the apartment i rent has a monogram 42" side-by-side fridge in it with no model or serial number attached. a GE technician came by and guessed that it was from 1992, give or take a year.
can anyone tell me 42" side-by-side model numbers for any of the years from 1990-1997?
Comments:
May 18, 2009
- Thanks for the post, but the model/serial #'s were taken off the machine at some undisclosed time in the past. My landlord bought the fridge second-hand, probably after it had been flooded and declared defunct.
i need to find out the model number so i can order a replacement freezer door gasket.
on the 42" Monograms the Model & serial nomenclature are usually located behind the top panel in the center section to the right of the compressor panel. Hope this helps....Bill
Comments:
May 18, 2009
- Well , if thats the case, another solution for you is to order a universal "cut to size" Door gasket. They go for $35.00- $50.00 depending on the kit you order. You can do a Google search... Universal refrigerator door gasket ... & anyone who sells it will pop up... Good luck
Hi, I have a counter depth model. And I hear clicking noise at the upper back (about 2/3 from the...
(More)
Hi, I have a counter depth model. And I hear clicking noise at the upper back (about 2/3 from the bottom, at the freezer side). I disassemble the ice-maker and the noise is not from there. It seems the noise only appears when the freezer reaches its temperature. Thanks.
(More)
Hi, I have a counter depth model. And I hear clicking noise at the upper back (about 2/3 from the bottom, at the freezer side). I disassemble the ice-maker and the noise is not from there. It seems the noise only appears when the freezer reaches its temperature. From the manual I had, it seems coming from the defrost fan. The clicking noise is always there, sometime louder. I need to find out when it is louder, though. Thanks.
ge monogram refrigerator side by side model zisw36dtb otherwise unit works fine removed drain trough...
(More)
ge monogram refrigerator side by side model zisw36dtb otherwise unit works fine removed drain trough and foam housing ----foil on drain trough heater appeared blistered but has continuity----no water in drain tube when disconnected
