Question about Kodak EasyShare M530 Digital Camera
How does a USB connector work - Kodak EasyShare M530 Digital Camera
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 127 Answers
If you have the right lead the small connector should plug into the camera (the socket might be behind a door or flap) and the large connector into the PC or laptop. When the camera is on the PC should 'see' it and open up a file window rather like the ones you normally see for files. You can then drag and drop the picture files where you want them. When you have finished REFORMAT YOUR MEMORY CARD in the camera. I cannot overemphasise this.
Posted on Dec 28, 2013
Number,one,three,five seven and zero not working and back space aswell
Is your keyboard connected via USB (a flat rectangular connector), PS/2 (A round connector, often it is purple), or AT connector (a round connector that is roughly twice the size as the PS/2 port for your mouse)? More than likely, it's connected via USB. Especially if it was bought within the last five or six years. If it is a USB keyboard, try plugging it into a different USB port and see if that helps. If that doesn't help then most likely the cord on your keyboard is damaged (kind of like when you have a pair of headphones that will only sound on one ear unless you jiggle the wire). If it's not the USB port (or you have a PS/2 keyboard) I would recommend you buy a new one. You can get one for as cheap as $10.
USB Connector: crasher35_6.jpg
PS/2 Connector: crasher35_7.jpg
AT Connector: crasher35_8.jpg
May 29, 2011 | Computers & Internet
I have windows server 2003 professional edition installated.Cannot access seagate external hadrdrive
If you were able to access it before and the drive powers up when you turn it on, the most likely cause is that the USB connector is broken. If your drive came with a Firewire adapter and you have a firewire connector for your computer. Then swap the usb with firewire interface and confirm that the drive is still working. If it works then the USB adapter is broken. The second alternative is to try the eSATA connector if you have an eSata interface on your computer get a cable and check that the drive works. Third way to check is to puchase an eSata adapter the allows you to plug the eSata to the usb port on the computer. Forth is to try and open the usb module and solder the usb connector back on. Fifth is to try tearing open the drive case (difficult but not impossible) and put the drive into a different case (purchase at Best Buy, Staples, online, etc)
Sep 15, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
USB Keyboard and mouse wont work with PS2 KVM with adapter
Have you tried rebooting once it is connected? Not sure if it makes a difference, but I know you can not hook up PS2 peripherals without rebooting.
Nov 03, 2009 | Dell OptiPlex GX280 PC Desktop
The USB casing is off the USB connector... does that mean it is broken?
The casing is certainly broken but you need to test USB connector to see if it still works. Plug the USB connector into the computer and see if it's working. If it is then all you have to do is tape up where the case has broken with electrical tape.
Regards
Sep 15, 2009 | Logitech Cordless Mouse
Front panel connectors/jacks is not working
OK--usually what you will find from the front is 3 connectors.
One will be a solid block that has one blank hole which is the key. That will plug into the corresponding pins on the motherboard--usually toward the back of the case.
There will be another other wire that terminates in two plastic connectors. These are the USB connectors. Sometimes the connectors are in two parts. One is a 3-hole and one is a 1-hole. Usually you will find two sets as they sort of go together.
The pin configuration on the motherboard looks like this ::::.
The single pin on the end is not used. The other ones are connected with the plastic connector on the first three starting at the left, with the end marked VCC to the left. The fourth pin is the ground which is usually the separate connector.
The second USB connectors are plugged in right next to the first--so each block of pins controls 2 USB ports.
Hope this helps.
May 14, 2009 | ASUS Computers & Internet
How does a external USB SATA drive dock
yes you can but whether that would make it work or not is a different story.
It depends if the hard drive is still working or not however it would test for certain whether it is working or not.
Apr 14, 2009 | Fantom Titanium II (TFD500C16) 500 GB USB...
Activating COT2 wireless mouse
Your ACME COT2 wireless mouse must have come in two pieces, the USB connector the mouse itself.
Insert the USB connector of your wireless mouse to your Toshiba Satellite and press simultaneously the button in your USB connector and the button in the wireless mouse. This is done in order to pair the mouse to the USB connector.
Jan 05, 2009 | Computers & Internet
My wireless mice's usb doesn't work?
Your wireless mouse must have come in two pieces, the USB connector the mouse itself.
Insert the USB connector of your wireless mouse to your laptop and press simultaneously the button in your USB connector and the button in the wireless mouse. This is done in order to pair the mouse to the USB connector.
Jan 05, 2009 | Targus AMW05US Mouse
My mouse doesn't move but keyboard works.
What type of mouse do you use? USB or PS2 connector mouse.? If you're using usb connector mouse, change it to PS2 connector mouse. Start your pc/laptop. When you're in the OS, plug out the PS2 mouse and then plug in the usb connector mouse. Restart you pc/laptop. Is it ok now?
Sep 20, 2008 | Computers & Internet
Speedstream 5200 modem
Open the following link --
speedstream 5200
Download the manual from the link and review page 7 for ethernet connection.
Notice particularly the back of the device. There are four connection points to plug things in the one on the left with DSL is where cable with the phone connectors connects the phone jack to the speedstream 5200. On the right the round connector with the pin is where the power goes. Next to the power connector to the left is a USB connector. In between usb connector and the DSL port is an ethernet connector. One way to avoid the need for the USB software os to use the ethernet connector bu connecting an ethenet cable (wider connector that fits snugly in both ports one on the Speadstream 5200 and the other probably present on your computer.
USB driver including VISTA (if you prefer)
USB driver link
Dec 11, 2007 | Efficient Networks SpeedStream 5200 Modem
Kodak EasyShare M530 Digital Camera Logo
14 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
