Question about Bosch HME9760 Microwave Oven
Box fuse location
Where is fuse located. Is there a diagram available
WHERE IS THE FUSE LOCATED ON A ELECTROLUX E30M065GSS MICROWAVE
According to the wiring diagram for this microwave: http://www.manualsdir.com/manuals/79797/electrolux-e30mo65gssa-e30mo65g-e30m065gss.html?page=8
The fuse is located where the 120v line cord connects to the unit internally. Make sure the unit is unplugged prior to servicing.
Feb 02, 2015 | Electrolux Microwave Ovens
Where is the fuse located
How do you expect us to know where the fuse is located without telling us the brand and model number of the microwave oven? They are NOT all the same!
Oct 16, 2014 | Microwave Ovens
Where is fuse box diagram 1995 dodge van
I believe this information can help you. It was got from Internet:
Most fuse boxes are located under the steering wheel of a vehicle but on some cars it can be in the glove box or under the glovebox but they may have hid it under the seat. On the 1996 Grand Caravan ES there are two fusebox locations.One is under the dash on the drivers side, you will need to remove the sound deadening panely by rotating two black plastic screws counter-clockwise. After removing the panel the fuse box is in plain sight. The other fuse box is under the hood, between the battery and the left fender. You will need to press the release at the rear of the cover and lift the hinged cover forward. This fuse box contains many relays as well as fuses. Be sure to replace the cover and ensure that it snaps down securely to prevent dirt and moisture from entering the fuse block.
Apr 24, 2014 | Microwave Ovens
Picture fuse box diagram
looking for fuse for washer pump will not shut off
Jan 07, 2014 | Microwave Ovens
Where is the fuse in the Tappan Microwave (undercabinet) mounted
Quite often on an over the range model, the line fuse is located behind the grille or behind the controller, or sometimes in between the door switches.
There is a video available showing how to remove a typical over the range control panel assembly in under 5 minutes here.
You _should_ be able to find links to helpful exploded view diagrams and order parts here.
But if the oven is dead, first check the outlet under load (a toaster or heair dryer work best), then you can suspect the fuse, the magnetron thermostat (or TCO), the oven cavity TCO, or the controller.
Let us know if you need further help.
Jun 06, 2013 | Microwave Ovens
Where is the fuse in the mmv4205ba
The fuse on this model is located on a small filter circuit board, which should be located just behind the grille.
But if the fuse is good, you may have a failed oven cavity thermostat or magnetron thermostat.
There should be a "mini-manual" (tech sheet) hidden inside the unit
behind the control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting, testing, and locating components.
Also at our Web site, we have a video available showing how to remove a typical
over the range grille and control panel assembly in under 5 minutes.
You can also find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.Accessing some components (especially the oven cavity thermostat) for testing and possible replacement will require you to remove the oven from the wall and take off the outer cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Maytag owner's manuals and installation instructions here.
Aug 18, 2010 | Maytag MMV4205 Microwave Oven
The unit is not functioning although power supply is fine; I suspect a blown fuse but cannot locate my original parts list (model #721.62622) to identify which fuse to replace. Are fuses available from any...
20A ceramic fuses (the most common) can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
It may be the fuse, which is usually located behind the grille, on the floor of the oven behind the control panel, between the door switches, or on the filter board near where the cord comes into the unit.
If the fuse is good, it may be an open thermostat / thermal cutout (TCO) / thermal fuse on top of the cavity / body of the oven.
To find helpful exploded view diagrams and get part numbers, you can just enter your full model number at the Sears parts site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as 721.62622200. Check the tag on your unit.
But Sears parts can usually be obtained for far less here by entering either the part number.
When you enter your model number here, on the resulting page look to the right for the blue "View manuals" button. Click there.
d:%5cele%5crepair%5cmicrowave%5ckenmore_sears%5cview_manuals_button.jpgd:%5cele%5crepair%5cmicrowave%5ckenmore_sears%5cview_manuals_button.jpgd:%5cele%5crepair%5cmicrowave%5ckenmore_sears%5cview_manuals_button.jpg439cb0b.jpg
That Sears-related site has many free manuals. While the manuals they list there are all free, they will ask you to register.
Many times, the owner's manual will also have the installation instructions inside, too.
If yours is not listed there for free, you would have to order it through the
Sears parts site.
We have the overall schematic diagram for model 721.62622200 here and here. It may be close enough to yours to help.
Jun 26, 2009 | Kenmore 62622 Microwave Oven
Fuse location on wall mounted Whirlpool MH7140XFQ
The fuse is in a holder located behind the control panel assembly.
At our site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you don't find yours, you can download it here.
If the oven is dead, it may also be a bad magnetron thermostat or oven cavity thermostat.
The first one can probably be accessed through the opening behind the control panel, but the oven cavity thermostat cam only be accessed by removing the oven from the wall, then removing the outer cover.
You can also find helpful exploded view diagrams and order parts by entering your full model number here.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Nov 21, 2008 | Whirlpool MH7155XM Microwave Oven
Bosch HME9760 Microwave Oven Logo
46 people viewed this question
Top Bosch Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Bosch Microwave Oven Expert? Answer questions, earn points and help others
