Question about Ignition System for Dodge Stratus
Dodge stratus how do I check what component is faulty ignition switch/actuator/lock
Car won't start
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Dodge Master
  • 1,727 Answers
Does it crank ??? yes - then its an engine/pcm problem
not crank at all then start with the battery and work your way towards the switch and to the starter
Posted on Dec 29, 2013
Is there an anti-lock switch on my 2005 dodge stratus
Sorry Debi , It does not work like that ! If the engine computer doesn't receive a signal from the anti-theft system , it wont let the car start . Could disable fuel , ignition , an sometimes it wont let the car crank over , There are bypass kits you can by , need to google it for your car. Other wise you'll lock up the system an it won't work .
Feb 03, 2015 | 2005 Dodge Stratus
Windows switches won't work intermittently then fuse blows so car won't start
It appears that you have a dead short in the switch, ehich would be like touchin teo wires together. Repkce of switch should solve problem,
Mar 28, 2013 | 2001 Dodge Stratus
Heat won't switch to defrost on my 2004 dodge stratus ?
either the control head is not working or the door actuator is not working or the door itself has broke or u have a vacuum operated door to which u might have a broken vacuum hose usually under the hood
Oct 07, 2012 | 2004 Dodge Stratus
Where is the ignition switch located on 2004 dodge stratus?
The switch is mounted on the back of the key lock in the column.
Aug 11, 2012 | 2004 Dodge Stratus
Doors won't lock, thinks key in ignition
Troubleshooting is required to inspect few parts.It can be issue with ignition switch.Its not getting off.Or issue with sensor or wiring.Or its faulty lock itself.Click the link below and follow the troubleshooting:----Driver Door will not lock or unlock with Key or Remote? http://whatisbyme.blogspot.in/2012/05/1998-toyota-landcruiser-driver-door.html
Driver side door will not lock or unlock with Remote? http://technoanswers.blogspot.in/2012/04/2009-toyota-tundra-driver-side-door.html
Central locking not working ? http://schematicsdiagram.blogspot.in/2012/03/this-is-how-system-operates.html
Remote will not unlock Rear door ?
http://schematicsdiagram.blogspot.com/2011/12/remote-will-not-unlock-rear-door-on-gmc.html
Repairing car Door lock Actuator?
http://howtobyme.blogspot.com/2011/11/repairing-car-door-lock-actuator.html
How to Access car door panel?
http://howtobyme.blogspot.com/2011/11/how-to-access-car-door-panel.html
Vehicle door panel components?
http://howtobyme.blogspot.com/2011/11/vehicle-door-panel-components.html
This will help.
Thanks.
Jul 17, 2012 | 2002 Subaru Outback
Cranks and then goes dead
First check your fuel pressure it should be 41-47 psi with key on and engine off if its below 32 psi replace the fuel pump and filter.If fuel pump checks out to be good then take ignition switch out and check for burned ignition switch wires and worn ignition key tumblers and ignition lock cylinder.These cars are known for faulty ignition switches and ignition lock cylinders.Ignition switch gets to hot then it won't start until it cools off.
Dec 30, 2011 | 1996 Pontiac Grand Am
I have a 2003 dodge stratus and all the lights work but the car wont crank over. I BANGED ON THE STARTER ALSO JUST NO CTANK
Check fuses, look at engine compartment fuse box, finda ASD relay swap it with horn relay. Try starting in neutral with foot on brake pedal(neutral saftey switch maybe bad). Check power at starter big wire(Need 12v+) check small wire while someone cranks car for you, you need a 12v+ while cranking, then it will go dead while not cranking. Cycle key-fob lock unlock, manually lock unlock driver's door(anti-theft problem). Check for faulty after market alarm system. (disabling starter).
May 17, 2011 | 2003 Dodge Stratus
Car dont start turns but dont run
Juan, this is straight from the book. Check these all out.
Make sure you have gas.
Make sure the battery is holding a charge.
You may have a leaking fuel injector, faulty fuel pump, or pressure regulator.
It may be a broken timing belt/chain.
Ignition components damaged or damp.
Worn, faulty spark plugs/coils
Broken, loosen, or disconnected wire in starting unit.
Broken loosen, or disconnected wire in ignition system.
Defective cam sensor, crank sensor, or PCM.
Mar 04, 2011 | 2004 Dodge Stratus
Locked key ignition
had the same problem with a 99 dodge van. tow truck driver put the key into the ignition and tapped it a couple of times while turning the key to freed it up and start the engine. works as long as you leave the key in the ignition so i use a second key to lock/unlock the van. hope this works for you. gary
May 19, 2009 | 2004 Dodge Stratus
97 dodge stratus 2.4 ,testing a camsensor
Have you had the ignition switch changed? If the ignition switch is faulty you can have issues getting the car to turn over. Also when driving the car can just shut off. The contacts in the ignition switch just wear out over time. It's a good place to start looking.
Dec 16, 2008 | 1997 Dodge Stratus
Ignition System for Dodge Stratus Logo
145 people viewed this question
Top Dodge Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Ruben Diaz
Colin Stickland
Colin Stickland
Are you a Dodge Vehicle Part and Accessory Expert? Answer questions, earn points and help others
