Question about Toys
Innotab 3s touch screen not responding,
Cant re callibrate or reset as the screen is not responding or selecting things on its own accord. It was fine until i purchased some new downloads.
SOURCE: touch sensitive screen not working
I found a solution for the LG KU990 Viewty touchscreen not responding problem. After thinking about twisting my phone, I came up with another solution which actually works every time. The touchscreen works via layers of plastic that when contact is made, a signal is triggered from the coordinates of the contact. However, when the phone has pressure, these layers of plastic stick together somehow. So, to fix it.... Get a small strip of adhesive tape that will not leave a sticky residue on your screen. Apply that tape in several spots on the surface of the screen, and lift it away from the phone with light pressure. Repeat this in several areas of the screen. That's it. You're done. Your screen should function properly. Simply recalibrate the touchscreen at this point in your settings menu. I hope it helps everyone with any type of touchscreen. I know it helped me. The touchscreen phones are totally useless using only the hard keys!
Posted on Jul 11, 2008
SOURCE: Touchscreen does not respond to touch
This is straight from Palm Support...
1.Press and hold the UP button on the front panel of your device.
2.While holding the UP button, use an unfolded paper clip, or the reset tool at the tip of your stylus, to gently press the RESET button inside the hole on the back of your device
3.The Palm Computing Platform screen will appear. Release the UP button when you see it.
Posted on Sep 29, 2008
SOURCE: My tytn ii touch screen is not responding
I have had the same problem but have finally got past the alignment screen by putting a new text document called welcome.not onto the memory card. At least the phone is working now, but the screen is not. HTC have sent me the phone back wanting £360 because they say it is water damaged even though it is less than 12 months old.
Posted on Mar 03, 2009
ihavsolution
  • 152 Answers
SOURCE: touch screen on Palm Z22 does not respond
http://www.palm.com/us/support/handbooks/z22/en/maintain.pdf
follow this document to do a hard reset...
Posted on May 27, 2009
  • 17 Answers
SOURCE: dropped samsung jet touch screen not responding,
The touchscreen connector has come loose. It's a small flatcable which connects the digitizer (touch screen) with the pcb on the back of the screen. It's repairable, however you need to disassemble the complete phone. A great disassembly guide can be found here: http://www.formymobile.co.uk/jetdisassembly.php Good luck! :)
Posted on May 29, 2010
How do i install on innotab 3s if i have not got a disk drive for installation disk is there another way thanks
go to this link : http://www.vtechkids.com/download/ you should be able to find a link to download the app for it3s there
Mar 06, 2015 | Vtech InnoTab 3S The Wi-Fi Learning App...
My sons innotab 3s won't charge
try usiing just the charger without the rechargeable batts...if toy turns on with just that then prob maybe eiither the toy itself or you need new rechargeable batts
Feb 15, 2015 | Vtech InnoTab 3S The Wi-Fi Learning App...
Has anyone been able to access the web on the innotab 3s? If so how were you able to watch videos or play games?
This requires a Wi-Fi access point and an internet connection. The manual here explains... http://www.manualslib.com/manual/551479/Vtech-Innotab-3s-The-Wi-Fi-Learning-Tablet.html
Jul 04, 2014 | VTech Communications INNOTAB 2 PINK
Troubleshooting why does my innotab 3s not get recognised
You must install the InnoTab 3S version of Learning Lodge. If it doesn't automatically install, you can install from setup files on the VTech website. Download the manual at http://www.manualslib.com/manual/551479/Vtech-Innotab-3s-The-Wi-Fi-Learning-Tablet.html
Jun 28, 2014 | Baby Gear
My daughters pink vtech innotab 3s touch screen seems to be not working, she cant touch anything
Try recharging the batteries, or try using another powersource. if this does not resolve the issue then you may need to call their hotline
Mar 19, 2014 | Vtech InnoTab 3S The Wi-Fi Learning App...
Innotab 3s troubleshooting
Try to uncheck the checkbox indicating administrative account thay holds up to secure data..
Mar 15, 2014 | Vtech InnoTab 3S The Wi-Fi Learning App...
Troubleshooting innotab screen
have you tried calibrating the screen? You can do this by pressing the Home Button, question mark, and volume up button all at the same time. Turn the toy on without letting go of the other three buttons until you see the Touch Calibration Screen. If this does not help, then I suggest you call Vtech. Contach info is available at www.vtechkids.com if you no longer have the manual.
Jan 22, 2014 | Vtech InnoTab 3S The Wi-Fi Learning App...
Innotab 3s some items failed to load due to network congestion
Has this problem been resolved? If you still get this issue I suggest you call the Vtech hotline. Contact info can be found at www.vtechkids.com
Dec 25, 2013 | Vtech InnoTab 3S The Wi-Fi Learning App...
Trying to connect the innotab 3s and it says the security mode being used by this network is no longer in standard mode
please read the review below as I think you may need to download patches and firmware updates to maybe fix your problems.
http://au.pcmag.com/vtech-innotab-3s/383/review/vtech-innotab-3s
Dec 08, 2013 | Toys
Touch screen doe not respond, it terns on visually but it don't let me do anything the touch screen don't work.
there is a callibration for touch screen in the touch screen settings.. if that does not work - the touch scren probably needs to be replaced.. It happens unfortunately..
Have a great day
Mar 06, 2010 | LG Prada KE850 Cellular Phone
Toys Logo
117 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
