Question about Beko Washing Machines
Beko washer tap symbol
Tap symbol and washer stops
Beko wont stop filling up with water
Broken or defect intake magnet valve, if you can get your hands on the replacement part, fixing it should be easy-medium level difficult. It would take a service/repair man 3 minutes.
Nov 13, 2015 | Beko Washing Machines
Can anyone advise how I might find error codes on my BEKO WME8227 regards Andy
go to ukwhitegoods and tap in beko error codes you will find it there
Sep 20, 2013 | Beko WME7247W Washing Machine
3 or 4 mins into any cycle, machine stops, symbol on front flashes ( symbol looks like a tap on it)
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Sep 01, 2011 | Washing Machines
I have a beko washing machine it doesnt work when i check it i find there is no water in it after i turn it on and it cycle then it is stopd in 27 min and it doesnt work i made eveything but nothing happen...
No water fill?
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call ;-0(
John C
Jul 08, 2011 | Washing Machines
I have a beko eco washing machine about 4 years old when i put it to program 4 or 5 the timer turns a bit put stops i just also just seen there is no water coming in to the unit the water taps are open .if...
If you have checked that the hot water tap is turned on fully and the hose is not kinked or squashed at the back, it is worth while checking the hot water inlet filter. Turn the tap off and remove the hot water hose at the washer end. Inside the inlet port there is normally a little filter which should just slide out. Clean if necessary and replace it and the hose.
DO ALL THE SAME FOR THE COLD WATER INLET/ FILTER.
If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve or a malfunctioning control board. Sorry but then it's a service call ;-0(
John C
Apr 21, 2011 | Washing Machines
I have a hotpoint ultima wt940 washing machine,, which is displaying a tap symbol,, when it fills up at the start of the cycle,, h2o flashes on the screen,, then the machine stops. Any advice? Thanks.
H20 is indicating a problem with the water supply.
Check tap/s are turned on fully, no restriction in hose/s, and make sure that there is sufficient water pressure.
Another possibility is that the inlet valve/s are faulty inside the washer.
Please rate my solution.
Thanks.
Nov 07, 2009 | Washing Machines
Washing Machines Logo
180 people viewed this question
Top Beko Washing Machines Experts
Tom Chichester
J D Wright
 Russ Hill
Russ Hill
Are you a Beko Washing Machine Expert? Answer questions, earn points and help others
