Question about Ricoh Office Equipment & Supplies
Aficio 3545 first tray auto feed
When the machine working it force get sheets from the first tray although when it worming :( so i let empty the first tray in order to avoid jam
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 90 Answers
Set to factory default setting
Posted on Dec 29, 2013
Orbixx
  • 133 Answers
SOURCE: automatic Paper feed
Check the feeder roller inside the printer for any foreign substance stuck to the roller, this may cause it not to grip properly. You can also try a few sheets at a time and make sure the paper tray is gripping the paper, but not too hard. If this fails, the roller may be out of place somewhat, try to reposition it. Let me know how you get on.
Posted on Sep 06, 2007
SOURCE: Brother MFC 7420 Paper Jam
After changing the drum, toner and running around town for days trying to find a reliable place to get this printer repaired, I realized I was spending a lot more money than what the printer actually costs. the drum was over $100, toner was $80, and the printer is $250. I bought a new one, and I can now use the old one for parts.
Posted on Jan 16, 2008
jyvibar
  • 148 Answers
SOURCE: paper feed/jamming problem
suggest you bring your orinter to the nearest authorised repair center. There might be parts to be replace
Posted on Mar 23, 2008
Joed911
  • 4338 Answers
SOURCE: HP paper jam
That is usually caused by the paper feed rollers being cover with paper dust. Take a clean cotton pad and alcohol and clean the rollers :turninig each roller as you clean it. if it has a rear dor, open it to get better access to the rollers.
Please remember to rate all users who assist you for free :)
Posted on Oct 01, 2008
Ajkill
  • 2035 Answers
SOURCE: label sheets won't feed, jam
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
good luck..
Posted on Dec 22, 2008
How to change feed roller on RICOH Aficio SP C242DN ?
1. remove all the cartridges.
2. remove the waste toner bottle.
3. rear cover
4. left cover
5. paper feed clutch
6. close the top cover and front door.
7. pull out the tray.
8. stand machine with the rear side facing the table.
9. slide the paper feed shaft to the left side.
10. remove the paper feed roller.
Jul 09, 2014 | Ricoh Corp Aficio SP C231N Laser Printer
What does fault 072-210 mean? how to fix it?
An error occurred when using Tray 2. Turn the machine off and on. Most likely worn feed rollers, causing a "Ghost Jam" try replacing the feed rollers in the tray, and try again.
Jun 05, 2014 | Xerox Workcentre 5225 / Copier, With...
Continuous jam paper feed cl3500n
I THINK THE NUMBERS BUTTON HAD PROBLEM, TRY TO CHANGE THE NUMBERS BOARD & SEE IF THE PATTERN STILL PERSIST. IF THE PATTERN PERSIST ALTHOUGH YOU INSERTED NEW NUMBER BOARD, THEN YOU HAS TO GO IN SP MODE TO CHANGE PRINT SETTING
Sep 26, 2013 | Ricoh Aficio SP-C210SF Printer
Copier keeps giving paper jam on A4 sheet feed although no paper is jammed. A3 Feed is no problem. Is tthere sensors that need cleaning etc??
please pull the tray out and check machine properly .may be there is any small piece of paper .remove it check machine from inside and fuser unit also..if the problem stills check all sensors by manually moving and cleaning ..problem will be solved
MIAN JEE
Sep 24, 2011 | Canon iR 2022 Printer
My machine aficio 2045e give error toner signal even though toner in bottle is more than50% i make every thing but still appear add toner
Inside the toner feed mechanism there is little plastic fins that tend to break off. You will probably have to replace the hopper unit (The unit that the toner tube sits in) or in that unit where the tube opening sites you can either replace the feed chuck or if your handy maybe repair the feed fins. The chuck part pops out with plastic tabs.
Sep 14, 2011 | RICOH RICOH AFICIO SP C820DNT2 40 PPM...
Paper does not feed into lexmark X5470 all in one printer
feeding problems
not take apaper
not feed a paper
hey im tuval from israel,
first of all im sorry about my english :)
and now to the point.......
look, if you know where the feeding wheel its good (like elastic material over this wheel) , now take a"nail cleaner" (aceton)
and clean this wheel (the elastic thing), i did thet and the problem is gone!!!
after the cleanning send 15-20 empty doc to print (remember - empty, dont use you ink - you dont have to - save money), if all the paper is out from the printer,
you fix that.
i hope i help you.
tuval.
vaadk3@netvision.net.il
hope fore replay.... :)
May 18, 2009 | Lexmark X5470 All-In-One InkJet Printer
Ricoh AP3800C "Output tray full"
Check the little black piece of plastic that senses the printed page exiting the machine. Our sensor was stuck and I was getting the same message (an similar Ricoh product). When I gently reset the black piece to center, moving freely, printing worked again. I think the sensor got jammed up when we were trying to remove a bad paper misfeed.
Ricoh manuals very confusing on this error message. They refer to standard tray, tray one, etc. without being clear whether it's a paper feed tray or the so-called "standard OUTPUT tray." The output is not really a tray, it's just the depression where your sheet lands after printing. I wrenched on the paper feed trays and their settings for an hour before I figured out they meant OUTPUT.
Feb 27, 2009 | Ricoh Aficio AP3800C Laser Printer
Lower tray won't work
check your printer properties box to make sure the paper source tray box is set to auto select, also in order to "program" auto select in the printer menu you need to select the enter key and then the "aito select" should then have an asterik next to it, meaning that the "auto select" is now the default.
http://www.websitetoolbox.com/mb/copierquestions
Jan 21, 2009 | Ricoh Aficio SP C410DN Laser Printer
Paper feed issues
The problem is what you already stated, the rollers are too smooth so they are not grabbing the paper to feed it.
Try this : clean with alcohol and a clean cloth very well and make a copy it will probably make one or two then jam.
order the tires and replace. should cost you about $20
Nov 06, 2007 | Office Equipment & Supplies
32 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
