Question about Hotpoint RGB745 Gas Kitchen Range
Heating element the lower heating element in our hotpoint stove is not working. had it tested at a repair shop and was told it is ok. changed the fuses and still not working. Any suggestions?
  • 1 more comment
  • prego Oct 18, 2007
    • the model # KE737NW-1
     The correct model #KE737MW-1. Serial # FL158892 Also it ia an electrric stove not gas. Getting this info over the phone from son. Sorry about that.
  • zrno Dec 17, 2007
    My wife turned on oven knob and than left oven door open.After that the lower heating in our Hotpoint stove is not working.
    The model # RGB745WEA2WW
    Serial # HV237178P
Hot Point Gas Range Model RGB745WEV3WW
Oven does not work properly, will heat to about 200 dergrees, no higher. On rare occaions it will heat properly perhaps for 2 or 3 days, then same heating problem starts again
Posted on Dec 16, 2007
  • 473 Answers
Give me the complete model # from the sticker on the range so I can assist you.
Posted on Oct 18, 2007
  • Craig Shelton
    Craig Shelton Oct 18, 2007
    I'm sorry but I am not having any luck with that model #.  Make sure that isn't the serial #.  If so then try to explain to me the type of controls you have.  Not sure if you can send a picture thru this site or not.
2 hobs on my electric cooker are not working
Fixing Electric Stove Burners that Don't Heat Up Properly ...
? 2:34
www.youtube.com/watch?v=GfqaPcha__o
Jul 2, 2012 - Uploaded by SamuraiRepairman
Fixing Electric Stove Burners that Don't Heat Up Properly ... Coil Surface Element Test - Electric Stove Repair - Duration: 2:04. by... Temporary Repair For Electric Plug In Range Stove Surface Element Burner Not Working ...
Electric Range Stove Repair: How To Repair Burner ...
? 6:52
www.youtube.com/watch?v=ndQU7RtqfRw
Jan 31, 2012 - Uploaded by applianceassistant
How to Fix Electric Stove Burner Elements That Won't Turn On Or Won't Turn Off. ... More Range and Stove Troubleshooting, Repair Help, And ... Fixing Electric Stove Burners that Don't Heat Up Properly - Duration: 2:34. by ...
Oct 26, 2015 | Ovens
Hotpoint aquarius ctd40
Hi the problem could really be either but its going to be more than likely the temp sensor failing you will need to test this to see if it is working they can be replaced relitively cheap but depending on the age or dryer its wether anything else is going to go wrong as well but this all depends on the age let me know ok
Feb 11, 2008 | Dryers
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
Had foolishly tried to remove baking element w/ oven turned off but still plugged in / breakers still on (all to make cleaning easier-ha!) unscrewed element beleiving it was modular like stovetop elements....
Some times s**t happens. The most likely situation is the wire connections that connect the heater have burnt off, or simply just become disconnected.
the normal repair or replacement to the lower heater element would be to disconnect the wires from the heating element by sliding the wire off of the spade connector. Some times they are connected by a screw and nut terminal. Next to remove the screws from inside the oven, and then pull the element out from the back wall. I can see how you could easily interpret that they would slide out like many stove top elements.
In your situation confirm that power is off.
Remove back panel and check terminal' connections to the heating element. repair.
Model ra520w3 HOTPOINT ELECTRIC RANGE Parts
maxresdefault-es3dyrcoa4nhevk3e5ork442-3-5.jpg Hope this helps?
Jun 21, 2017 | Hotpoint RA520 Electric Kitchen Range
Hotpoint RB747GJ electric stove. Extremely long preheat cycle
I went to one of my local appliance sales/service dealers and asked the question. They said it sounded like the baking element was starting to go, but would need to test it. They gave me the option of a service call or if I was handy and comfortable working with it, told me to cut the power at the circuit breaker and then remove the screws holding the element in place and bring it in to have the continuity tested. If the element tested bad, I would get a replacement element. When I removed the element, there was only one wire attached. The baking element tested fine and all I had to do was replace the broken wire connector. I had broken the wire connector when I lifted the element up to clean out the ash residue from the cleaning. it was easy to determine which wire went there since it was missing the connector. Total repair was less than $2 !
Dec 01, 2009 | Hotpoint RB757 Electric Kitchen Range
Hotpoint tdl52 no heat, element changed, but still will not heat
Check your all fuses that are suppose to protect your element. should have a high and low limit fuse
Aug 23, 2009 | Dryers
GE Evolution stove/oven. My oven is not working,
remove heating element an check with ohm meter. pretty simple really.
Jun 12, 2009 | GE Ovens
Stove top burners and lower baking element not heating up
If all the elements are dead, check for blown fuses/tripped circuit breakers. There may be some in the range unit itself in addition to your electrical service panel. If one element is completely dead on all heat settings, the control is probably bad or there is a broken wire. If it is stuck on high for all control settings or is erratic, the control is bad - replacements are readily available and easily installed.
On ranges with push button heat selection, a pair of heating elements are switched in various combinations across 120 and/or 240. If some heat settings do not work, the most likely cause is that one of the heatings elements is burnt out although a bad switch is also possible. Kill power to the range and test the heating elements for continuity with resistance meter or multimeter.
For the lower baking element:
Again, check for blown fuses in the oven or tripped circuit breakers. The remove any wiring to the bottom element and test for resistance. If you get no reading (or a very high resistance) then your element is dead.
May 09, 2009 | Kitchen Ranges
Drying Problems with a Hotpoint CTD00
There is a thermal fuse at the back that you must check. The thermal fuse can be tested using a multimeter.
If the fuse is ok, then check the heating element , the temp probe, wiring harness to heating element and temp sensor, and if there is nothing in there , then test control timer board.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Apr 27, 2009 | Hotpoint Dryers
Hotpoint RGB745 Gas Kitchen Range Logo
267 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
