Question about Apple MacBook Air
My macbook air start to show me a white screen white a blinking folder inside
I have macbook for about a year now and i was out for few day wen i come back trying to turn on my macbook air it has a white screen with blinking folder inside what can i do to solve this problem
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 9 Answers
Sound like you have an issue with either your hard drive or the operating system has lost the plot. Try this OS About OS Recovery
If you are able to access the recovery partition then use the disk utility to check the disk.
If this does not work then take the computer to an Apple repair centre, if it's still covered by warranty the disk might be replaced under warranty.
If it's not covered, you could try using DiskWarrior 4 The Disk Utility for Mac Disk Repair Mac Directory Repair... which has allowed me to recover disks that have not been able to be repaired with Apple's disk utility.
Posted on Apr 23, 2014
smartr10U
  • 1305 Answers
SOURCE: my macbook has a blank white screen, and then it
Your macbook is not locating your hardrive.
turn off your laptop, insert the Mac OS disc in the drive, and then reboot while holding down the c key to allow it to boot from the OS on the DVD.
Then use the disk utilities application from the desktop menu and to a disk repair on your hard drive and then restart.
Posted on Nov 28, 2009
inferno45
  • 45 Answers
SOURCE: Bios setup for MacBook?
Command Button(the one with the apple logo) + Option + F + 0 when it boots
Posted on Nov 21, 2008
  • 6 Answers
SOURCE: Macbook Error
It's not finding your operating system. Could be failed hard drive, corrupted registry or a start up disk error. Have you tried starting on the Macbook Pro install disk 1? If not, insert the disk while it's starting up, it and hold down "c" key. When I comes to the start up window, click the right arrow button, proceed to the install window but don't install! Instead select "disk utility" under the pull down menu (upper left hand corner of the screen). Select the hdd in the upper window and click the "repair" button. Repeat the repair again after is finishes. If there is no hdd icon in the upper window, the hdd is probably fried and needs to be replaced. Hope this helps.
Posted on Jul 29, 2009
parrotheadpc
  • 2600 Answers
SOURCE: Switch on - screen is grey with flashing folder with questionmark
Hard drive is dead or the signal from the hard drive is not being read by the ide controller. I'm working on a MacBook 13 inch right now with the same issue. I had a spare hard drive and a windows Vista disc, so I installed the hard drive and inserted the vista install disc and the laptop loaded and installed Vista on the Mac with no issues. I took the hard drive from the Mac and attached an adapter to it and ran it through a usb on another laptop and the laptop could not read the files on the drive....so, the drive was bad.
Posted on Oct 24, 2009
SOURCE: on startup, white screen with question mark folder
my mac pro laptop has white screen flashing folder with question mark it fell & when i took it to the store they told me it was the hard drive so i bought a new one and it still does the same thing so how do i fix my laptop . please help
Posted on Apr 10, 2010
My macbook has a white screen with blinking folder inside what can i do
The issue is that the laptop cannot find a disk to boot from. This could be due to a number of things. Failed disk, corrupt disk, corrupt system files on the disk. If you have a system disk and an internal or external dvd reader, you may be able to boot from that. If not, then you will probably be visiting an Apple store, or at least a computer repair shop that repairs apple computers. If you have no backup, you risk losing your files.
Dec 28, 2013 | Computers & Internet
Won't turn on
The problem in blank white screen is the display (LCD). Send it to a technician for repair. The blinking folder with a question mark is conflict on drivers. Have you installed a software lately? If you do please uninstall it. Maybe that is the cause of having a blank white screen.
Jul 12, 2010 | Apple MacBook Pro PC Notebook
Vertical white wide band - Shivering fonts
Unfortunately that sound like a defective LCD panel. You can verify this by plugging the system into an external monitor. As long as the shimmering band does not appear on external display then it is the LCD. If it is under warranty I would suggest taking it into Apple.
Aug 16, 2009 | Apple MacBook Air Mac Notebook
Aluminum Macbook has flashing file folder with ?, won't start
Sounds like someone spilled windex on it. You may be out of luck if it ran down and hit the electronics. (which it sounds like it did)
Aug 14, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Macbook won't start!
that normally happend when the macbook do not find the software you can read this apple post http://support.apple.com/kb/TS1440
Jun 24, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Blank screen with blinking folder
This is a sign that the startup disk can't be found.
When you power on the computer, try holding down the "alt" key or "option" key on your keyboard.
Then after a while, it should ask you to select the location of the operating system. Select your macintosh HD. Everything should load as normal.
If this doesn't work, insert the install cd's and hold down "c" instead. This will load the cd with mac os x on it. You can then install the operating system. Please make sure you have backups. Unless the option to simply upgrade or repair your mac pops up, you will loose your files following this method.
Nathan.
Apr 13, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
When i try to log into my macbook...
try checking your disk / disk permissions (note:to verify disk you must start from the os x cd at the top of the screen click utilities -> disk utility->repair disk)in the finder window after login you can press command N (apple key and N key at the same time) open the applications folder and find the utilities folder open utilities folder and double click 'Disk Utility' select the disk you wish to repair from the list on the left and click repair disk permissions (note you should back up important files before performing any disk repair utilities) also if you cannot log into the finder you can simply insert the os x disk and hold the C key down after the first boot chime this will start from the cd drive (which may take a little while)
Mar 11, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Macbook
This is a copy of a previous post of mine -
Fixya - Mac Won't Start
Here are a few things that might help you
Try to start your computerfrom the system CD, if this fails, you may try to start it from theDisk Warrior CD, if this won't work also, I would check the PRAM.
Aug 06, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Apple MacBook Air Logo
126 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
