Question about Tascam Cd-rw900sl Cd Recorder/player
Player fails to read or write
Disc spins for several seconds. "disc failure" appears on screen. disc is then ejected.
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 231 Answers
Try a different disc.
Posted on Jun 06, 2015
CD player rotates but wont play or read disc.
Cd spins but player can not play - ecoustics.com
www.ecoustics.com > Forum > Home Audio Forum > Mini Systems Forum
Oct 30, 2003 - Cd spins once system is on but player can not read discs. ... Traywon't eject. ... I have a Memorex 2Extreme CD player, and I insert the disk, and pushplay, and the CD acts like it's searching for awhile and then the screen ... Dvd player won't read any CDs (but use to ) - eCoustics.com
Sep 22, 2005
Cd makes clicking noise and I get Disc Read Error PLZ HELP ...
Dec 24, 2004
CD Player screen reads no disc - ecoustics.com
May 30, 2004
More results from www.ecoustics.com
How to fix a boombox CD player when it wont play - YouTube
? 5:15
https://www.youtube.com/watch?v=pH33UZveLYI
Jun 24, 2013 - Uploaded by Shyzah
How to fix a boombox CD player when it wont play .... My box reads "no disc", but it is in proper position ...
Dec 22, 2015 | Audio Players & Recorders
Pioneer cdj 400 unit turns on, takes cd, cd spins and then just ejects it.
There are two reasons for this fault. The first one is with its disc loading mechanism. If the mechanism do not place the disc properly on to the reading chasis, this fault can be. It will spin for some time and will ejected automatically
The second one is with its optical pickup unit. If optical pickup unit do not read the disc; due to some fault to it [dust or dirt over the optical lens]. But in this case, there will be only "No Disc" display will be there. No automatic ejection will take place.
With your player, the first sated might be the case. The disc loading mechanism might need replacement.
May 29, 2012 | Pioneer Audio Players & Recorders
Blue Ray player model BD HP-20 locked
Turn off the power.
Press and HOLD the eject button.
While holding the eject button, turn it on.
This works with most players, but may not work with all.
Nov 20, 2017 | Sharp Aquos BDHP50 Blu-Ray Player
Open/close tray disc stuck bose Lifestyle 48
Problem:
I also have a bose Lifestyle 48, and the same problem has happen to me where the DVD player would not open,
Solution:
Unplug the unit, Wait a few seconds, after plugging the power back in, immediately hit eject so that the player does not have time to spin up and try to read the disc again
Feb 17, 2009 | Bose Lifestyle 48 System
DVD player will not read any disc
The motor is on its way out - the H02 code indicates motor failure as in it cannot spin the disc. You can sometimes fix it but for how long is anyone's guess. Disconnect from the power, remove the three rear screws and two screws on each side (total 7) and lift off the outer cover. Now if you carefully reconnect the power BE VER YCAREFULLY NOT TO TOUCH ANY PARTS INSIDE THE CASE and put a DVD disc in as per normal, you'll will see that when the tray closes, the upper platen (a honeycomb disc) that sandwiches the DVD to the lower platen does not spin - it should. Give a gentle spin clockwise and it should spin up and the DVD will play. You may need to restart if you missed your chance first time. If you switch off and on, eject and close the tray, the spin should happen as normal. If it doesn't, your motor is knacked and not an economical repair. Buy a new player. If it spins time and time again, you may well have temporarily fixed it for a while.
Jun 17, 2008 | Panasonic DVD-RV31 DVD Player
DVD stopped playing all DVDs
Reset you player by doing the following:
With the player on, hooked properly to your television, and on the correct station:
Open the tray
Close the tray (with no DVD inserted)
Hold the stop button down for a full 5 seconds
The CyberHome screen should appear. You should be able to play your dvd's now.
Feb 20, 2008 | Cyberhome CH-DVD 300 DVD Player
Dont know what to do
Probably not much help. but the 1st thing I would do is check to see if the disc is even turning...put it in with label straight up, then when it fails, eject...odds are severely against the disc being oriented the same way if it spins, so if it hasn't moved, the main drive motor is bound up or dead. Either way, return it.
Dec 29, 2007 | Coby DVD-233 DVD Player
Tascam Cd-rw900sl Cd Recorder/player Logo
414 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
