Question about PfaFF Sewing Machines
Thread catching on bobbin and bobbin can't turn around so can't sew a stitch also many threads from bottom
  • 1,263 Answers
Hi , that sounds like the timing is out ...
Regards
www.electronicrepairs.co
Posted on Dec 28, 2013
  • 192 Answers
SOURCE: Bottom thread will not catch
Unplug the machine and remove the needle plate so that the bobbin case if fully exposed. Lift out the bobbin case and the cup that it sets in will be visible. Locate the "hook" on this cup. It is a finger with a sharp point at the upper edge of the cup. The hook is what grabs the thread from the needle while sewing.
  • Thread the needle.
  • Turn the handwheel by hand.
  • Watch the hook as it approaches the needle from right to left.
If the hook passes by the needle AFTER the eye of the needle is above it, you timing has slipped and the machine must be taken in for repair.
If the hook catches the thread from the needle, put everything back together and try threading again.
Posted on Nov 14, 2007
SOURCE: singer sewing machine model 6012 c
hi
i want to know how i put thread in the sewing machine
thank you
Posted on Aug 23, 2008
SOURCE: Upper thread wraps around bobbin mechanism, while sewing
IT PROBABLY IS THREADED INCORRECTLY. GO SLOWLY BY THE DIAPHRAGM AND MAKE SURE IT IS THREADED CORRECTLY. ALSO MAKE SURE SPOOL PIN HOLDERS ARE IN PLACE THAT HELPS TO GUIDE THE THREAD CORRECTLY.
Posted on Sep 22, 2008
  • 6 Answers
SOURCE: Singer CG 550 Top thread keeps wraping around the bobbin and jam
Have you checked the top thread is correctly placed in the spring of the bobbin case?
Posted on Feb 21, 2009
louislevel_2
  • 374 Answers
SOURCE: need sewing machince help????
hi;
breaking thread and thread below not hook up by upper thrread, this is due on not properly set up of thread tension,first check bobbins windin35caecd.jpgg see figure.the threads should
be counter clockwise.
the theading on upper set up should prorerly inserted follow figures.7dabcae.jpg
the dial set up tension should start at #3 to # 5
the stitch tension should be set to # 8 to # 12
use trial run for fabrics,diffferent set up in every fabric tru to study before sewing in other fabrics.have a nice day don't forget to rate me.thank s a lot
Posted on May 17, 2009
Why needle is not catching the bobbin thread
All problems like this are caused by incorrect threading of the cotton thread. Even if you have done it before, thread the cotton using the instructions in the manual.
Also make sure the bottom bobbin and its housing are correctly inserted.
Aug 15, 2015 | Singer 3321 Talent Sewing Machine
Bottom stitch skips stitches
MY FIRST THOUGHT IS THE TIMING IS OFF A LITTLE. BEFORE SPENDING YOUR HARD EARNED MONEY FOR A REPAIRMAN TRY THESE POSSIBLE CURES:
1. TRY TO SEW WITH THE NEEDLE ALL THE WAY TO THE LEFT AND THEN TRY IT ON THE RIGHT. IF ONE OF THE TWO SEWS BETTER THAN THE OTHER YOU CAN BE ASSURED IT IS THE TIMING WHICH MEANS YOU NEED A REPAIRMAN.
2. JUST FOR GOOD HABITS DO THESE BEFORE GOING TO THE REPAIRMAN: CHANGE NEEDLE AND THOROUGHLY CLEAN THE BOBBIN AREA WITH CANNED AIR AND A QTIP TO CLEAN DIRT OUT. AFTERWARDS PLACE A DROP OF SEWING MACHINE OIL ON THE RACE THAT YOUR BOBBIN CASE FALLS IN.
3. PLACE TWO INCHES OF THREAD UNDER THE PRESSER FOOT. TURN THE HAND WHEEL TOWARDS YOURSELF AND WATCH IF THE UPPER THREAD WRAPS ON TOP OF THE BOBBIN CASE WHILE THE NEEDLE IS RISING. THE THREAD SHOULD PULL AROUND THE BOBBIN CASE WITHOUT CATCHING ON THE BRACKETS THAT HOLD THE BOBBIN CASE. IF IT DOES CATCH A LITTLE BIT YOU MAY NEED TO MOVE THE BRACKET AWAY FROM THE BOBBIN CASE ABOUT ONE PAPER WIDTH.
Jan 29, 2015 | Sewing Machines
Why does my thread keep bunching up?
That is called "thread nesting," and several things can cause it. The upper thread enters the bobbin area during sewing, catches the bobbin thread, and as the needle goes up, pulls the stitch tight. Something is catching the upper thread as it goes around. The most common reasons are the bobbin or bobbin case (or both) is improperly inserted; the bobbin is warped (roll it down a flat surface--if it wobbles, it's warped), either the case or the bobbin is not seated evenly, there is a rough spot on the bobbin case that is catching the thread, or your bobbin is loosely/badly wound. You need to rule out the possibilities step by step until you find the cause. First, review your threading procedures from start to finish, using your user's manual. Then, without fabric, turn the hand wheel by hand (ALWAYS towards you) to see if you can see it start to catch. The top thread should rotate smoothly in the bobbin area. You should be able to pin-point the cause that way.
Sep 24, 2014 | Singer 2517 Mechanical Sewing Machine
My brother computerized sewing machine does not catche the bottom thread to make a stitch
try using a longer needle, or lowering the one you have now by loosening the needle screw and dropping the needle down some
Aug 08, 2014 | Brother Sewing Machines
The thread is not catching properly underneath
Try resetting the bobbin. Also check if bobbin is over-wound. Open hatch and watch to see what is going on down there. See if threads are wound around base of bobbin.
Jul 28, 2014 | Janome Harmony 2039 Mechanical Sewing...
I had my machine in the closet for 5 years and now need to sew a hem on my cotton pants. What should the settings be set at? Right now it is at a 4 and the stitch length is a 2 1/2. The thread is too...
If your machine has been stored for 5 years, you should give it a good clean and oil according to the manual before you do anything else. Then put in a new needle and wind a fresh bobbin, checking that the bobbin has been wound smoothly as a badly wound bobbin can cause poor tension and stitching from the bottom thread.
You want the thread to go from the spool through a tension disc or eyelet to the bobbin and keep some gentle tension onto the thread spool using your scissors handle or similar so that the thread winds off it smoothly and the spool doesn't bounce around. Also give the thread a nudge with your finger tip as it winds onto the bobbin so it fills evenly, top, middle and bottom, not all in the middle.
Are you wanting a straight stitch to sew around the hemline? If so, your stitch length is right, but stitch width should be zero. You don't say what knob is set to 4, if its your top tension then that should be close, usually between 4 and 6 if dial goes from zero to 10.
Which thread is too tight? top or bottom. Firstly check the threading path to ensure that the top thread isn't catching on anything, is through the take up lever properly and coming from the thread spool without catching there. Some thread spools have a little knick in the top where you can catch the thread to store it, but you dont' want the thread to catch here when seaming, so turn it around the other way on the spool so it can't.
Try test stitching a medium zig zag stitch on scrap fabric, and you'll be able to see if the bottom thread is pulling in or the top one, then adjust the tension dial a little to lessen this.
Hope these pointers help, if you can't get a good neat stitch after trying these things, then consider taking it for a clean and service, the technician can get inside and clean the machine thoroughly and also check for any other issues that might be there.
Apr 30, 2011 | Singer 57815 Mechanical Sewing Machine
When im sewing my bottom stitch looks good but my top stitch is real loose and sometimes my bottom thread gets pulled up. i have played with the tension but dont help
Check the bobbin tension and that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder.
Feb 24, 2011 | Brother CS-6000
Brother XL3030 SEWING MACHINE ..STRAIGHT STITCH LOOKS GOOD ON TOP OF FABRIC, BUT BOTTOM STITCHES ARE SKIPPING AND LOOPS FORM IN PLACES..YOU CAN PULL THE THREAD RIGHT THROUGH AND UNRAVEL ALL STITCHING! I...
Feb 19, 2011 | Brother XL-3030 Electronic Sewing Machine
When attempting to sew the bottom of the material stitches are all bunched up. Could it be the bobbin?
It could be the bobbin if you put it in the bobbincase upside down and its turning the wrong way. When its in the bobbincase and you pull the thread while looking at the bobbin, the bobbin should turn clockwise. If its turning counter clockwise flip the bobbin over.
It could just be the top isn't threaded right also.
Or maybe there is a burr on the hook that grabs the thread as it goes around. The burr would catch the thread and foul everything up.
There are a few reasons for what you described.
Rick
Sep 03, 2010 | Sewing Machines
Top thread won't pull up the bottom thread
make sure needle is in with flat facing back and pushed all the way up in needle holder. thread needle from front to back, and ensure a bobbin with thread is correctly inserted in machine with approx 2-3 inches of thread hanging off it.
wind machine over (top of handwheel toward you) gently holding the needle thread (do not hold taught or hook may not catch loop underneath needle plate) and the bottom thread should come wrapped around the needle thread after you have turned 1 revolution and stopped with takeup lever at top.
if you have done all of this and the bobbin thread will not come up, try sewing on scrap fabric and see if the stitches are correctly formed. if so all is good, if not, it sounds like your hook timing is out and will require a tech to repar.
goodluck,
scott.
Jul 29, 2009 | Brother LS-1217 Mechanical Sewing Machine
Sewing Machines Logo
26 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
