Question about Genius HS G550 Lychas - Headset ear-cup - 31710040101
Distorted bass Now I have purchased this headset cause it was looking good price wise. In the description, it read this has 50 mm Nedoymium drivers delivering deep powerful bass. Which I didn't get. I am not expecting this from a music point of view. When I hear explosions, I wanna just hear explosions with LOUD BASS. I am thinking these might be faulty and would replace them. But, if this problem is more universal, I would like to try a solution for that first. Thanks in advance!
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 127 Answers
Sounds (sorry) more like a PC/Laptop/player problem to me. Headsets like these don't usually just fail in this way.
Posted on Dec 28, 2013
Distorted sound
Never used them, but distorted outputs indicates you are over-driving them, connected them to 'speaker out' rather than 'headphone out', Or you have already blown the drivers. Connect to a different sound source and see how they work then. You likely will not get a loud boom from any headset.
Dec 28, 2013 | Sennheiser Audio Players & Recorders
Trying to find the right fuse for a eden World Tour 800 bass amp
Well, hope this helps you.
Fuse Requirements:
USA @ 120 Volts /60 HZ - 10 Amps, 5 x 20 mm GMC/T/slow blow
Europe @ 240 Volts/50 Hz - 5 Amps, 5 x 20 mm GMC/T/slow blow
Japan @ 100 Volts/60 Hz - 12 Amps, 5 x 20 mm GMC/T/slow blow
Mar 10, 2013 | Hartke HyDrive HX410 4x10 Bass Cabinet...
How do I replace ear buds on electronics 520?
There are no replacement earbuds for Plantronics Voyager 520. You would need to replace the headset if the earbuds are making it uncomfortable enough that the headset is unusable. Link to Headsets Direct Bluetooth Headsets is included below.
Plantronics Bluetooth Headsets
Good luck from Headsets Direct!
Jun 28, 2011 | Plantronics Hama Voyager 520 Bluetooth...
Where can I get my blue tooth repaired. When I am talking to poeple on it they can hardly hear me?
If your product is less than 1 year old, go back to where you purchased it and have them replace it. If it's older than 1 year, making it out of warranty, the following link has a price guide. The listed price is $70 so you will need to consider $70 to replace what you have or invest that $70 towards a new purchase of an item that is most likely more advanced and offers new features.
Plantronics Repair Pricing
Good Luck from Headsets Direct!
Apr 14, 2011 | Plantronics Discovery 925 Bluetooth...
The bass is very distorted and i replaced the battery but still the bass is very distorted and i can not hear the words of any song i listen to. whats wrong with it??
you may have blown a speaker. check the wires behind the speaker to see if there is a short(two or more bare wires that touch)
Mar 10, 2011 | Skull Candy Skullcrushers Headset
Change sepertine belt on engine.
it is not that fun, you need to have 1/4 inch tools, 10mm socket 8mm socket, 12 mm socket,18mm socket. and wrenches to match. you need to support car on jack stands and remove pass tire. Go to your local auto parts store and get a manual first. as the valve timing is very critical in the installation process !!!!!!!!!!! if this timing is not done exactly you will cause severe engine damage to valves and pistons. read manual and read again then assemble it right the first time as there is no room for error. Belt is 30 -50 $$$ depending where you go.
Jan 11, 2011 | 1998 Ford Escort
Disk read error-Verifying DMI Pool data... My
hello, Acer T180 comes with a SATA drive which are very reasonable priced these days. I think your system came with a 160GB hard drive (less than $50), you can probably get a 500GB for $50 bucks now.
here is a link to newegg for sata internal drive many of them free shiping for holiday season.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=internal+hard+drive+sata
you may come across few terms like "bare drive", "OEM", then there are regular ones. "bare drive" doens't come with wires(sata data & power connector), same with OEM- no wires, keep in mind OEM is genrally for resellers but i don't think anyone cares (:-) ).. since you are replacing the drive you have you can get by with any or these types. bare drive & OEM tend to be bit cheaper in price.
hope this helps
good Luck
regards,
Amar Sondhi
Dec 04, 2009 | Acer Aspire™ T180 PC Desktop
Sennheiser MM 50 iPhone Mic & Button does not work
I had just the same problem and if you're lucky, the solution is very simple: due to the open headset-plug of the iPhone I had a lot of dust inside. Just try (carefully!) to get the dirt out of the jack with a pair of tweezers or a strong vacuum cleaner. In my case it solved the problem. Good luck!
Apr 16, 2009 | Sennheiser (MM50) Headset
Jensen JMP 50 sounds like I am in a tunnel or well.
Have you powered up the speakers have you checked the sound drivers?? but remember the sound of the Jensen JMP-50s is a bit hollow and lacking in bass, and the speakers do lack bass and treble controls, which can often be found in other speakers in the same price range.
Aug 18, 2008 | Jensen JMP-50 Computer Speakers
Genius HS G550 Lychas - Headset ear-cup - 31710040101 Logo
Top Genius Radio Communications Experts
TO Lady
Tom Chichester
Are you a Genius Radio Communication Expert? Answer questions, earn points and help others
