S10 troubleshooting chevy 1994, runs, but no power, then cuts out..!
    Prodigy:
    An expert who has answered 500 questions.
  • Computers & ... Expert
  • 510 Answers
Take this question to the correct category, if it exists, this is for PC/laptops !!!
Posted on Jun 27, 2014
What would cause you to lose fuel pressure while driving.
Chevrolet S-10 Questions - Fuel System Loses Pressure ...
www.cargurus.com > Questions > Chevrolet > S-10
CarGurusJul 28, 2012 - Fuel System Loses Pressure - I have a 2003 Chevy S-10 Pick Up with the 4 ... car a few times, what essentially you are doing is priming the fuel pressure. ... A dirty fuel filter will not cause the lines to lose pressure after the engine is shut off. ... I have a 98 s10 2.2 liter and it was driving fine all day then when ...
Chevrolet S-10 Questions - My 2001 S10 has a hard starting ...
CarGurusSep 16, 2012 - My 2001 S10 has a hard starting problem if the truck sits between 1 ... Vacuum leak, have you checked fuel pressure while it sits? ... Would the spider alsocause a misfire at low rpms? .... at an idle, or squeaking while driving and it gets faster as you go? ..... 1994 Chevrolet S-10 2 Dr STD Standard Cab LB.
Chevy S-10 Won't Start - Repalced Fuel Pump and Pressure ...
www.cartruckinfo.com/chevy-s10-wont-start.html
Chevrolet S-10 pickup won't run and has no fire unless I jumper the fuel pump relay. ... Once the truck starts and is running you can remove the jumper to the fuel pump ... Iwould get the fuel pressure checked to start with, because that's where the ... 93 gmc 4.3l FI runs but dies out loss of power after 5 mins of running then ...
Stalling S10: I Have a 1994 Chevy S10 2.2l It Stalls After 35 ...
Dec 10, 2015 | 1994 Chevrolet S-10
1994 Chevy s10 has no power and dies after a few minutes of running why?
need to run codes on it sound like egr valve stuck closed
Mar 03, 2014 | Cars & Trucks
Where is location the fuel pump relay in my chevy s10 1994
Depends on your engine size. The first picture is for the location on the 4 cylinder engine and the second is for the 6. Hope this helps....
Apr 01, 2012 | Cars & Trucks
Trying to wire a 1994 lt1 into 1996 chevy s-10
It should be a plug and play if your using the ECM for the 1994 engine. The ECM on the 1996 S10 will no work on the LT1 engine, for one thing the S10 ECM will only command for 6 fuel injectors and will have different injection pulse and so on. The program of the S10 ECM is made for the Vortec as to the LT1 will have different parameter **** as engine running temperature, vacuum readings, and timing.
The most obvious would be the 1994 LT1 runs on a OBDI system and the 1996 is running on a OBDII system. You can still run the 1994 LT1 from a 1994 with a OBDii system ecm, but some of the sensors will need to be upgraded to accommodate for the proper readings the OBDII system will need to have the engine to run right.
If you don't have the right ECM for the LT1, go to the wrecker's and locate one, Caprice, Camero, Firebird ECT.....
Thank you for using fixya and good luck on your project.
Apr 09, 2010 | 1996 Chevrolet S-10 Pickup
Need a wiring diagram for a chevy s10. brake
your power starts at the brake light fuse,check with a test light,then proceed to stop light switch on brake pedal under dash,one wire will be hot when when you check it with your test light, the other won't be until you press down the brake pedal then the power flows through to the second wire,if no power to second wire replace switch,if you have power remove tail light bulbs and check for power in side socket.
Nov 24, 2009 | 1997 Chevrolet S-10 Pickup
1994 chevy s10 .. moter swapped to carburated and
Actually, I recommend putting an after-market ratchet shifter on the transmission. This sounds weird, but we purposely cut the TPS out of my TH350 for street / strip racing. A ratchet B&M shifter or something similar will work, but it makes destination driving (I.E groceries, family, etc) a bit more of a pain.
Nov 06, 2009 | 1994 Chevrolet S-10
1994 chevy s10 fuel problem
If you having fuel flow problem, 1st check the fuel pump make sure is has a good pressure, 2nd check the crank sensors, 3rd common problems on 2.2l injectors which it has only one can be faulty or clog. 4th check fuel regulator, if the regulator is bad it wont keep the pressure build up and lock allowing the injector to work correctly. if your fuel pump is good, your crank sensor may also be going bad, what crank sensor does it it sense the flywheel turning and it send single to ECU (computer) telling it to turn on the pump and keep it running as long as the flywheel keep turning. If pump, crank sensor,regulator and injector are good, my next guess is to have your ECU bench tested. if you have to replace ECU, get it from the junk yard.
Sep 12, 2009 | 1994 Chevrolet S-10
Needing 94 s-10 pickup 4wd vacuum diagram
i would try putting a c-clamp on the vacuum actuator on the fenderwell and see if the 4wd engages. they go bad alot. Good Luck
Mar 12, 2009 | 1994 Chevrolet S-10
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
