Question about Toyota Sewing Machines
Mechanical trouble shooting
The needle thread won't catch the bobbin thread.
  • Janice
    Janice Dec 28, 2013
    It's just that my husband bought me this sewing machine from the Preloved second hand Website and the girl he bought it from said it hadn't been used. My daughter has the same one and she can't get it to work either. Hmmm! I was really hoping it would be something simple..
  • 1,263 Answers
Hi, it 's mostly timing issue's ,
is it possible for a picture of this machine ?
Regards
www.electronicrepairs.co
Posted on Dec 28, 2013
Testimonial: "Oh thanks Robin. It's the toyota RS2000 2D (black)If its the timing does that mean I'll have to get it repaired."
  • 192 Answers
SOURCE: Bottom thread will not catch
Unplug the machine and remove the needle plate so that the bobbin case if fully exposed. Lift out the bobbin case and the cup that it sets in will be visible. Locate the "hook" on this cup. It is a finger with a sharp point at the upper edge of the cup. The hook is what grabs the thread from the needle while sewing.
  • Thread the needle.
  • Turn the handwheel by hand.
  • Watch the hook as it approaches the needle from right to left.
If the hook passes by the needle AFTER the eye of the needle is above it, you timing has slipped and the machine must be taken in for repair.
If the hook catches the thread from the needle, put everything back together and try threading again.
Posted on Nov 14, 2007
SOURCE: the bobbin thread on sewing machine will not catch
how do you retime
Posted on Aug 13, 2008
  • 33 Answers
SOURCE: I cannot get the needle to catch the bobbin thread
sounds like your keeping the upper thread too tight when you drop your needle down to catch the bobbin or the bobbin thread that you left hang out is too short, let me know if it works amy
Posted on Sep 04, 2008
SOURCE: bobbin thread not catching
Whenever you see loops on the underside of the fabric something is snagging the thread. the biggest culprit is burrs on the hook. the hook is what goes round and around the bobbin. The reason for burrs on the tip of the hook areseveral
ONE ...is by helping the fabric through as the machine is doing the sewing which directs the needle too close to the hook thus scarring the smooth surface of the hook and potentially breaking it off and the needle too. You must allow the machine do it on its own and only guide the material.
TWO...Sometimes if you are sewing s-t-r-e-t-c-h-y double knit material the material calls for a ball point needle. I have gotten good results with the Singer brand YELLOW BAND needle.
Three ... The hook could have gotten out of timing. What this means is that the hook is not meeting the needle on the top edge of the eye of the needle. You yourself can check this out by removing the bobbin (or shuttle, cassette). Install the needle flat side to flat side of the mounting rod and all the way up. By slowly turning the handwheel on the right slowly and watching that the eye of the needle is just below the hook on the upward swing of the needle and that they both meet dead center. This when you need to take it in to a repairman. FrankIy I don't like to advise this because of unscruppulous practices. My boss used to call me a virgin Mary because I wouldn't ripp-off the customers. Anyway at this time you can also check the condition of the hook carefully looking for nicks and scratches on or around the tip of the hook. If there is damage present you can file this down with a very fine emory board or by using a strip of 400 to 600 grit sandpaper as if your were buffing a shoe. If the hook is removeable by unsnapping the snaps on either side its easier to buff. Anything courser may contibute to the problem. If the paper won't remove the damage you may need a whole new hook. If its not removeable you will have to take it in to have it installed.They have to time it properly.
Four...The two disk that you mentioned also has a spring. That sping is there to pull up those loops. If the disks are full of lint from the thread going through. the clups of lint won't allow the discs to apply tension on the thread and thereby having tightened the tension so much that that spring is not working properly.You can clean the discs by raising the foot which opens the discs. With a long narrow pick pull out all that lint without scatching the discs. Check closely that the the thread goes across the top of the machine down through the discs pull up snug so the spring engages,through the take up arm,in the two thead guides, then into the needle front to back or right to left, if it is a side loading bobbin. Now the tension will work properly!
TESTING : Move the TENSION dial to mid point of the dial usually 5. This is your starting point.
With two layers of fabric ( not stretchy) and with a regular needle, set stitch length at about 12 per inch on the dial. Now sew about six inches. Raise the fabric and look at the results. Do minor adjustments necessary on your tension dial up 6...7.. if loose on the bottom 4...3..2 if loose on top.
If you did all the steps above those are the steps a repairman performs and charges $75 except me I used to charge $10 .
Brother machines are good quality it is those hidden gremlins that make a fun hobby frustrating when you don't have someone to turn to without having to shell out cash! Its been a pleasure!
jravenus
Posted on Nov 07, 2008
  • 15 Answers
SOURCE: bobbin thread won't catch with needle thread
check that the needle is in the right way round i.e. with cut out on the needle facing into the machine. if this is fine then check that as the needle comes back up from the lowest point that it goes to, that the point on the bobbin case passes just above the hole in the needle, i.e. in the middle of the cut out.(if not it needs re timing) if threaded a small loop should appear at this point for the bottom bobbin to catch if not slacken the top thread and try again.
Posted on Sep 07, 2009
Needle not catching bobbin thread at all
Did you change the needle? If that doesn't solve the problem then it's probably out of time. Take it in for repair.
Oct 27, 2012 | Brother XL-5500 Mechanical Sewing Machine
Bobbin won't spin to allow needle to catch thread
sometimes when you break a needle it can cause the machine to
jump time, the machine would have to be taken to a sewing machine
shop to be checked by the technican
Aug 17, 2012 | Singer Inspiration 4210 Mechanical Sewing...
Needle won't catch bobbin thread
try changing the needle-flat side goes to the back of the machine
clean under the needle plate & in the bobbin area for loose threads or lint
Apr 07, 2012 | Singer 8280 Mechanical Sewing Machine
I have a brother ls-2125 sewing machine. the upper thread is not catching the bobbin thread properly. help please
  1. Tension
    • Your sewing machine tension controls the rate at which the thread is fed through either the upper section of your machine or through the bobbin case. If your upper or bobbin threads aren't threading properly, sometimes adjusting the tension will correct this problem.
    Timing
    • Your sewing machine works by passing the upper thread through the needle of the sewing machine at precisely the same time the bobbin brings its thread to its uppermost position. If either the needle or the bobbin thread reach these positions too soon or too late, the threads won't interact and create the knots that make the seam. You can throw off your timing by sewing too many layers of fabric or hitting a pin with your needle. See you sewing machine repair facility to correct any timing issues.
    Thread
    • Thread can get snagged or caught in the upper section of your machine or on lint pieces in the lower bobbin section. If your threads aren't catching properly, you may be able to fix it by unthreading and rethreading both your upper thread and bobbin threads.
Oct 15, 2011 | Brother LS-2125 Mechanical Sewing Machine
Needle keeps jamming, won't thread
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 07, 2011 | Janome D'cor Excel Pro 5124 Mechanical...
Having thread breakage probelm and also can't track down the correct bobbin to use on the Elna 2005
have you got the manual for this machine? You can download one from here: http://www.ps2netdrivers.net/manual/elna.2005/
It is a front loading bobbin and removabel bobbin case so I think the bobbin is a plastic "Class 15" - like this http://www.sewingpartsonline.com/bobbins-class-15-plastic-10-pack.aspx
Thread breaking could be caused several factors such as the thread actually being old and brittle, the needle or needle plate having burrs and catching the thread, incorrect threading, bobbin in bobbin case the wrong way, or top tension discs playing up/too tight or thread catching somewhere in the threading path.
I'd suggest that you trouble shoot this and refer to the manual for cleaning instructions. If you can access them clean between the tension discs (turn tension down to zero and "floss" between the by running the selvage edge of a piece of clean cotton scrap through the discs to remove any lint/dye buildup). Wind a fresh bobbin and rethread referring to the manual to ensure the bobbin is turning the right way. New needle and rethread top thread refering to threading diagram. Tension on 5 and test sew again.
If you are still having problems, then the machine may benefit from a service by your local Elna dealer, a good service and clean at least every 2 years is recommended.
May 06, 2011 | Elna 2005 Mechanical Sewing Machine
Bobbin won't spin and catch with thread needle
my guess is that the lower drive train gears are shot. having the gears replaced would run you about $300
Jun 14, 2009 | Sewing Machines
Jul 25, 2008 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
23 people viewed this question
Top Toyota Sewing Machines Experts
Tally Girl
Tally Girl
xxxxxx xxx
Are you a Toyota Sewing Machine Expert? Answer questions, earn points and help others
