Question about Rl Flowmaster Rl Flo Master Proplus No Pump Sprayer, 2 Gallons
Flomaster model 1102WB tank sprayer: Cannot unscrew the top assembly to add weed poison. Does it rotate CCW? Been a while since I have used it, and I cannot find the manual. Charles
2 Suggested Answers
  • 961 Answers
SOURCE: I have the follwoing R.L.Flowmaster products: R.L.
They sell the sprayers and parts at Home Depot, Walmart and other places. I am providing a link for you to look at:
http://www.rlflomaster.com/wherebuy.htm
You can click on the store logos and pick out what you want and, they have an 800 number to check stock.
Posted on Jun 12, 2011
What is the mixing ratio to 1 gal of water?
Their products are here, but they don't tell you the usage. It has to be on the label by law. The rear label usually lifts up to reveal a small book of three or four pages. If it isn't there, contact the company via the website.
http://www.spectracide.com/Products-and-Solutions/Lawn-Weed-Killers.aspx
The does have label details here
http://www.spectracide.com/Customer-Help/Labels-and-MSDS.aspx
For the Spectracide it is 1/2 oz to a gallon, but it depends on what type of grass you have. I will copy and paste the label details, but I doubt the format will stick, but it is all there.
Ounces of Concentrate to Use for:
St. Augustine*,
Bahia,
Centipede
2/3
2 2/3
13 1/3
21 1/3
32
32
1/2
16
250
1,000
5,000
8,000
Sq ft
to be
Treated
Bluegrass,
Fescue, Rye,
Zoysia
Gallons
of
Water
*DO NOT USE ON FLORATAM VARIETY OF ST. AUGUSTINEGRASS IN
FLORIDA.
HOW MUCH TO USE
SPOT TREATMENT
To spray small areas or individual weeds, use a pressure sprayer for better
control. Do not use a hose-end sprayer. Mix as directed in table below. Shake
well before spraying. Be certain to wet each weed.
ENTIRE LAWN
PRESSURE SPRAYERS
Measure amount of concentrate from chart below into sprayer tank and dilute
with 1 gal of water. Close tank sprayer and shake well before spraying. Use a
spray pattern that gives small spray droplets without any ne mist to treat
250 sq ft.
HOSE-END SPRAYERS
"CONCENTRATE ONLY" (DIAL) SPRAYERS
1. From the chart below, determine amount of concentrate to be applied for
each 250 sq ft of lawn.
Bermuda,
Bentgrass
St. Augustine*,
Bahia, Centipede
1/2 - oz
2 - oz
2/3 - oz
2 2/3 - oz
1 - oz
4 - oz
1/2 - oz
2/3 - oz
1 - oz
Grass
Type
Ounces in
Sprayer
250 sq ft
1,000 sq ft
250 sq ft
1,000 sq ft
250 sq ft
1,000 sq ft
Area
Treated
Dial
Setting
Bluegrass, Fescue,
Rye, Zoysia
FLORIDA.
2. Fill sprayer jar with enough concentrate to cover area to be treated. Do not
add water to sprayer.
3. Set dial on sprayer to the setting from the chart below.
4. Attach sprayer to hose. Extend hose to the farthest area of lawn to be treated
and work back toward faucet so that you do not walk over treated areas.
Apply evenly to lawn.
EXAMPLE: To treat 1,000 sq ft of fescue lawn, add 4 - oz of concentrate to the
sprayer with sprayer dial set on 1 - oz. Check the directions you received when
you purchased your sprayer for further details on the proper use of your dial
sprayer.
"CONCENTRATE-PLUS-WATER" SPRAYERS
For sprayers that require the addition of water as well as concentrate prior to
application:
1. From the following chart, determine amount of concentrate required to treat
2. Pour concentrate into sprayer jar to the required "- oz" level.
3. Then add the appropriate amount of water to the "gallons" level. Replace
sprayer top on jar and shake well before spraying.
treated and work back toward faucet so that you do not walk over treated
areas. Apply evenly to lawn.
EXAMPLE: To treat 1,000 sq ft of fescue, pour in concentrate to the 4 - oz mark
and add water to the 4 gal mark. Check the directions you received when you
Lawn Weed Killers
Apr 18, 2016 | Spectracide Bug and Weed Killer for Lawns...
I have no pressure in my flo-master sprayer after pumping
Make sure the tank pressure release is shut, or make sure the rubber o-ring under the pump is there. You should feel back pressure after a few pumps.
Jun 29, 2014 | Rl Flowmaster FLOMASTER 1 GAL SPRAYER ()
How do you refill?
Remove all pressure by keeping the hose open until no pressure is left. place pump handle down toward tank. Turn count counter clock wise to unscrew. Take assembly out of tank then fill tank. Reinstall in reverse order.
https://www.chapinmfg.com/sprayers
May 24, 2014 | Chapin 2 Gallon Spectracide Sprayer
I've just been given a roundup 2 gallon sprayer. It seems to me the top should be removable to add the liquids but I can't figure it out and don't want to experiment to the point that I damage...
Howdy MMis971,The sprayer just needs to be pushed down by the handle as you turn counter clockwise. This can be made a little easier by unscrewing the nozzle where it connects to the tank to release any pressure built up by pumping.
Happy Gardening,Coach Dave
Sep 10, 2011 | Roundup 2 Gallon Pro Garden Poly Tank Pump...
Sprayer not working right...seems cloged. How can I clean it ?
TAKE SPRAYER HOSE OUT OF JUG CHECK FILTER ON THE END. AND UNSCREW
TIP AND CHECK FOR ANY TRASH AT TIP.
Sep 06, 2011 | Roundup Poison Ivy And Brush Pump 'N Go
Can you tell me how to pour water and chemical into the tank? the small nozzle for the gun is too small
The handle that you use to pump that sprayer will twist and come out... then you pour the water and chemical through that larger hole...replace the pump...twist it tight and then pump the pressure...
heatman101
Oct 27, 2010 | Rl Flowmaster FLOMASTER 1 GAL SPRAYER ()
I have lost my owners manual for my model 2602. Can I get that?
FUNNEL TOP SPRAYER MODELS 2601, 2602, 2602I, 2603, 1602: Operating Instructions ( http://rlflomaster.com/service/pdf/971-230.pdf )
Or, tired of browsing the web? Call us: 1-800-253-4642
Hope helps (remember to rate this).
Sep 30, 2010 | Rl Flomaster 2 Gallon Acid Resistant...
What is the mixing proportions for roundup in the home use sprayer?
pH of water is important. Buffer pH at PH 5 . Then add 2% Roundup. Homesprayer is 1 lt therefore 2 % is 20 ml.
in a 20 lt Rucksack sprayer a 2% is 400 ml.
If weeds are above kneeheight and thick use a 3% solution.
Aug 06, 2010 | Roundup "" Weed & Grass Killer
Sprayer valve is clogged
I've had some success by removeing the entire trigger mechanism and soaking it in solvent for a few hours.
Mar 23, 2010 | Rl Flomaster Acid-Resistant Sprayer...
Rl Flowmaster Rl Flo Master Proplus No Pump Sprayer, 2 Gallons Logo
247 people viewed this question
Top Rl Flowmaster Garden Experts
andy just round the...
Level 1 Expert
Nick Olsen
Are you a Rl Flowmaster Garden Expert? Answer questions, earn points and help others
