Question about Dishwashers
Whirlpool Dishwasher won't drain during normal cycle
I have a Whirlpool Dishwasher Model # DU1055XTVS which is about 4 years old.
It runs through its normal cycle and cleans the dishes well. However, at the end of the cycle, it appears that it doesn't empty the water basin. The tub is always full of water at the end of the run cycle.
Every morning I have to push the Cancel button on the dishwasher. When I do this, it goes into a 2 minute cycle - where the first thing it does is empty the water. I can hear it running out through the drain, and it sounds fine. After the two minute cycle, the tub is always empty. Without fail this works - so at first I thought the drain might be clogged but considering this always works, I don't think it could be the case.
Interesting thing I have found. At the end of the dishwasher cycle after the heated drying has stopped, I can immediately push the Cancel button, and nothing happens. I have to wait 1/2 hour or so until the dishwasher cools down, before pushing the cancel button to get the water to drain. It seems that while the dishwasher is still hot, it won't empty the water or process the cancel button push.
What's the problem? What should I look at or replace ?
  • Mike H Jan 19, 2012
    I am having the this same problem.
    I am having the same problem.
  • 67 Answers
As you say a clogged line or valve does not make sense.
Try running it without the heated drying and see if it empties or if the cancel button will work then.
The dishes should air dry quickly if you empty it and open the door.
It could be a defective thermostat allowing it to get too hot during the heat cycle
Posted on May 19, 2009
My whirlpool dishwasher (GU980SCGB3)will not drain. Wash cycle works fine. Water will not drain when the cycle is finished.
Whirlpool Dishwasher Won't Drain - Model GU980SCGB3 ...
www.repairclinic.com/...Dishwasher/...-/Whirlpool-Dishwasher-won-t-dr...
My Orders. Login · Order History · My ... Whirlpool Dishwasher Won't Drain.GU980SCGB3 ... Dishwasher not draining, wont' start or not cleaning dishes properly? This video provides ... how to access... Show all parts for model GU980SCGB3 ...
Nov 04, 2015 | Whirlpool 24 in. GU980SCG Built-in...
Why is my whirlpool dishwasher making a loud noise during drain, wash and rinse cycles?
They can be complicated to re-assemble. Best solution is to video the procedure (if you have a video camera) during disassembly and make notes and diagrams to orient things properly and make sure the correct screws go back where they shoud. Takes more time, but you'll be glad you did, it will save you a lot of aggrevation in the long run.
Aug 24, 2014 | Whirlpool 24 in. GU1500XTLS Stainless...
Motor keeps running. Water heats fine. Help
One of the reasons for motor not draining during normal cycle is the check valve is stuck. It is meant to return to normal during drain cycle but close during wash. I think the cancel is resetting it and letting water out.
See this discussion.
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dishwasher/26-129-977852-/Bosch-Dishwasher-won-t-drain-SHE43RF2UC64
Apr 02, 2014 | Bosch 24-in Built-In Dishwasher Color:...
DISHWASHER was locked now unlocked but won't run. Goes to drain/Cancel when you push the Normal Cycles
Wondering how you unlocked the dishwasher. Normally you would have pressed Heat Dry for about 4 secs.
I don't this action would have caused the problem. For dishwasher to run you need the door lock switch to operate. If door is not closed it will go to Cancel.
Check item 12 in this diagram.
Oct 26, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher won't drain.Leaves several inches of water in bottom of unit after cycle is complete
Check for blockages in the base of the dishwasher under filter etc.
Also make sure the kitchen drain is clear and if you have garbage disposer run it prior to running the dishwasher.
Also need to confirm if the dishwasher pump is actually operating during the drain cycle. If the pump is faulty then it will not drain. Provide full model number of dishwasher if you need further assessment of the problem. Good luck.
Aug 30, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
My Whirlpool Quiet Partner II dishwasher (DU1055XTVS) will not cycle out of the wash cycle. I've tried running it on the normal wash and other modes with the same result. Is there a common problem with...
Either the contact on the door is not flush with the dishwasher, which makes a good connection between the door and the diswasher. Make sure if it is built into a cabinet the dishwasher is sitting straight inside the cabinet. If it is not straight this may cause it not to function properly and will cause the door not to make a good contact.
If that is not the issue replace the switch in the door. Or you may have an even more problematic issue: The timer controller in the door is bad.
Jan 11, 2011 | Whirlpool Dishwashers
GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Dishwashers Logo
540 people viewed this question
Top Dishwashers Experts
Owen Barnes
