Question about DKNY Watches
How to open back of dkny ny1091 - DKNY Watches
I cannot open rhe back of a 3950 lady watch DKNY
most of this kind of watch can be open by a skilled repair man using a knife, you can try it. but the hard part is not opening it but closing in the cover. it is close by pressing in at the sides of the watch. Better to see a repair man for this.
Dec 13, 2010 | DKNY Modern Edge Lady Watch # NY3901
Steel mesh on strap is ravelling and cannot wear it
Thank you for contacting FIxYa.<br /> You will have to contact DKNY on this or take back to store you got. I dont know how long you have had it. Most watches warranties do NOT cover bands. <br /> Contact at:<br /> http://www.dkny.com/contact/<br />Best regards.
Aug 25, 2010 | Dkny Mesh Bracelets #NY3992 Watch for...
I-have-a-ny3715-watch-with-a-stone-missing.it-was-bought-in-new-york-last-november-i-have-the-reciept.i-have-tried-local-jewelers-but-they-cannot-fix-it.how-do-i-get-it-repaired-
Your best bet is to contact DKNY to see if they can replace it for you. Other then that, I would try a local jeweler. Here is a link for the DKNY service center: http://www.dkny.com/contact/ Good luck!!
Aug 12, 2010 | DKNY 1009 Wrist Watch
Dkny 1350 how to change day
Hello. Contact DKNY customer service and request an instruction manual http://www.dkny.com/contact/index.php
May 25, 2010 | DKNY 1009 Wrist Watch
Hi, I have a few baguettes missing from my DKNY watch...how do I have them replaced? The watch is only 6 months since purchase. The number on back is 110709. Ta
First I would bring the problem to the attention of DKNY so they are aware of the problem, see if the missing stones are covered by any warranties or policies of DKNY. If they are not a reputable jeweler in your area should be able to match them at your expense. I Hope that DKNY sands behind this watch and repairs it to your satisfaction.
Good Luck To You!!
Jul 15, 2009 | Watches
Replace the back of a dkny watch after replacing the battery,
For closing your caseback you need the man with very strong hands first, but it might not work as some casebacks can be closed using special tools only.
Before you visit the watchmaker, try this: first of all open your bracelet by taking out spring lug. This will make more space at the back. Then take watch caseback and check for groove in it. Align that groove with stem (pin going into watch movement) and deepen grooved caseback side as it should be. Then without turning caseback apply great pressure with both hands to the watch(from caseback and dial sides). If hands are strong enough, caseback should snap on into place.
In case if it doesn't work, find a piece of thick leather (wide mens belt will do) and place it on completely flat surface (table top). Place the watch face down on that leather, adjust caseback groove with stem again and try to press caseback down with both hands, only this time using your weight.
If all mentioned above doesn't work- you have to go to see watchmaker.
Good luck.
Arthur
Dec 15, 2008 | DKNY Women's Crystal Bezel Watch
Dkny watch- repair, need extra links
I suggest calling DKNY customer service @ 1-800-231-0884 This is their return or repair department they should be able to help with links for your watch.
Mar 09, 2008 | Watches
Watches Logo
Top DKNY Watches Experts
Ansel Alberto
Ansel Alberto
richie46
Are you a DKNY Watch Expert? Answer questions, earn points and help others
