Question about Lionel Freightliner Fld 120 Tractor and Trailer 154 Mwb
Suspension air bag installation - Lionel Freightliner Fld 120 Tractor and Trailer 154 Mwb
Air bag pump is running, new airbags . rear bags wont air up.
These Lincoln air suspensions are terrible. I have converted many over to coil springs at a fraction of the cost of replacing/repairing the bags. If the rear bags don't inflate, there is a broken air line to the bags or the bags are leaking
Apr 12, 2015 | 2001 Lincoln Navigator
2003 Range Rover air suspension. Help please!!
If the bag hasnt completely failed (punctured or worn to leaking) they can come "unseated" from the base at the bottom of the "bellow" or bag. Not very common but possible. Alternatives to dealer parts and installation checkout ARNOTT air springs. The bag alone runs about $100. If you can afford it replace both fronts with the ARNOTT new generation one piece airspring. The are easy to install and offer little or no headache. Lastly, if you are a fan of the unsurpassed comfort of your Range Rover air-ride suspension, dont let anyone talk you into the coil spring conversion. Its not the same level of comfort and you will feel a big difference in handling. Good luck!
Apr 16, 2013 | 2003 Land Rover Range Rover
Why won't rear end raise up ?
I have a 2000 Lincoln Town car, had the same problem, it was the rear air suspension/shocks. They are air bags basically that levels your car and it cost about $300.00 for each at the dealer for parts and install but it also has its own motor that inflates and deflates these air bags and I also had to replace that and that cost over $400.00 installed at the dealer.
May 28, 2012 | 2000 Lincoln Town Car
Air bags suspension won't inflat. Checked all fuses & air suspension switch. What can the problem be?
Probably failed seal or air bag leaking air. Check again and try to see if this will do the trick. Sometimes pvc line could fail to deliver air to the bag too!
Feb 06, 2012 | 2000 Ford Expedition
1998 crown vic air suspension compressor does not pump.
Sounds like the problem is in the air bag suspension, not the compressor. The air bags shouldn't be losing air when the car sits. The compressor adjusts the suspension level according to the load. The air bags have a valve similar to a blow up raft that allows air to pass through both ways. If when the car is running the compressor is constantly running and not turning off, the issue is within the air bags and/or the air line.
Sep 05, 2009 | 1995 Ford Crown Victoria
Air suspension not leveling the vehicle as it should
no the air supply line must be leaking to the air bag, go back and complain, these bags last about 75-100,000 miles.
Apr 08, 2009 | 1999 Lincoln Navigator
Service air suspension
Your airbags probably have an air leak or are just starting to crack. Go to you tube and type in Suncore hummer suspension air bag replacement. They have a whole how to install that also show your suspension and how it fails
Jan 12, 2009 | 2003 Hummer H2
92 lincoln towncar air bag light flashing
Air suspension is controlled by the compressor in your engine compartment.  The compressor runs when the suspension is not level.  Either because you have loaded the car with exceptional weight and the system is now adjusting the ride, or you have a leak in the system, or you have a bad sensor.
If you have a leak, the most likely culprit are the air suspension bags, the air suspension solenoids or possibly the lines to them.
Try these sites: http://www.strutmasters.com/catalog.php?cat=2
http://www.suncoreindustries.com/english-lincoln-town-car-89-06-air-suspension.html
I don't work for either of them.  I own a 96 TC and have replaced my air suspension with coil springs form Strutmasters.  Work GREAT and I have no more air suspension problems.  Rides just as good too.  You can't tell the difference.
Oct 18, 2008 | 1996 Lincoln Town Car
Rear suspension
i have a 99 lincoln town car and the rear air ride don't work the back of the car is hitting the ground how do i fix that
Oct 11, 2008 | 1999 Lincoln Town Car
Lionel Freightliner Fld 120 Tractor and Trailer 154 Mwb Logo
24 people viewed this question
Top Lionel Crafts & Hobbies Experts
Jeff Hogancamp
Jeff Hogancamp
J.D. Browning
J.D. Browning
ray gallant
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
