Question about Vtech Tote n Go Laptop Plus
Vtech keyboard not working - Vtech Tote n Go Laptop Plus
Where is the sel button on vtech model#c56219-2
The key marked "MENU/SELECT" at the upper-right corner of the keyboard.
Jan 08, 2014 | Vtech 5.8GHz Cordless Phone with Digital...
Vtech KidiJamz keyboard: keeps saying turn off message (Let's jam again later..) and then turning off even with new batteries in place.
Ours had the same issue. I took the Vtech Kidijamz apart. The power button has its own little board. I unscrewed that. It connects to the next board via two wires. I reflowed the solder for all the connections for those two wires (four solder points total). Issue fixed. FYI: reflowing solder just means heating each solder point (with a soldering iron) until the solder gets soft and then removing the iron to let the solder cool and thus harden.
Oct 05, 2013 | Vtech KidiJamz Studio
My vtech phones show NO LINE; MY OTHER PHONE WORKS
More than likely the phones base station (transmitter) is defective, this is a common failure on Vtech cordless phones, i have owned two and both failed the for the same reason. I also see this problem posted often for Vtech phones.
Dec 02, 2011 | Vtech Lands Phones
Need user guide for vtech cordless phone
Go to Vtech Support,
http://www.vtechphones.com/vtechphones/index.cfm/support/general/manuals/
Type in the model number of the Vtech cordless phone, press the Enter key on your keyboard.
I downloaded a manual for my cordless Vtech phone not too long ago.
The User manual is in PDF file form.
The computer you are using now has Adobe Reader on it, which uses PDF files.
For additional questions please post in a Comment.
Regards,
joecoolvette
Sep 12, 2011 | Computers & Internet
We can't use keyboard or mouse the cursor is stuck
mcdevito75 here, Try to shut down the computer, click Start, then shut down. Or you can also try the crtl key and alt ket and delete key, all 3 keys pressed at the same time on the keyboard.
Jul 03, 2010 | V.Smile Vtech DeskPro
Notebook does not respond to keyboard selections
First, replace and check batteries these things usually use up batteries pretty quickly. If this doesn't work, the computer may have been dropped too hard. If this is the case you'll need to replace it. Check first with Vtech if you sent in the warranty card or have the receipt. Even if not try them anyways, it could probably save you some money.
Jul 18, 2009 | Vtech Nitro Notebook Kids Laptop Computer
Phones stopped working. They only read
first step is to unplug all power and phone connections from the wall for all Vtech phones and bases.
Second,plug each set and base in the wall for power one at a time.
Go back to the basics and pair the handset with the base of the unit.
Do this for all sets one at a time.
May 29, 2009 | Vtech 5.8GHz Cordless Phone with Digital...
I'm not familar with the Vtech but I would suspect that all 4 units work off of the answering machine base. It sounds like it is seeing a dial tone.
Take a working phones like the wall phone, if it is easily removed, and use a known good connecting cable between the good wall phone and the jack that the Vtech is plugged into.
If that works, take the connecting cable loose and replace it with the Vtech connecting cable. If that works check the jack on the Vtech for crossed wire. If non found, connect it to the jack the wall phone was plugged into. If this doesn't provide satisfaction, let me know exactly what you did and what happened and we will go from there.
May 28, 2009 | Vtech 5.8GHz Cordless Phone with Digital...
I need a repacement robot to us with the vtech me-mo-mo
I have a robot but no keyboard...
Jan 23, 2009 | Toys
Vtech Tote n Go Laptop Plus Logo
35 people viewed this question
Top Vtech Toys Experts
Nikki  Mclean
Nikki Mclean
Are you a Vtech Toy Expert? Answer questions, earn points and help others
