Question about Philips Audio Players & Recorders
Philips home cinema dvd wont eject
DVD is stuck mid film and player says starting I have a Philips HTS3541/05 Home Cinema and a disc is stuck in the tray. We were played a film last night and it just stopped and now it only says starting on the screen and I cannot eject. I have tried turning completely off (plus overnight) but still the same. I am downloading new firmware onto a usb but it tells me not to upgrade if there is a disc still in. Philips advise to return to store, but I was hoping for a fix as stupidly I cannot find the receipt!
    Problem Solver:
  • 9 Answers
If you bought it with a credit card you should have up to 90 days to return it. You will void the warranty if you try my solution. look on the back and sides. There should be some small screws. Take them out and then slide the back off of the player. You should be able to see the disk tray. Some systems have a manual eject button hidden somewhere inside. Once it is open you should be able to find the model number of the dvd drive. Look up the specs and see if you can find the button. Otherwise you can try to force it open. Be extremely careful if you do this. You could strip the gears and or break it. If the gears are exposed use a small flat head screw driver and slowly turn the gears till it opens. I hope this helps.
Posted on Dec 28, 2013
  • 123 Answers
SOURCE: lx 9000r wont play any dvds even previously played
You can try reseting the unit.
Reset the set to the default factory settings:
All the information stored
(programmes, time and date) will be lost.
1.
Disconnect the set from power supply.
2. Press and hold down "STANDBY•ON" on the set and reconnect the set.
3. As soon as "IS TV ON?" is displayed, release "STANDBY•ON."
Hopefully reseting it will clear whatever problem it is having and allow you to once again use your DVD player.
Hope this helps. Good Luck.
Posted on Apr 08, 2008
  • 3 Answers
SOURCE: samsung ht-x20 unlock codes
http://www.videohelp.com/dvdhacks/samsung-ht-x20/8981
This should solve it :) I had similar problem. Swapnil
Posted on Nov 04, 2008
SOURCE: Samsung home cinema system HT-THX25 Multiregion hacks
Turn on the HT with no DVD. Press the following buttons on the remote: ENTER 8, 4, 2, 6, 9 ENTER
It will turn off. When turned again on it is a region free HT.
Posted on Nov 26, 2008
SOURCE: my samsung home cinema ht-tz212 wont play discs,
Try resetting the system turn power off then press and hold stop button on Main unit for at least 5 seconds this is main system reset it may well do the trick for you
Posted on Apr 10, 2010
SOURCE: LG DVD player Disc Error message even when playing lens cleaners!
LG DVD Player Disc Tray opens & closes automatically & unnecesarrily
Posted on Jun 27, 2010
When inshirting movies dvd in dvd player showing message on dvd players screen no disc and cant play movies dvd why?
it could be the disc itself dvds really don't age that well a common problem is that one day they just decide to freeze and stop working even though they had only been played a few times the most extreme would be your situation. I would suggest trying newer dvds out if same problem occurs then it is a problem with the dvd player.
Feb 06, 2015 | Philips Televison & Video
I have a Philips HTS5550 home theater and i have found out that the dvd spindle spins a disc for a few seconds, then it stops and displays a "No disc error" on the screen. What is the solution to repa
First, make sure you're not trying to play a bad disc by testing with another factory-burned DVD. And ... please do not be insulted here ... be sure the labeled side is facing upward. If still the same, the laser is mot likely defective and you will not be able to repair that yourself.
Aug 07, 2014 | Philips HTS5550/12 DVD/DivX Home Cinema...
I have a Philips HTS5550 home theater. The dvd machine has of late been displaying a "No disc error" when i insert a dvd in the machine to play. I have already tried using the cleaning kit. What might
if there's no flashing red light on lens?.. the ribbon connector of lens is not properly connect, or change it if you notice that it has lines cracked. the bad performance of the disk spinning motor is also causing why was your unit displaying "no disc" error.
Aug 04, 2014 | Philips HTS5550/12 DVD/DivX Home Cinema...
Would like unlock code for Philips HTS5593 Blu ray
To make your Philips BDP3100 region free (this works on a BDP3100/05 purchesed in the UK in June2010)
1. Make sure there is no disc in the tray when you switch on.
2. Press "home" key on remote control.
3. Enter number "1389310".
4. Switch off. Wait a few seconds and then switch on...now region free.
Please note, the above hack has only been confirmed as providing region-free DVD, not Blu-Ray.
Mar 14, 2013 | Philips HTS5593/12 3D Home cinema system...
I just bought a philips hts3510 home cinema and i just found out that it doesnt take any dvds with region 1. Is this the fact that these years such dvd players do not support multi region dvds?? Im very...
http://en.wikipedia.org/wiki/DVD_region_code
"The commercial DVD player specification requires that a player to be sold in a given place not play discs encoded for a different region".
If you don't live in Region 1 and you know most DVD's ARE Region 1, it would make sense that some care should be taken to buy DVD's compatible with YOUR region.
Feb 19, 2011 | Philips Audio Players & Recorders
When I turn on my Philips lx8500w dvd player my wireless internet stops working, what may be the problem?
the lx8500w uses the same frequency as the wireless (2,4Ghz). I bought the same system, it's ********. Just problems and after 2 years it doesn't work anymore (goes to standby after 1 hour or so). Try to change the wireless channel. Or buy another home cinema...
Mar 19, 2010 | Philips Home Cinema system DivX LX8500...
Tray lock on pioneer
press and hold stop button on the front apnel on ur dvd palyer ur palyer will resetting
Jan 26, 2010 | Pioneer DVR-225-S Pure Cinema Home DVD...
DVD player disc tray won't open
take a screw driver and open it up
maybe its a disc that stuck
if not working
probably cheaper to buy a new one
Apr 28, 2009 | Philips DVD793CH Multi-disc DVD Player
161 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
