Question about Inova T4 Flashlight
My flashlight just stopped working. when placed on charger, the green charged light appears. How do I know if its a battery or bulb problem?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
It's telling you the battery is fully charged so suspect that either the battery is dead or the bulb is burnt out. Get a test meter and test for voltage at the battery. If yes, then the bulb is burnt. If no voltage then obviously the battery is bad
Posted on Dec 29, 2013
I am getting a flashing green light when I try to charge my batteries on the Pronto M51 what does this mean
why did you change the batteries, did you verify that it wasn't the charger in the first place, sometime the charger will appear to charge but actually isn't. put a meter on one battery then plug in charger if voltage goes up charger is good if not look for loose connections and or bad charger.
Sep 25, 2012 | Invacare Pronto M51 Power Wheelchair
Tried to charge my Coleman Retro Lantern, the red light for charging is on but after 24hrs charging, I take the charger off and try to turn the lantern on, it wont work. How can I fix this...
I just bought a retro rechargeable sealed battery,recently. I charged it for 18 hours,the lights all worked,but I don't remember the green light comming on.i put the lantern away for 3 months or so.i decided to check the the battery light out first week of june, the light was there,then I said let me charge it up again, I never seen any green light come on showing it was fully charged. I took the battery out and checked the wires to see if there was a break. None that I could tell. After you take the battery out ,there is another section square that covers where the bulb is located,but I didn't touch that part yet. Stuck" on this one. Help"
Sep 15, 2011 | Coleman Retro Rechargeable Battery Powered...
Charger light does not come on
The red light indicates the batteries are charging and green indicates the charging is complete.
Jun 12, 2010 | Stinger Streamlight 75000
Recharging - indicator lights when complete
When the green light stays on that means the battery is fully charged. The correct charger for that light is a Class 2 Transformer
Model: KA12D120030042U It has a output of 12VDC at 300 mA
May 29, 2010 | Vector 2M Pwr Rch Spotlight
Stinger xt malfunction
If the charger indicator works i would buy the battery and the bulb and replace them at the same time, as you don't know the exact condition of either. Say you bought the battery and it worked fine for a week or so and the life of the bulb ran out ?. Tricky buys on e-bay.........
GGBMDB
Nov 19, 2008 | Stinger Streamlight 75000
Rechargeable mag light not working .
when you dropped it you probably knocked the contacts inside out of place. or you broke a soldered connection. if you can take it apart you can most likely fix this yourself. when you remove the front lens assembly there is a retaining clip that you need to remove so you can take the guts out.....please rate this
Sep 02, 2008 | MagLite - Mag Charger System 110v (M)...
My Vector Vec157 Flashlight won't Charge...
It is the battery, I have a similiar Vector light for a few years and tried re-charging the battery but only the little LED light would come on. I have another Vector light, same model and switched batteries from the worjking one to the non-working one and now it works fine.
I then proceeded to purchase a new battery for the non'working one and when I arrived home I installed it and turned on the main light, still won't turn on, I tried the LED's, they work. I figured maybe the new battery needs a good charge so I plugged the charger in and charged the light for 12 hours, still no main light.
I guess the new battery is defective, so now I will return it and exchange it for another one.
Aug 22, 2008 | Vector 20 Million Power Series Spotlight
Wii charger not charging
problem is either one battery is discharged and the other is full or corrosion on battery terminal tops or batteries are defective. the red lights flash when the unit sences that the batteries have a problem with the induction charge. simple test is to using a meter measure the batteries or discharge the unit with a wire and a 2.2 volt bulb (flashlight bulb) once discharged, unplug the charger unit for over 10 secs to reset it. then plug it in and try the batteries in the packs again. if still inop then they are done for.
Aug 15, 2008 | Nintendo Wii Console
Rechargable Batteries Battery Charger
When batteries are placed into the charge mode, the red light will come on.
When fully charged, on those units with a green light, the green light will be an indication that your batteries are charged and if your unit has no green light, the fully charged indication will be when the red light turns iff.
Apr 24, 2008 | Universal Battery Charger Charges Multiple...
Inova T4 Flashlight Logo
334 people viewed this question
Top Inova Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you an Inova Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
