our new (7 month old) 30'' Wolf Range has this issue. When both front burners are light, the back burner's electronic starter begins to click, but only when you put a pan on the front left burner. I believe the iron/steel in the pan is causing a magnetic field thats starting the rear burner to go off.. just don't know.. will report back after the repair person comes.
Jan 22, 2011 | Wolf Range 18 in. SPR-100 Gas Cooktop
Starter clicks but doesn't light burner
either the gas valve for that particular burner isnt opening,or if all burners are like this then the dual valve that feeds the broiler and stovetop has a bad stove top side of valve portion its underneath the oven cavity behind the lower pan drawer
Jul 31, 2010 | Jenn-Air 30 in. CCG2423 Gas Cooktop
Im having problems with my electric Gaffers Sattler stove. One of the burners is alwas on high when you turn it on. I cant find a serial number. Thank you for your time.
The switch that controls that burner is defective.
Pull out the lower pan drawer and look for a model number on the range cabinet.
If you can not find a model number,unplug the range,remove the switch and get a part number from the switch.
Jan 06, 2010 | Cooktops
I am looking for replacement drip trays and intructions for instalation
Hardware store or appliance store that has a parts department.
You have a gas stove? Lift the grate, drop it in. Electric stove? Pull the burner up and away from the plug (look down at the burner, there are two pieces that go probably toward the center of the stove). Same as gas, drop the tray and reinsert the prongs into the plug.
I hope this helps you
a
Oct 02, 2009 | Dacor 48 in. Epicure EG486SCH (Gas)...
Whenever I cook cream soups in my stainless steel pots, they burn on the bottom. I watch them very closely and just have the heat on medium, but they always seem to burn. I recently bought a glass pot to...
I'm assuming this is an electric stove, since that's what the picure shows. Most electric stoves turn the heating element on and off to regulate the temperature. On high the element is on almost all the time, on low it's off most of the time. The problem is that when it's on, it's on at full power, and sometimes this is enough to scorch things like milk based creme soups.
You can do two things:
First, try using a double boiler. This will put water in the lower pan and help keep the heat lower than with a regular pan. You could also try to find a pan with a very thick bottom, and try that. It might work better.
Sep 13, 2009 | Frigidaire 31 in. GLEC30S8 Electric...
Need replacement drip pans for ge xl44 gas stove
u can find the parts only in the service center of GE appliance center.but if ur unit is more than 10 years,im sure no parts available.
Jun 30, 2009 | GE Profile JGP636 Gas Cooktop
Ceramic glass stove is cracked
HI
You should be able to replace the top only.
Normally if this is your fault, it is not covered by warranty. Normally this would be if you dropped something onto it. This would leave like a star shap series of cracks.
If its down to manufacture, this should be covered under warranty. This damage normally looks like just one long crack, no impact mark.
Check with the manufacturer
Rob
Feb 18, 2009 | Cooktops
Whirlpool Genuine Oven Stove Range Gas Bake Igniter 74007399 Logo
229 people viewed this question
Top Whirlpool Cooktops Experts
vince
Lakeland Appliance...
Are you a Whirlpool Cooktop Expert? Answer questions, earn points and help others
