Question about Liebherr Refrigerators
Liebherr cnsl 3033-22 manual
Manual
How do I change thermostat?
Look inside the cabinet for a black dial with numbers 1 to 9. Usually top left or right and at the rear. If it is a digital display, look for a 'set' button and arrows.
Should have looked first!
  • Electronic control system:
  • MagicEye with LED digital refrigerator temperature displays
  • SuperCool function
  • It states you can get instruction manuals from the site, but you have to find a 9 digit service number.
    You've misplaced your operating instructions? No problem.
    It's simple and convenient to download the latest operating instructions for your LIEBHERR refrigerator and freezer as a PDF document here.
    Just enter the 9-digit service number of your appliance, which you'll find on the rating plate. The rating plate is situated on the inside left of upright appliances and on the outside right of chest freezers. (Drawing )
    http://www.liebherr.com/HG/en-GB/region-UK/94270.wfw
    Pictures of where to find the code
    http://www.liebherr.com/CMS/images/Typenschild.jpg
    It says you can get instruction manual
    Oct 04, 2015 | Liebherr K3660-20 Refrigerator
    How do i reset my Liebherr Premium Freezer, the freezer is not cooling and making ice
    It needs professional service. If it is out of warranty, you'll need to call a service tech for a visit.
    Nov 26, 2014 | Liebherr SBSes 74S2 Premium NoFrost
    I have a Liebherr free standing french door frig (two freezer drawers). The plastic component that shapes the ice cubes has fallen out of the ice maker into the ice receptacle below. I don't know how to...
    I don't know about this ice maker, but you could always check the Owner's Manual (either the one that came with fridge, or an online copy) for re-attachment info. That's something basic that the manual may very well cover.
    Sep 18, 2013 | Liebherr CS2062 Bottom Freezer French Door...
    The top part of the freezer compartment is warming up and setting off the alarm. Liebherr 7080 207-01 model
    I also had defrost problem with Liebherr 7080 207-01. I removed freezer back panel, I defrosted all ice with hair dryer, but the freezer is not done for manually defrosting!!! You may have problems removing the back panel (I was not able to remove it with a screwdriver and i decided to pull it beaking the plastics supports and thean I put it back. It is a shame !!! Now it is working much better. I think this will be my last Liebherr freezer!
    Oct 18, 2012 | Liebherr Refrigerators
    How do you reverse the door swing on Liebherr K4260 refrigerator ?
    you may find the instructions here:
    http://www.liebherr.co.uk/HG/en-GB/119722.wfw
    As a starter look for the blanked holes on the other side, from there on it should be intuitive?
    Mar 05, 2011 | Liebherr K 4260 Refrigerator
    How to find part number of Liebherr fridge freezer
    Normally if you remove the LHS salad drawer in the fridge you will see a sticker on the wall of the unit with the relevant information.
    Hope this helps.
    Jun 08, 2010 | Liebherr Refrigerators
    Ice build up inside refrigerator Liebherr K3150
    may be you have a bad temperature sensor or bad control board.
    Mar 01, 2010 | Liebherr K3150 Refrigerator
    Hi does the Liebherr WTNES 2956 have a demo mode ? if yes how can I disable it ?
    Liebherr GNES 2866-20B, wont come on how do i get it out of demo mode
    Oct 31, 2009 | Liebherr KES3660 Stainless Steel...
    Liebherr f/f, drain gully is retaining water, drain hole is clean
    the fridge probably isn't quite level - or tilt the side that is holding the water slightly so it down to the drain hole - 1/8" could make the difference
    May 05, 2009 | Liebherr KES3660 Stainless Steel...
    Refrigerators Logo
    24 people viewed this question
    Top Liebherr Refrigerators Experts
    Dan Webster
    Dan Webster
    Shehu Pro
    Shehu Pro
    Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
