Question about Vtech Kidizoom Digital Camera
Kidizoom twist plus White screen
Brand new, switched on, just a White screen?
This camera just stopped working. refuses to switch on and unfortunately we stay in Cape Town South Africa and no one knows how to even repair it... HELP!!!!!
If the battery is definitely good and camera refuses to work and you cannot find anyone to repair, only alternative is to replace. Actually, those things are a PIA to repair and very expensive to do so, and getting a new one is really the most cost effective way to handle the situation. If it were a three thousand dollar camera then things would be different.
Sep 07, 2015 | Vtech Kidizoom Plus PINK and Blue digital...
MY CAMERA DID NOT COME WITH AN USB CORD. WHAT SIZE AND WHERE CAN I PURCHASE ONE
USB Connection Cable for V tech Cameras"
Brand New Cable
Fully Comp with 2.0, 1.0 and 1.1
USB 2.0 - 1.1 Backwards Compatible
Data transfer speeds up to 480Mbps
Oct 16, 2011 | Vtech Kidizoom Digital Camera
What type of memory card can i use for my vtech camera
The Kidizoom camera uses SD cards, which max out at 2GB in size. The Kidizoom Plus will take SD cards up to 2GB and SDHC cards up to 16GB. The brand won't make any significant difference. Neither will speed, so don't bother paying more for faster cards.
Mar 21, 2011 | Vtech Kidizoom Digital Camera
110 line in to light switch. How do you continue 110 line out to other oulets or switches?
Add another line to 120V switch.
To begin, inside your switch box, there must be at least two cables.
Each cable has a black-wire and white-wire and bare ground wire.
If your box has only one cable, then you cannot use that for your junction.
OK, your box has 2 cables.
One cable comes from circuit breaker box. These are called Line wires. There is a Black Hot and White Neutral.
The other cable goes to light. These are called Load wires.
You are going to add a new cable with a black-wire and white-wire
In back of box, the white wires are twisted together and covered with wire nut.
These white wires are called Neutrals.
Add your new white wire to these other white wires.
The switch has 2 black wires. One black wire is the Hot line wire.
Add your new black wire to the switch screw that has the Hot.
Of course the switch has 2 black wires, so how do you know which is the Hot.
Turn light switch off, turn power ON, and test each black wire to bare ground wire.
Tester lights up on the Hot.
Review:
New white wire connects to other white wires that are twisted together and covered with wire nut.
New black wire connects to Hot wire.
Ground wires are connected together.
On your new receptacle, the black wire connects to brass screw, and white wire connects to silver screw.
Screws are color-coded to tell electrician how to wire.
http://waterheatertimer.org/Color-codewire.html
http://waterheatertimer.org/B220C.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
Mar 08, 2011 | Leviton 5634 Dual 1 Pole Switch Decora...
How do you wire a 3-wire timer switch (white, black, red) to replace a single light switch to a front door light?
You have a 3 wire in-wall timer.
Colors red black white
You are replacing single pole switch that has 2 wires (plus ground, we'll ignore ground for now)
So switch has 2 wires:
1 switch wire goes to Load/lights > this wire connects to timer red wire
1 switch wire is Hot from breaker > this wire connects to timer black wire
When finished, if lights do not turn on, then reverse red and black wires.
Timer white wire powers clock inside timer.
To complete circuit to clock, white wire is connected to neutral wires.
Located in back of electric box are white wires twisted together and covered with wire nut.
These wires are neutral, connect timer white wire to these wires.
If box does not have neutral wires described above, connect timer white to bare ground wire.
Add a comment any time
Dec 10, 2010 | Hardware & Accessories
New switch GE model 15265 ... to light up 2 lightbulbs outside. Old switch all cables are black. Those who light up the tester are the hot=Red/black?? Those which do not light up are white?? Green I know...
Manual for GE 15265
http://waterheatertimer.org/pdf/GE-15265-manual.pdf
15A timer works fine on two bulbs, up to 1440 total watts.
If old switch has 2 screws plus green ground screw, then timer is right.
If old switch has 3 screws plus green ground screw, 15265 doesn't replace 3-way switch.
Timer-green wire connects to bare ground wire
Old switch has 2 screws with wires on each.
One wire is Hot-from breaker and this connects to timer-black wire.
One wire Goes-to-lights and this connects to timer-red wire.
If you get these two wires reversed, timer will not work, so reverse them.
It will not blow circuit if the timer-red and timer-black wires are reversed.
Timer-White wire is the confusing wire for everybody:
Timer-white wire runs clock motor located inside timer.
In back of electric box are neutral white wires that are twisted together and covered with wire nut.
Connect timer-white to these neutral wires.
If box does not have neutral white wires, connect timer-white to bare ground wire.
Nov 13, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
Vtech kidizoom camera will just freeze while you are operating. Somewhere I read, if you hit the reset button, it will then work. This is true, but the camera freezes multiple times an hour. I then have to...
hi i got a kidizoom for my daughter. i am trying to upload music from itunes it seems to go on but when i switch on the camera i can't find it anywhere. what am i doing wrong?
Dec 31, 2009 | Vtech Kidizoom Digital Camera
Powers on/off, but all other buttons won't work
exact same problem here. I called the Vtech and they will replace it.
Sep 06, 2009 | Vtech Kidizoom Digital Camera
Vtech Kidizoom Digital Camera Logo
138 people viewed this question
Top Vtech Cameras Experts
Tony
brian soufane
Are you a Vtech Camera Expert? Answer questions, earn points and help others
