Question about HP Hewlett-Packard Compaq 8710w Mobile Workstation Notebook Computer RM263UA PC Notebook
8710w rtc battery - HP Hewlett-Packard Compaq 8710w Mobile Workstation Notebook Computer RM263UA PC Notebook
8710w - Not reading External Monitor
Possibly a connection issue or configuration error.
Jan 30, 2014 | HP Computers & Internet
E320 2007 battery replacement
Lenovo ThinkPad Edge E320?
I don't think you are referring to the Main battery......
However;
1) There is a slide button on each side of the Main battery.
Both are slid to the outside edges of the laptop, then the main battery is slid out. Out towards the outside of the laptop.
I believe you are referring to the CMOS battery.
Also known as the RTC battery. Real Time Clock battery.
From what I can see the ThinkPad Edge E330 is VERY similar to the ThinkPad Edge E320.
What you need is the HMM. Hardware Maintenance Manual,
http://www.manualowl.com/m/Lenovo/ThinkPad-Edge-E330/Manual/309892
Use the Right Arrow on the right side of the number 100, at the top; to go down through the pages.
Page 61 for Main Battery Removal/Replacement
(Starts on Page 60 - 1010 Battery Pack. Bottom of page)
Page 70 for RTC Battery Removal/Replacement
Bottom of the page - 1070 Backup Battery
As you can see you just remove the screws, (Philips. Use No.1 Philips screwdriver, or equivalent Jewelers screwdriver), for the Bottom Cover, and remove the Bottom Cover.
(It's a panel. It is not the Base Enclosure/Bottom Cover)
Then unplug the small white male plug connector, on the end of the RTC Battery's wires; from the motherboard.
Remove the RTC Battery, and replace.
This shows you in a video, but a different Lenovo ThinkPad Edge laptop.
Principle is still the same,
http://support.lenovo.com/en_US/downloads/detail.page?DocID=PD021754
KNOW THIS HOWEVER........
Your body carries Static electricity. When that Bottom Cover is removed, all of the Static shock sensitive hardware components are exposed.......
You need to make SURE your body is relieved of Static, BEFORE reaching to unplug that RTC battery, or remove it.
Better still is to wear an ESD wrist strap, and have it's alligator clip attached to a good ground source.
(Electro Static Discharge)
Average cost is around $3 to $6.
Here is but one example,
http://www.radioshack.com/product/index.jsp?productId=2103245
Example of RTC Battery,
http://www.ebay.com/itm/COMPATIBLE-Backup-RTC-CMOS-BIOS-BATTERY-CR2032-FOR-IBM-Thinkpad-02k6541-/251250253852?pt=Laptop_Batteries&hash=item3a7faea01c
Now I did NOT state that this was THE RTC Battery you need.
Just stating that is what it looks like.
Know this;
ALL of these batteries produce 3 Volts DC.
They use a CR2032 watch type battery, that is commonly used in a desktop computer.
All you need to make sure of, is the Male Plug Connector is correct.
Yep. That's it.........
If you HAVE to, you could cut the wires on the new RTC Battery, cut the wires on the old RTC Battery, and PROPERLY splice the old RTC battery's male plug connector to the new one.
Use heat shrink tubing, and solder the wires together.
Remove RTC Battery to reset a password?
Nope. Don't think so.
There should be a capacitor, or capacitors; that store a small residual charge of power -> INDEFINITELY, even after removing the RTC Battery. (CMOS battery)
CAN I be wrong? Yep. Depends on manufacturer, and year made.
Replace RTC Battery because it's no good?
Yes. Sure.
Looking at the Base Enclosure, (Bottom Cover), is part of what makes me think the E330 is very close to the E320,
http://www.pcworld.idg.com.au/review/notebooks/lenovo/thinkpad_edge_e320_129834m/397569/images?image=5
http://support.lenovo.com/en_AU/product-and-parts/detail.page?DocID=PD024121
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 17, 2013 | Computers & Internet
8710w Battery recognize probleme
That sounds more like an alternator problem. If you have a multimeter start the car and check the voltage on the battery terminal it should be around 14Volts if it is getting to 15 Volts then the alternator is overcharging if it is 12.5 Volts then the battery is not getting enough charge and your alternator needs attention.
Jan 18, 2013 | HEWLETT-PACKARD Hewlett Packard 8710w - HP...
I have a VeriFone VX510 and it says "Bad RTC Chip
bad RTC can be repaired. the machine is equipped with multiple sensors inside. if one of them goes bad, or the Battery is dead tampering or bad RTC will show this can be fix by replacing the sensor and or the battery if you need this to be done call me @ (775) 358-2922 hope this help : - )
Nov 18, 2010 | VeriFone VX510
How do you reset the power on password on a Compaq 6720s laptop
Hi There,
If you're trying to describe the BIOS password, then this link is the best information website on the subject I've ever run across. Best of luck....
http://www.tech-faq.com/reset-bios-password.html
Aug 04, 2010 | Compaq Presario Notebook
Password was changed unknowingly by child.can't get in! Acer laptop
1~try to download service guide of your laptop.
2~learn how to reassemble the laptop.
3~ find the the location of RTC battery.
4~take the RTC battery off and wait 10 seconds.
5~put the RTC battery back to the RTC socket
NOTE:
1~BATTERY POSITIVE SIDE DOWN
Dec 23, 2009 | Acer Computers & Internet
Forgot password for Acer TravelMate 240
RTC battery inside somewhere to keep the password of your computer.
Try to find the RTC battery (acer almost used cr1220 ) and take it off from socket wait 10 seconds and put it back again .
You need to disassemble the unit ~take the keyboard and heatsink plate off ~you will see the RTC battery.
You may type cr1220 to search the picture of RTC battery on line easy.
Good luck.
Dec 22, 2009 | Acer TravelMate 240 Notebook
How to remove power on password on hp compaqnx6110?
You can try reseating the RTC battery:
http://h20464.www2.hp.com/index.html
Real-time clock battery removal Before you begin: Remove the battery and keyboard.
  1. Disconnect the RTC battery cable from the system board
  2. Use a small, flat-bladed, non-conductive tool to flip the RTC battery out of the socket on the top cover.
Real-time clock battery replacement
  1. With the positive (+) side facing up, insert and press the RTC battery into the socket on the top cover.
  2. Reconnect the RTC battery cable to the system board.
If this does not fix the issue, you may have to replace System board
Jul 06, 2009 | HP Compaq nx6110 Notebook
Hello, I┬┤woluld like to know where is the bios chip in a hp dv5-1000us. I need reset the bios chip after a unsuccesfully bios upgrade. thanx.
you cant reset the bios like that if you upgrade it wrong you need to get the chip replaced or flashed if it can be .it has to be done properly and professionally
Apr 13, 2009 | Computers & Internet
HP Hewlett-Packard Compaq 8710w Mobile Workstation Notebook Computer RM263UA PC Notebook Logo
18 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
