Question about Vacmaster Pro 130 Vacuum Sealer
Beginning steps of operation the device shows E01 when pushing seal command
I need the manual for the dirt devil 360 reach pro with attachments
https://www.manualslib.com/manual/1257092/Dirt-Devil-360-Reach-Ddu03-E01.html#manual
Apr 20, 2018 | Dirt Devil Vacuums
FoodSaver V3240: Lights flash,,,won't operate...what's wrong?
Pull out the long rubber piece on the top, clean any debris, replace firmly.
Aug 10, 2014 | FoodSaver V3240 Vertical Vacuum Sealer
My Vacmaster Pro 130 does not vacuum. What is wrong?
Karen, I am the social media coordinator for ARY VacMaster. Most times when this problem arises with a new machine, it's because there are packing spacers on the under side of the lid that weren't removed. Pull those off and try again. If that doesn't work, Give our technical support department a call at (800) 821-7849. You can always "like" us on Facebook (www.Facebook.com/aryvacmaster) and ask questions to us directly there too. Hope this helps. You can contact me there for quicker answers. :-)
Jun 04, 2012 | Vacmaster Pro 130 Vacuum Sealer Food...
My dyson dc17 turn on but doesn't turn
I am sorry to hear you are having difficulty with your DC17. If the brush bar is not spinning it may be obstructed.
Please visit http://www.dyson.com/support/help.asp?article=956&product=DC17-ANIMAL for step by step instructions on how to inspect your brush bar and clear any obstructions that may be present.
Once you have carried out these steps you may need to reset your brush bar. To do this please plug your machine in, recline it as if you are preparing to vacuum a carpeted surface, turn your machine on and if the brush bar is not spinning push the silver button next to your power button one time. This should reset the brush and it should begin spinning immediately.
If you are still having difficulty with your machine please contact the Dyson US Helpline at 1-866-693-9766 or the Dyson UK Helpline at 0800 298 0298 so we can provide further assistance.
Best wishes,
Jessica
Mar 07, 2012 | Dyson DC17 Animal Bagless Upright Cyclonic...
How do I restore my devices firmware for my zune 30gb
How to restore your Zune device software:------------
When you restore your Zune device software, the startup partition and the data partition are removed and rebuilt. In addition to removing the Zune device software, this process also erases all audio, videos, podcasts, and pictures that are stored on the Zune device.
Warning To restore the Zune device software, you must have a Windows-based computer that has an Internet connection. That computer must have the Zune software installed. And you must be able to connect the Zune device to a USB port on that computer by using a Zune Sync Cable. Do not perform the following steps if you do not have any one or more of these things immediately available.
After you start to restore the Zune device software, you cannot again use the device until you complete all the steps. You will not receive any confirmation or warning on the Zune device after you start the following procedure.
To restore the Zune device software, follow these steps:
1. Set the Hold Switch to unlocked.
2. Press and hold the Back button at the same time as you press and hold the top of the Zune Pad. When the Zune device begins to power up, release the buttons.
3. Immediately after you release the buttons in step 2, press and hold the following special button combination, depending on your Zune model:• If you have the 4GB Zune, the 8GB Zune, or the 80GB Zune, immediately press and hold the Back button at the same time as you press both the left side of the Zune Pad and the Play/Pause button. Continue to hold these buttons until your Zune device restarts and "Please wait" appears on the screen.
• If you have the 30GB Zune, immediately press and hold the Back button at the same time as you press both the left side of the Zune pad and the center of the Zune pad. Continue to hold these buttons until your Zune device restarts and "Please wait" appears on the screen.
Note "Clearing contents. Please wait" appears, followed by “Connect Zune to your PC."
4. After “Connect Zune to your PC” appears, connect the Zune device to the computer that has the current Zune software installed, and then update the device to the current Zune device software.
----------- Click this link directly for more troubleshooting:-- http://support.microsoft.com/kb/944909 -------- If error problem while restoring then click this link below:-- http://support.microsoft.com/kb/945278 ---------- Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 03, 2010 | Vacuums
How to replace belt for hoover elite vacuum
http://www.hoovervacuumbelts.net/
How to replace
Disconnect cleaner from electrical outlet.
1. Place handle in operating position and turn cleaner over.
2. To remove bottom plate, insert end of flat screwdriver into wide area of right-hand slot and push handle of screwdriver to the rear. Repeat in left-hand slot.
3. Lift extension of bottom plate, rotate plate and remove from
cleaner body.
4. Remove agitator and broken agitator belt. (If belt is not broken but is stretched or cut, proceed with steps 7-10 and pull belt off motor pulley. Then continue with step 5.)
5. Slip agitator through new belt (with lettering toward outside of cleaner) and position belt in belt guide. Push end of belt into
opening in cleaner body. Reposition agitator making sure to
align flat sides of projection on belt end of agitator with flat sides of slot in cleaner body.
6. Place the three tabs on bottom plate into slots in front of cleaner body. Snap bottom plate into place over agitator.
May 29, 2010 | Hoover Elite U5061-900 Bagged Upright...
My dyson dc08 has a loss of suction. A flap valve operates within a few seconds of startup which appears to divert air. I have replaced both the hepa and sponge filters but the problem persists. If there...
You have used your Dyson too long without thorough cleaning - Here's how.
Obtain a torx screwdriver, or a set of torx bits, you will need to select the correct size when you come to remove the screws. They are all the same, so you will need only one.
Take the radix catridge off the machine as if to empty the clear plastic sucking container. (From here on your hands get dirty).
Firmly pull out the inner conical funnel. Here it is removed. (Note I am showing photos of the cleaned device).
Next remove the three torx screws. You can see the recesses these are hiding in in the above picture they are the holes without nozzles. The screws are self tappers screwed into plastic, and are easy to undo.
Remove the lower part of the housing and its rubber sealing ring.
Note the orientation for when you put it back together. The above photo shows the lower bell housing opened away from the top part as if opening a door. It's pretty hard to put them together incorrectly so don't worry too much.
You now need to remove two further screws which are recessed into the sides of the inside of the housing. Their positions are easy to find as they are the only recesses large enough, and match up with two curves on the outside of the housing. They are at the left and right in this picture.
Next you need to remove the handle at the top of the radix housing that you normally use to pick up the device.
Remove the two screws deep in the tubular holes you can see at the right of this picture.
Then slightly lift the end of the handle at the end where you removed the screws.
Next use a screw driver to push the other end of the handle off the housing away from the end where you just removed the screws.
This picture shows the handle pushed out (or ready to be re-attached)
Finally remove the screw revealed by removal of the handle.
You can now lift off the top housing revealing the wormy looking cyclone device This is where most of the **** builds up.. Lift this off and clean everything out thoroughly with water.
Make sure everything is clean and dry!!!!
Re-assemble in reverse order.
Now your Dysin is restored to original sucking power.
May 19, 2010 | Dyson DC08 Cylinder Bagless Canister...
When in the up right position the dyson looses suction then begins to take in air just above th filter at the vented area
It sounds like you need to follow the hose and make sure it's connected to the vacuum properly, and make sure all the fitting connecting the hose to the vacuum are sealed good. It's best to wipe the rubber gaskets between fittings with a damp cloth to ensure a good seal.
Sep 21, 2009 | Dyson Vacuums
Vacmaster Pro 130 Vacuum Sealer Logo
Top Vacmaster Vacuums Experts
Are you a Vacmaster Vacuum Expert? Answer questions, earn points and help others
