Question about Vacmaster 87630 Pro 130 Food Sealer, Back
Error messsage E01
It will not seal
I need the manual for the dirt devil 360 reach pro with attachments
https://www.manualslib.com/manual/1257092/Dirt-Devil-360-Reach-Ddu03-E01.html#manual
Apr 20, 2018 | Dirt Devil Vacuums
I have wasted quit a bit of the bags because the food saver is not sealing completely. It leaves a 1/4 to a 1/2 inch unsealed therefore I can not vacuum seal. What am I doing wrong
Try making a seal with nothing liquid in bag, check seal on bag after. If seal looks good it could just be liquid getting on seal area causing it not to seal. There are tips online on how to help prevent this (example: placing rolled up paper towel sheet). If seal still looks bad than you may have a bad spot on the heat seal wire.
Jan 23, 2016 | Vacuums
Seals but won't draw all the air out. Seals fine
That could be a bad foam seal not completing suction, A piece of debris that got sucked into vacuum line and or in pump, or in some cases a crack in a elbow or pump housing.
Jan 22, 2016 | FoodSaver Vacuum Sealer Kit V3460
Why does the vacuum sealer not seal the bag nor seal?
wow when I ran my food business I seemed the only one that could get this thing to seal right every night , Im gonna say it was because I wasn't in a big hurry , these machines work great but there not fast it takes sometimes 5/10 minutes to get a good seal on them , and you cant overload them either , when it comes to these less is more , makes for a easier time using them
allow the food to stop about two inches from top edge of bag , and wipe any loose food from the sealing surface (inside) as this will affect the seal as well
Jan 19, 2016 | FoodSaver V3420 Smart Seal Vacuum Sealer...
It will seal but not vacumn and seal
is this a vacuum sweeper or a vacuum sealer for food
Feb 07, 2015 | Vacuums
Foodsaver V3840 Won't vacuum air out and wont go to seal. A label states the seals are not removable. Do you know how to fix?
you are not using a "good" bag. Make sure there are no holes and that the bottom and sides of the bag are properly sealed. It will run all day and not pull the air out if the seal is broken anywhere.
Sep 11, 2014 | FoodSaver V3840 Vacuum Packaging System
My Vacmaster Pro 130 does not vacuum. What is wrong?
Karen, I am the social media coordinator for ARY VacMaster. Most times when this problem arises with a new machine, it's because there are packing spacers on the under side of the lid that weren't removed. Pull those off and try again. If that doesn't work, Give our technical support department a call at (800) 821-7849. You can always "like" us on Facebook (www.Facebook.com/aryvacmaster) and ask questions to us directly there too. Hope this helps. You can contact me there for quicker answers. :-)
Jun 04, 2012 | Vacmaster Pro 130 Vacuum Sealer Food...
When I try to set the time on my electric wolfgang puck pressure cooker, I get an "E4" and a beep. What is the problem?
I actually have one I use all the time at home. We LOVE it but this seems to a common issue.
the problem is a Signal Switch Malfunction. It has to do with the power switch and the pressure switch from what I have been able to find out. Mine doesn't have a pressure problem it just goes to E4 once you set the time. I gave the switch a good smack and it has been working for a while. This is the second time and this worked both times now. I am sure the switch will have to be replaced at some time.
I have come across this error when I am cooking rice and then trying to pressure cook something else immediately after. I have found that If I release the pressure valve and manually let the steam release, then my chances of getting the getting the E4 errror are less, but it recommends not to do that. :( Another way I have gotten rid of the code was to open the machine. Let it cool off by washing the lid and pulling the pan inster out of the base and let that cool as well. Then I will unplug the machine and basically start all over. The error will go away after some time either way, it's just unfortunate that it can't go from meal to meal when you have several different dishes you need to make. Don't THROW away your machine with an E4 error, just give it time to reset
Apr 07, 2011 | Vacuums
Hi I have an Ariston Aqualia front loader. It has
You could try mild solution of bleach to the drum, perhaps replace door boot seal..
Nov 04, 2009 | Vacuums
Vacmaster 87630 Pro 130 Food Sealer, Back Logo
15 people viewed this question
Top Vacmaster Vacuums Experts
Are you a Vacmaster Vacuum Expert? Answer questions, earn points and help others
