Question about Pets - Others
On and off switch
Remains off
Wiper remains on after the combation switch is off
your switch could be faulty or bridged try changing the switch
Jul 24, 2013 | 1999 Chevrolet Venture
WFK2401UC on/off switch #171021
You can always bypass switch and use the switch on your socket as your on/off switch
Jun 17, 2013 | Bosch Washing Machines
Is the Woods 59028 Programmable Timer Switch Light Almond a 3 way switch?
Woods 59208 is single-pole timer.
Open following link to see list of timers used for 3-way application:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59028
When replacing 3-way switch, some timers can replace either switch. For example Aube and GE.
Other timers can only replace switch that receives power from breaker. For example Intermatic.
The timer replaces only 1 of the 3-way switches.
The other 3-way switch remains.
But in all cases, the remaining 3-way switch has to be rewired to accommodate the timer.
3-way timers cannot replace 3-way switch wire-for-wire.
3-way timers mimic 3-way operation. When 2 of the timer wires are connected, the timer reverses programming. When those two wires are disconnected, the timer programming resumes. So off becomes on, and on becomes off.
The remaining 3-way switch has to be rewired so that switch connects and disconnects the two timer wires that mimic 3-way operation.
Aug 08, 2011 | Woods 59028 Programmable Timer Switch...
Is the woods 59028 a 3 way switch?
2000 gmc sierra dash lights and running lights remain on after
It seems you have a sort circuit in the wiring or the switch......
normally you have 2 types of shorts, 1 is to earth and this causes the fuse to blow, indicating a fault and preventing a fire.
The second one is a short to power, where the circuit remains on, despite the switch being turned off.
I would suggest that the park light switch is shorting out.
If you are not familiar with electronics, I would prefer you seek an auto electrician to do the job.
Jul 30, 2010 | 2000 GMC Sierra 3500
My contactor switch will not remain engaged. I
Something,is drawing too many amps,most likely the compressor.
Jul 08, 2010 | Frigidaire FAA065M7A Air Conditioner
Headlights remain on after turning switch off on
This is normal for most todays vehicles. If they remain on more than a minute your sensor could be malfunctioning. be sure the sensor on the dash doesnt have something covering it. it looks like a small bubble usually in the speaker grill
Sep 21, 2009 | 2000 Daewoo Nubira
1993 Corolla. Brake lights remain on, even with
Definately the brake light switch,locatedabove the brake pedal (may need to drop the lower facia panel) switch may need replacing or more than likely adjusting. new switch about £10. Good luck Davelee
Mar 23, 2009 | 2003 Toyota Corolla
Pets - Others Logo
21 people viewed this question
Top Pets - Others Experts
Ross Keen
Tom Chichester
Ruth summersides
Are you a Pets - Other Expert? Answer questions, earn points and help others
