Quad core q6600 is working on acer eq35 mmotherboard
Hi i have bios version r01-c1. I have buy this procesor and i don t know its working.
    Problem Solver:
  • 5 Answers
Go to acers website and install the newest bios. If you did that already, you might have a ram issue. Why do you think it's the processor? What are the symptoms?
Posted on Dec 28, 2013
  • 2427 Answers
SOURCE: Acer t180 bios set up
hmm you might need to flash the bios or reset the bios follow these instructions.
TO RESET BIOS
1.) unplug the computer system
2.) remove the side panel
now you have two option
OPTION 1
3.) locate the jumper jp1 or jcmos1 you can use your manual for a refrence its a 3 pin jumper located cloase to the battery
4.) the jumper is currently on 1 and 2 , set it to 2 and 3 wait a few seconds and set it back to 1 and 2
5.) THATS IT BIOS PASSWORD RESET
6.) boot system enter setup and load optamised defaults.
7. save and exit setup
OPTION 2
incase you cant find the jumper
3.)remove memory
4.)remove the battery
5.)press the power button 5 times to empty any charged capicators
6.)replace battery and memory
7.)boot ystem enter bios load optimised defaults , save and exit
THATS IT BIOS RESET
Posted on Jan 10, 2008
teknowolf
  • 207 Answers
SOURCE: ACER 180 (AMD 64 3800+) upgrade
Any AMD Proc for an AM2 should work fine.
The BIOS should detect the proc's voltage requirement and set them appropriately.
The bios is a proprietary one for ACER and can't be updated to one allowing you to adjust CPU voltage manually, without voiding your warranty.
If you don't mind risking your warranty (For overclocking purposes) then you can find a BIOS to flash onto your MB from FOXXCON. Which is the Company that makes the board for ACER.
If you don't know how to do a 3rd party flash, you should probably do ALOT of research on it before risking your warranty on such a task.
Good luck
Hope this helps
Dave
Posted on Nov 06, 2008
VenkY3K
  • 118 Answers
SOURCE: Hi,
check compatabilty check online for your board chipset on the www.acer.com/support will find the solution for the upgrade cpu compatabilty, gudday !!
Posted on Mar 23, 2009
SmartAviator
  • 449 Answers
SOURCE: NO SPECIFICATIONS AT ALL!
Try use the diagnostics/system information utilities.
Posted on Jul 12, 2009
Kustom42
  • 56 Answers
SOURCE: NO SPECIFICATIONS AT ALL (Acer EM61SM/EM61PM)
I would recommend that you do in fact purchase a new motherboard, it is the heart of your computer and salvaging it from a prebuilt will not work out well for you, usually there is a restriction in the bios only allowing certain hardware to work with it.
As for the size, if you go with a decent case that is specified as ATX, it will work for this motherboard, it may be a micro ATX motherboard but an ATX case from someone such as Lian Li will work for both.
If you want some advice on a good computer build give us a price range, what you are trying to do on the computer, and whether or not you need a monitor, keyboard, or any other periphials.
You can also check out sites like hardforum.com or tomshardware.com they both have very active forums that have specific topics where people can post these requests to get advice from a bunch of different people.
I want to unlock the bios on MCP73PV R01-C1 and overclock the cpu !
That would take a bios flash you can brick it doing this. However the flash utility tool Acer uses should be on their website under support.
May 02, 2014 | Acer Computers & Internet
Intel E5800 wont work with Acer Veriton M460 SPECS BELOW
eric, Belarc will give you a comprehensive picture of your computer. GL
Jan 22, 2014 | Acer Veriton M460 Micro Tower Core 2 DUO...
Intel core 2 Quad Q6600 compatible with ECS P4M800PRO-M2
According to their website, no. The core 2 duo is supported, but not quad core. http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=674&CategoryID=1&MenuID=16&LanID=0
Look under the cpu tab.
Oct 31, 2012 | EliteGroup P4M800PRO-M2 (V2.0) Motherboard
I cannot install a quad core 8400 2.66 mhz processor to my MSI 965 Neo F V2 motherboard
The following Core 2 Quad processors are supported by your board: (each with a special BIOS version)
SL9UM Q6600 @ 2.4 GHz
SLACR Q6600 @ 2.4
SLACQ Q6700 @ 2.66
SLAWE Q9300 @ 2.5
SLAWR Q9450 @ 2.66
SLAWQ Q9550 @ 2.83
Your 8400 is not on the CPU supported models list.
Jan 17, 2010 | Computers & Internet
The processor speed was change every turn off my pc... 2.4ghz it will be 1.20ghz... i have a quadcore Q6600!.. how can i fix this problem!
go in the bios and set the speed for 2.4 ghz then click F10(save and exit) and you save the set speed should work .
Dec 03, 2009 | Intel Core 2 Quad Q6600, 2.40 GHz...
E8400 or Q6600
personally i have the q6600 which is a quad core processor, all the others you listed were dual core, personally i use alot of programs all at once which is good if you have a quad core, but just for general music, data, and streaming, the e8400 is probably better for you, its a 3ghz processor.
Mar 20, 2009 | Intel Core 2 Duo E8400 LGA775 3.00GHz 6MB...
Computers & Internet Logo
David Payne
David Payne
