Question about Ovens
Whirlpool stove something fell behind the area where you store your pans at bottom of stove,,,,,,i cannot close it all the way now......i do not know if there is room to pull it out or if the back comes off......what do i do? can i remove the bottom container where the pans are stored to get to the item?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 25 Answers
You should be able to just pull the drawer out and reach in and grab what ever was dropped . I have yet to find a stove that you can not either access from the front or by pulling the stove out and get in behind . If you have to pull it out make sure you just pull straight out try not to turn the stove you will find that it will pull out very easy and there should be enough length in power cord to allow this
Posted on Dec 28, 2013
2 Suggested Answers
jayhawke
  • 338 Answers
SOURCE: My bad... I use my
open drawer- use hot dog tongs and fish for rack- or a large kitchen magnet on a string
Posted on May 28, 2011
Testimonial: "Very helpful! This was something I was sure I didn't need a repairman to fix, I just wasn't sure how to go about it. Thanks a million! "
Did not realize that burner was under the bottom of stove. Put in an aluminum drip pan on the bottom and turned ove n on for the first time. The pan is now melted to the bottom of my brand new oven. ...
Can you see that the pan has actually melted, or is it just stuck? Aluminum melts at over a thousand degrees, an oven only gets half that hot.
Try to pry it up with a putty knife.
Worse case scenario would be sanding it out with a rotary power sander after cutting as much out as possible with tin snips.
Nov 27, 2013 | Kenmore Ovens
Whirlpool wall oven door handle fell off how to reattach?
I just unplugged the main switch then cleaned behind the oven and re-plugged it. It fixed my problem. It is very basic but it works.
Aug 23, 2012 | Stoves Ovens
I dont know what model i have
Your modle and serial number should be located on the front of the oven where the door closes. Usually the bottom door where you store pans ect. .
Aug 08, 2010 | GE Ovens
Replaced bad thermostat on Magic Chef model 9112xpb. Ignitor now glows orange but oven still won't start. Does gas valve on bottom of oven need to point up or sideways to start?
Gas shut off valve handles are perpendicular to the gasline when closed and parallel when opened. If you are referring to the appliance regulator behind the stove, the lever should face up or out, as opposed to sideways. This particular lever only shuts gas down to the oven and not the stovetop.
Let us know if you need more assistance.
May 16, 2010 | Magic Chef Ovens
The oven burner will not ignite.
Because the glowbar is glowing does not necessarily make it good.
Turn off the gas to the stove. Remove the oven racks. Remove the bottom oven pan. Remove the flame spreader. This gives you access to the glow bar and gas valve.
Put a clamp on amp meter around one wire of the glowbar. Turn the oven control on to BAKE.
If the glowbar reads 3 amps or less,replace the glowbar ignitor.
If the glowbar reads good,check the burner tube for a white ash buildup. It can be cleaned with a wire brush. Look closely near the glowbar section of the burner.
Check all the wire connections for the gas valve.
If the glowbar is good and the ash deposits are gone and the oven still will not ignite,the next step is to replace the gas safety valve.
Dec 01, 2009 | Amana Ovens
Gas range..surface buners light...oven does not.
Usually the gas valve is behind the stove. pull it out from the wall and look behind it. Code requires the shut off valve to be in the same room as the stove so if there is no shutoff valve it would be a good idea to call your gas supplier and have them take a look at the problem. They will look at it and advise you for free.
Mar 31, 2009 | Ovens
Aluminum foil stuck to new oven bottom - how to remove
(Wear a professional n95 mask and rubber gloves). Use a straight razor and scrape off as much foil as possible. Get a hold of Mercuric or sulfuric acid. BE CAREFUL not to spill anywhere, work close to a stainless steal sink. Poor a little in a small glass container and bring over stove porcelain surface. Pour the acid onto the foil and wait 3-4 minutes, use paper towel to wipe off the acid, and then a soapy wet rag. Repeat process until all foil is dissolved. Then wash surface thoroughly and repeatedly with a soapy dish towel. Once complete run water in the sink for 5 minutes till any possible remaining accid is flushed from the sink. The foil is gone and the porcelain is preserved. Works great! (Don't breathe the fumes and ventelate the area or move the stove outside)
Jan 20, 2009 | Kenmore 47783 Electric Single Oven
Simpson 2001 series upright electric stove oven does not get hot only gets warm
It could be the oven element (behind the cover plate in the back of the oven), or the fan not blowing the heat into the oven.
Aug 19, 2008 | Ovens
Ovens Logo
52 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
