Question about Philips Audio Players & Recorders
Sa011102s 97 my device when turned on turns off automatically after few seconds.I tried to repair it using the software but it didn't work.Please I need a solution immediately.
  • 124 Answers
SOURCE: TV turns of automatically
could be noumerous things: 1. check power supply, too high or too low voultage may cause TV to shut down. measure it to detarmine if power supply is faulty. 2. check convergence board. If either of these 2 fuses on the convergence panel are open then replace the STK output devices PLUS check for any resistors in that circuit that may have overheated and changed value. Use actual fuse values, putting in a larger fuse, even to try and diagnose problem, will cause more severe damage. 3. Check for bad solder connects on the PC board in the area of the power cord and related components. good luck
Posted on Mar 27, 2006
SOURCE: LCD Tv turns off automatically within few seconds
It is a software problem sony was fixing for free untill 03/01/08
You can unplug your set from the outlet for 30 seconds and it will work fine untill several hours of use acrue again. Found this out on the sony website. hope it helps.
Posted on Mar 11, 2008
  • 1894 Answers
SOURCE: mitsubishi ws-65907
can u please give me ur email ID so that i can send u a DOC file having all step by step instructions?
since it is very long i can post it here
Posted on Jun 22, 2008
  • 37 Answers
SOURCE: automatically turns off after few seconds
I had a similar problem and I believe the problem is with the high voltage circuit and ccfl transformers. If you know electronics you may be able to find the chips that provide the power input to the CCFL transformer (I had two transformers and 4 FET's). You will also need a micro soldering station and excellent soldering skills to replace the flat packs (SMT). Hope this helps.
Posted on Aug 26, 2008
SOURCE: unable to start laptop
I understand the urgency and also the importance of data stored in the laptop.
As the laptop is unable to start in normal mode let us try in safe mode.
Follow the steps below:
1. Turn the laptop off completely.
2. Press the power on button to turn it on and at the same time simultaneously keep tapping ' F8 ' key on key pad until you see a advanced boot options screen.
3. Select 'safe mode' and hit enter.
Thank you.
Posted on Nov 28, 2008
Blue tooth speaker wont turn back on.
Unable to connect to a device?
Before attempting any of the following steps, make sure that you are running the latest software version on your SoundLink Wireless Mobile speaker. Click here to visit the software update center and update your speaker. If you are still having difficulty connecting to a device after updating the software, continue to the troubleshooting steps.
Unable to connect with a previously paired device?
Please try the following to resolve this issue:
Perform a product resetTo perform a SoundLink speaker reset, following these steps:
  1. On the speaker, press and hold Mute for 10 seconds, the LEDs will flash briefly
  2. Press Power to turn the SoundLink speaker back on
Clear the pairing list on both the SoundLink Wireless Mobile speaker and the source
  1. On the SoundLink speaker, press and hold the Bluetooth button for approximately 10 seconds until you hear a tone. The SoundLink speaker clears all Bluetooth devices from its memory and becomes discoverable
  2. Clear the list on your Bluetooth device. For more information, please refer to the manufacturer of the device
  3. Perform a product reset. On the speaker, press and hold Mute for 10 seconds, the LEDs will flash briefly. Press Power to turn the SoundLink speaker back on
  4. Try pairing the device again by following these steps:
    1. With the Bluetooth device and the SoundLink speaker both turned on, press and hold the Bluetooth button on the speaker for three seconds to make the speaker discoverable. The Bluetooth indicator will slowly fade on and off approximately once every second to show the speaker is in discoverable mode
    2. Set your Bluetooth device to "Discoverable." This will allow your device to discover the SoundLink speaker
    3. On your device, locate the Bluetooth device list. Select "Bose SoundLink" from the list
    4. If your device asks for a passkey, enter digits 0000 and press OK. Some devices also ask you to accept the connection. Your Bluetooth device indicates when pairing is complete. The SoundLink speaker indicates pairing is complete when the Bluetooth indicator stops fading on and off and remains on
Be sure the SoundLink speaker is within 30 feet of the Bluetooth deviceThe system is designed to operate at a range of 30 feet. However, performance can be diminished by obstacles such as walls or metal, and may also be affected by other Bluetooth devices. Try moving the SoundLink speaker closer to the Bluetooth device.
Be sure the source's Bluetooth function is OnMany Bluetooth enabled devices have an option where the Bluetooth feature can be turned On or Off. This option may be set to Off to save the battery life of the device. Be sure this option is set to On. If the Bose product is paired to the Bluetooth enabled device, it should automatically reconnect when its Bluetooth function is turned on. If the Bose product doesn't automatically reconnect, manually select the Bose product within the Bluetooth list on the device.
Manually connect the SoundLink speaker in the device listSome devices will pair to a device but not automatically connect. Go to the pairing list of the device and check if this is the case. If it is, try connecting to the SoundLink speaker.
Oct 20, 2013 | Just Wireless Bluetooth Headset Wireless...
Lenovo laptop shut down and will not turn on. Tried removing all power and holding down power button but didn't work. When I press power button the te button lights up for a few seconds then goes out. ...
disconnect the adapter +battery HOLD THE POWER button by 30 seconds aprox, this trick is by eliminate all ESD.
Try again connecting the adpater +battery, if work is o.k
If the problem persist, connect only the adapt and see if the computer work, if does , connect the battery, if work is o.k .if doesnot.
The battery is faulty, RUN the software diagnostic with the adapter and see what going on inside of computer, the power supply inside can be faulty or the battery.
As a last trick, open the battery take out the small battery for CMOS, by 20 seconds. And turn on the computer can be TURN on.
God bless you
Jun 23, 2013 | Computers & Internet
Cannot down updates for 7700 cobra gps
On the bottom of your unit is a reset button hole . With GPS turned on and Rest Button Hole facing you, Using a paper clip, insert in the Reset Button hole. GPS will turn off automatically. Turn GPS Unit back on and try to update. Please vote if my information is helpful or not. Recommend me. Thanks UAW 97
Jun 26, 2011 | GPS
The philips go gear mix 2GB doesnot play, it updates to only 40% as i turn it on, and then it shuts down automatically. Guess some internal file/software is missing, i might have deleted it by mistake
Firstly, I'd suggest that you do a soft reset of your player. You will find the reset button next to the 'power on' button on the side of the player. Please hold the Reset button using a pen tip or other sharp object for 10 seconds. Now turn it on.
If that doesn't work, I'd suggest that you format your player or repair it using Philips Device manager. Contents may be removed by using this function. So make sure to back up your contents.
Format:
On your computer desktop, double-click "My computer". Double-click on the MP3 player's icon. Right-click on the Internal Storage icon and then select "Format".
Repair using Device manager:
Launch Device Manager and click the Tool menu and select "Repair", then follow the instructions to perform the repair process. Make sure all other applications such as Philips Plug-in, Windows Media Player or Windows Explorer that access the device are closed or else Device Manager will not recognize the device.
Hope this works.
Apr 05, 2011 | Philips GOGEAR SA6045 MP3 Player
Help me please
Your TomTom home software is corrupted:
1) Try a 'hard reset': while the power is on, stick a small (tooth/match) stick through the hole under your unit base and opposite to were the USB connector go, for a few seconds, remove the pressure on the stick will cause a complete system reboot if possible.
2) Check the health of your Tomtom One flash drive: connect to the computer, use Windows Explorer -> Properties -> Tools > Error-checking to scan and repair any problem.
3) Restore software: using TomTom Home, restore from a previous backup followed by a device update while connected online.
Hope it helps: let me know how you go and good luck!
Jan 06, 2010 | Tomtom One XL GPS Receiver
Device turns itself on automatically a few seconds
Hello there and welcome to lfete at Fixya, the Support Team
Maybe there is a setting for the stand by mode in the phone, you have to adjust that. Go to the settings in the phone and find the phone settings and adjust these settings.
Hope that helps
IF NOT then try to return here
Have a nice time over there
Please rate my answer
Jan 02, 2010 | Palm Tungsten E2 Handheld
Nokia 5220 turning off and on
if your phone restarts by iteslf this means that there is probplem with your phone memory or there is problem with the phone software(firmware).
1. Please do a reset of the phone using this code *#7780# and *#7370#
2. Please take your phone to Nokia service center to update the phone software.
hope this should resolve your issue.
Mar 26, 2009 | Nokia 5220 XpressMusic Cellular Phone
Child lock shut off
Hold the button with the lock until the light turns off. Consult the manual.
Can you provide a model number?
Feb 18, 2009 | Dishwashers
Unable to use main camera
This is only a minor software problem.Please reinstall your phone's software or update your phone's firmware version.
Sep 01, 2008 | Nokia N82 Handheld
Jan 13, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
29 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
