Question about Mitsubishi WD-52725 52". Rear Projection HDTV
WD 52725 won't accept INPUTS
After replacing the bulb, my set won't accept any input sources. No DVD player, No Xbox 360 no nothing. I just get the tell-tale blue screens when I change the inputs. I've read conflicting accounts on how to do a system restor or reset so I can't say I've been successful with one. I've tried thje "A/V RESET" button on the front for each input without success. Any help will be greatly appreciatted. Thanks!
  • Mitsubishi Master
  • 8,617 Answers
The most probable cause are the capacitors have failed on the terminal 1 and terminal 2 PWBs or the signal PWB
Posted on May 22, 2009
Video Does not work on New Magnavox TV
Hi, it sounds like your problem is that you've selected the wrong "video input" for your DVD player. Your new television most likely has at least 3-4 (sometimes 6-7) different inputs for video. With your DVD player connected and turned on, press the "Source" button on your TV to cycle through the different inputs. Be sure to wait 2-4 seconds between selections to give your TV enough time to switch inputs. If your DVD player has "color coded" output cables, it's most likely a "component" video connection. See if one of your video inputs on the TV is called "Component". Some other video types are Video, DTV, HDMI, SVideo, Component, Composite, RGB, PC Input, etc...
Jul 24, 2013 | Sylvania SDVD7014BJ 7 in. Portable DVD...
What's your problem?Im trying to hook up my xbox 360 to my JVC 27 inch TV, I installed the yellow to video input and the red and white to audio input and all get is the audio and no video. What am I...
Troubleshoot.
1. Ensure yellow is actually connected to an "input" slot.
2. Ensure TV is set to the correct input source.
3. Ensure your yellow, white and red RCA connectors are grouped in a single input source to TV. Sometimes the "component" and "composite" inputs are grouped closely together.
4. Consult the TV manual for hookup instructions.
5. Conduct a continuity test on the yellow xbox wire with a multi-meter.
Oct 04, 2011 | Sega The Club - Xbox360 for XBox 360
My WD-60735 doesn't recognize my xbox 360 in HDMI or AV. DVD player works fine in AV, Xbox works fine in HDMI and AV on another tv. Just goes to blue screen on this tv.
have you set your settings for 720p on your xbox then turn the tv on to the right input then turn the xbox on? i had that issue with a previous tv? does the lights on your xbox just spin around?
May 14, 2011 | Mitsubishi WD-60735 Projection Television
Mitsubishi WD-62627 Projection DLP TV help with PS3
To localize issue better try plugging your xbox into input for your ps3 and see what happens. You may have a bad input. Happens.
Aug 28, 2017 | Mitsubishi WD-52725 52". Rear Projection...
Multiroom not playing from 'DVD' source
Each input re[resents a zone, not a device. If your are lookin to seup multizones, each output controls one zone, ie - 1 = living room, 2 = outside, 3 = garage, 4 = pool room. If you are using a multidevice unit, the inputs must all go to one connector, input 1 = stereo, 2 = tv, 3 = xbox, 4 = pa.
Let me know if this make sense. If you have the make of the unit I will be more precise for you. I install these everyday, so this is easy.
Sep 25, 2008 | Marantz SR-7200 Receiver
Component video inputs 1 and 2 look very fuzzy, but DVD component doesn't, 720P
Hello, I am sorry for your issue. The audio inputs should not matter. It sounds like those inputs do have a problem. Please contact Onkyo at 800-2291687 option #3 so that we can troubleshoot with you and provide options. Thank you, Onkyo USA
Jul 06, 2017 | Onkyo TX-SR304 Receiver
No video throught HDMI output
press set up go option number 1 then go hdmi monitor and input yes. then press set up again
Dec 11, 2007 | Onkyo TX-SR605 Receiver
No digital inputs on the menu
Initialize settings by pressing "menu, 2, 4, 7, 0 enter" after settings have been initialized press the system reset button on the front once the LED stops blinking, reprogram the netcommand and tuner settings. 2. (Initialization and reset does not help) Suspect the DM PCB part # 934C116002
Dec 06, 2007 | Mitsubishi WD-52725 52". Rear Projection...
No picture using component on Toshiba 32HL66
It may be a synch issue. Make sure your component input is set for the proper type of output. Your XBOX 360 is likely set to 1080i, but your DVD and PS2 are only 480i (or maybe 480p for the DVD if progressive scan). Sometimes component inputs are 'self adjusting' to the signal, but others require manual setting.
May 30, 2007 | Toshiba 32HL95 32 in. LCD TV/HD Combo
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
103 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
