Question about Car Audio & Video
Cant get the swoofers to come on
Took it to the shop to get wheel bearing fixed and the subs were workmen and wen I went to pick it up they didn't work like someone shut off something or turned on something
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 103 Answers
They probably removed your battery cable during the repair (standard procedure) and forgot to reconnect the amplifier wire (not standard procedure).
Posted on Dec 29, 2013
I have a bmw 520i 2003 117000kms. after changing the valve gasket cover the engine light went on. the diagnosis didnt pick anythg at the garage but still experience a bit of shaking of the car wen drinving...
Check the tires for proper air, or have tires balanced at a reliable tire shop. I would check to see if the wheel bearings are loose worn or out of adjustment. While you're at it check the shock absorbers and suspension components for wear or damage. Look to see if the stabilizer bar is broken or bent. Hope that Helps.
Feb 02, 2014 | Cars & Trucks
Had rear brakes replaced about a month and half, had a thunking noise. took back, said i had tar on tire causing noise. said it would go away, after 3 to 4 weeks got worst, only heard noise when applying...
Hello and welcome to FixYa!
Even if you are missing a lug nut it won't make a noise if the rest are tight. I suspect that the problem will be on the wheel bearing. The wheel bearing can be worn out that's why you hear a noise. I suggest that you go for the wheel bearing replacement to resolve the issue.
Hope this helps and thank you for using FixYa! Have a good one!
Sep 03, 2011 | Dodge Caravan Cars & Trucks
I have a 1998 cavalier. My back wheel on drivers side was locking up so had a wheel cylinder replace and a brake line by just someone, then that didn''t help so I took it to all stars and they did...
its possible that the seals in the wheel cylinder were damaged from the previous problem when it didn`t fix the problem.was the replaced seal a new one or a used one that the someone installed or the seals were defective from the manufacture.also were the brakes shoes cleaned of the brake fluid that was on them from the original cylinder leaking on them as this can cause the brakes to lock up,as well as if the brakes are not adjusted properly can cause this as they will catch and turn with the drum until it can`t rotate any more causing the brakes to lock up.as far as the hardware missing then the person that replaced the wheel cylinder didn`t replace everything that they took off or didn`t know what was suppose to be there as far as parts.
Aug 09, 2011 | 1999 Chevrolet Cavalier
Took 05 equinox to shop for wheel bearing work and shop called and said center carrier bearing needed replaced immediately. He told me that he would change it for $64 labor and $150 for the driveshaft...
It does seem a little bit shady. They should have done a full diagnosis on the repairs that were needed and then gotten you're approval before they proceeded with the repairs. If you didn't give them approval to do all that work, then they did it at their own risk. In my opinion you should only pay them for what you approved them to work on. What a hassle...good luck with that.
~Brandon
May 28, 2011 | 2005 Chevrolet Equinox
I had both front end hubs replaced on my 2004 Siverado 1500 pick up truck. What is a hub?
hub took the place of old wheel bearing know they are seald bearings easy to replace remove brake calaper an three or four bolts an king nut if fourwheel drive sorry i cant spell haha
Dec 16, 2010 | 2004 Chevrolet Silverado
AWD Disable and abs light always come on , already replaced rear selanoid . Whats going?
CHECK ABS FUSE AND RELAY.THE AWD CONTROLED BY SPEED SENSORS ONE IN THE FRONT OUT PUT SHAFT SECOND SPEED SENSOR IN THE REAR OUT PUT SHAFT THIRD SPEED SENSOR IS VECHICLE SPEED SENSOR.BEST TO HAVE VECHICLE FIX AT A GARAGE OR DEALERSHIP YOU WILL NEED DIAGNOSTIC EQUIPMENT TO WORK ON IT.
Aug 30, 2010 | 2002 Buick Rendezvous
Left hum assemply whinning as I pick up speed.
something is not right if you replaced brakes 2 mounths ago it cant need new ones, ask why,maybe a frozen caliper? anyway i would have another shop take a look, see what they tell you. or pull the wheels and you take a look,hope this helps.
Jan 04, 2010 | 2000 Jeep Cherokee
Cutlass Supreme new front wheel bearing repeatedly goes out
You may have pulled the inner tri-pod joint out of the cv shaft and that will make noise. Is the bearing really bad? Does it turn freely?
Jun 23, 2009 | 1995 Oldsmobile Cutlass Supreme
Anti lock and trac off
the abs wiring is in wheel bearing . you could have a bad bearing . a shop with a scanner could tell you witch one is bad or has wiring problems. aleros wiring run down lower control arm to wheel bearing. on control arm the wires get cut inside plastic loom and you cant see it till you pull them out and look .once you fix problem the lights will go out on there own.
May 21, 2009 | 2001 Oldsmobile Alero
1995 Toyota Celica Front Wheel Hub
can u replace the bearing in the hub? will that fix your problem?
May 25, 2008 | 1995 Toyota Celica
Car Audio & Video Logo
15 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
