CD/DVD rom in laptop not working
Hello shefin, i have a lenovo g570 series laptop, my cd/dvd rom drive shows in computer but as soon as i insert a disc in it, it ejects out and displays the dialog box "Insert a disc." even when i insert in it, it does not spin or light up in the drive. please help to fix this problem.
    Top Expert:
  • Computers & ... Master
  • 37,979 Answers
The drive could be defective.
Posted on Dec 28, 2013
  • 97 Answers
SOURCE: toshiba satellite cd/dvd-rom
This has been a common windows issue. I'm sure that this will solve your problem. You can go to this link, http://tinyurl.com/toshibadvd, download the registry file and run it. After that, just restart your computer and it should be good to go.
If you're not sure and is worried about security since this is messing with the registry, you can just click on this microsoft link where it explains and gives you detailed instructions on how to manually edit the registry and fix the problem. http://support.microsoft.com/kb/929461.
This is typically the same thing, the first one is just a shortcut on how to do it. Just a reminder, EDIT THE REGISTRY AT YOUR OWN RISK!!!
Posted on Sep 16, 2008
  • 4 Answers
SOURCE: Error Code 47
Hello ,
As per the issue described by you Error Code 47 is described by Microsoft as given below ( as in the link http://support.microsoft.com/kb/310123 ) :
Code 47
Windows cannot use this hardware device because it has been prepared for safe removal, but it has not been removed from the computer. (Code 47) Recommended resolutions
Here are some things that you can try to resolve this problem.
Reconnect the device
This error code occurs only if you used the Safe Removal application to prepare the device for removal, or pressed a physical eject button.
Reconnect the device to your computer
Disconnect this device from the computer, and then connect it again.
Restart your computer
Make sure that the device is connected correctly to your computer, and then restart your computer. Click Start, click Shut Down, and then select Restart in the Shut Down Windows dialog box to restart the computer.
If it still does not help then definitely refer the notebook to the HP authorised service centre.
Regards ,
Puloma
Posted on Oct 16, 2008
SOURCE: Stiffy drive don't respond and DVD ROM spin but don't read CD
The laser carriage was stucked in one posistion, it works fine after I've manually release it.
Thanks
Posted on Jan 23, 2009
harry_qtech
  • 63 Answers
SOURCE: cd rom drive not able read data cd
First Go to control panel- System icon- Hardware Tab- Device manager
Expand the CD/DVD roms- Right click on your CD/DVD drive and Uninstall it.
Now download the utility from the following link and just run it on your system.
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
It will take a quick minute to run this utility.
After this restart your computer. It should work fine
Posted on Feb 04, 2009
md_ehsan_1
  • 255 Answers
SOURCE: Dell Studio 1537 DVD not working
1. clean your cd, then put
2. clean your cd/dvd head
3. scratch cd/dvd shows this type of message
Posted on Jun 28, 2009
DVD player not being recognized...
restar the computer HOLD the key CTRL +F2 OR ESC depend of the mark of your computer and go to restore factory default and fix it.
Of course pass the antivirus+antimalware+update the w.microsoft very important!
God bless you
Jun 23, 2013 | Lenovo G570 Notebook
Matshita dvd ram uj8b1as
Hi, my lenovo G570 laptop has a Matshita DVDRAM UJ8B1AS drive, it wont read any disc that is inserted,it starts to spin but nothing else. It doesn't show in My Computer either. Do i need to re- install the driver, if so where do i get it from?
Apr 02, 2012 | Lenovo INC 43344QU G570 Ip Pdc20 156...
CD/DVD driver not working
A few solutions:
1. Have you tried to clean your cd/dvd lens? Probably your lens is getting weak.
2. For advance user: Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
- Look for DVD/CD-ROM drives and delete the subkey.
- Restart your machine.
3. Let Microsoft FixIt help you:
http://support.microsoft.com/mats/cd_dvd_drive_problems/en-us
Worst case - Get a new CD/DVD-ROM for the replacement.
Don't forget to thumb up! ;) Good luck!
Feb 25, 2012 | Lenovo 3000 Y410 Laptop
My CD rom is not working
No matter what type of laptop you own or how you use it, the CD-ROM or DVD drive is an important part of the unit. With the CD or DVD drive in place, you can play your favorite music or watch your favorite movies, so when that CD or DVD player stops working it is important to get it back in service as soon as possible.
1.Locate the bypass hole on the CD-ROM drive. There is a very small hole, generally located underneath the eject button, on every CD-ROM drive. Unbend a paper clip and insert it into the hole until the CD tray pops out.
2.Remove any CD that is in the tray and replace it with a CD laser lens cleaner. These laser lens cleaners are available at computer shops and electronics retailers.
3.Run the laser lens cleaning program, then try to play a CD again. If that CD fails to play, replace it with another CD and try again.
4.Shut the computer down and remove the AC power cord if cleaning the laser lens does not resolve the issue. Turn the laptop upside down and slide the battery release lever to the unlocked position.
5.Remove the battery and set it aside. Then locate the screws that hold the CD-ROM drive in place and remove those screws. Slide the CD-ROM drive out of the bay, then slide it back into the bay until it snaps securely into place. Replace the screws that hold the drive in place, turn the laptop back on and try to read the CD again.
6.Log on to your computer and right click on the "My Computer" icon. Select "Properties" from the menu and click on the "Hardware" tab. Click the "Device Manager" button and expand the CD-ROM section. Right click on the CD-ROM and choose "Update Driver" from the menu to download and install the latest device driver from the CD-ROM manufacturer.
I hope you find it very helpful. Thank you for using fixya
Aug 18, 2011 | Lenovo 3000 Y410 Notebook
Why does my lenovo insist on my having a cd rom when i have a dvd writer installed? how do I fix it so that computer recoognizes it?
I have the same situation. My computer has a
DVD-RW/CD-RW installed yet when it is empty, the computer simply recognizes it as a CD drive. However, it will automatically recognize any DVD I place in the drive. Even a blank DVD-R. So it's not really a problem for me.
Also, if you type in DEVICE MANAGER in your windows search area, it will show you all your computer's hardware and peripherals. I have Windows Vista 64 bit and in device manager it does recognize it as an ATAPI DVD under "DVD/CD-ROM DRIVES".
I haven't seen a DVD burner yet that won't play or write cd's; maybe this is standard.
I wouldn't worry about it as long as it performs the functions (play/burn DVD's?)
Mar 14, 2010 | Lenovo 3000 J Series 2.10G Xpp PC Desktop
My lenovo 3000 j series shows I have a cd-rom instead of the dvd burner I have, so I can't burn anything, how do I change the computer over so it'll see it's a dvd burner, and not a cd-rom ?
Go to device manager and check the DVD rom drive has been detected. Also check you have installed the drivers for the same.
Revert back for more assistance.
Thank you for using Fixya.
Mar 14, 2010 | Lenovo 3000 J Series 1.80G VBE PC Desktop
Plz help me out with serious problem of cd/dvd drive
it looks like you need an update for your DVD driver (Optiarc drives )
use the lenovo support site to get the latest driver for your notebook,
http://lenovo.com/us/en/index.html
this should solve your issue.
Sep 06, 2009 | Lenovo 3000 Y410 Notebook
Cd rom drive not able read data cd
Feb 04, 2009 | Sony VAIO VGN-FS640W Notebook
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
