Question about Mastercool 67471 Evaporative Cooler Air Conditioner
Problem with Breezair ILL1140-A evaporative cooling
We had a power outage while the cooling was on and when the power returned and I turned the cooling back on, all I got was the 'Service 2' message on the screen.
Range has power but elements or oven will not heat.
Hello David Adamoski,
Power "outages" is an incredibly HUGE statement...
Sometime involving spikes or insufficient power...
Both of which can seriously damage your equipment.
Giving NO MODEL NUMBER does not allow me to
even speculate properly... Although FIXYA is a
CALIFORNIA (San Francisco Bay Area) website...
A huge number of our questions come from
TOMORROW... Across the international DATELINE.
If you were in the UNITED STATES... I would easily
tell you to CHECK your residential power at the service
entry... VERIFY that you INDEED have at least...
220 volts both at your SERVICE ENTRY... and
at your appliance
(utility companies can & do make MISTAKES)...
Not finding any issues there...
If you have your OWNERSMANUAL... Look
up you schematic drawings... in particular... CIRCUIT BOARDS,
FUSES or TRANSFORMERS... Check those specifications
(and look for soot or meltdowns..
GET the REAL PART NUMBERS on eBay
(for serious savings)...
ELSE
Try one of these part houses to find your
CIRCUIT DRAWINGS... parts and drawings
Search Over 2 1 Million Appliance Parts
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
PartSelect Appliance Parts and Repair Help
Better still... Come back with a QUESTION that includes
your MAKE & MODEL...
We can do this...!!
Carnac the Magnificent
Dec 19, 2017 | Kitchen Ranges
My breezair evaporative cooling can not cool.
Maybe you're expecting too much. Evaporative cooling doesn't work really well. It's function depends on evaporating a lot of water into the air. If the air in your room doesn't have a really low humidity (really dry air), then evaporation can slow way down or even stop regardless of how fast the fan is blowing.
Jan 02, 2015 | Heating & Cooling
My breezair evaporative cooling system can not cool.the air flow is very worm,anyone can tell me this problem?
what is the weather like is it humid ?
Humid weather will render any evaporative cooler ineffective !
Have you got the windows and doors open to the building ?
Evaporative cooling relies on putting water in the air and pumping the air out of the building. If it is humid the air already contains water and no extra water is added to the air and no cooling occurs.
Whirlpool WRF560SEYB Refrigerator did not turn back on after power outage, display said "cooling off"
Sounds like you had a power outage?-- did the lights go dim for a few minutes, before the power actually went out?-- Sometimes, low voltage will cause the compressor motor to over heat-- so it might have to 'cool down'-- What happened next?-- Did you try it again an hour or so later/-- Tell us more-- Mack B
Nov 03, 2013 | Whirlpool WRF560SEYB 30" french door...
My samsung model RF263AEPN is flashing an 88 89 after the power went out
This is taken directly from the Samsung website:French Door: Why Is The Display Blinking 88 88 And Not Responding?Cyber
Drastic power fluctuations such as power outages and surges can cause electronic device to behave abnormally. If the refrigerator display is showing 88 88 (all eights) and is still cooling properly, unplug the refrigerator for 60 seconds and then plug it back in. If the display returns to normal after approximately 2 minutes service is not required. However, if the display does not return to normal service is required.
Sep 23, 2013 | Samsung RF263AEPN French Door Refrigerator
I have a breezair evaporative aircondioner. Ive turned the cooler off however the water has been leaking continually for several hours , even though ive switched the mains off . Sometimes ive often...
There is a water shut off valve connected to a float. The float may have a hole in it or the valve itself won't shut the water supply off before it overflows.
May 04, 2017 | Heating & Cooling
After power outage the fridge was displaying codes SY and EF I have Frigidaire model number FGHS2365KF1. Any thoughts?????
Hi.
SY: Defective evaporator system. Check evaporator fan, thermostat and heater.
EF: Evaporator Fan defective. Test and eventually replace the evaporator fan.
The problem is likely the evaporator fan. Before replacing the fan test the other parts comprised in the evaporator system.
Here a tip explaining how to test such parts with a similar fridge model: Fridge not cooling. Procedure is more or less the same with your model.
Here parts and diagrams for your model.
Generally you can find parts and diagrams for most appliances using the links listed on this page:
Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Aug 29, 2011 | Frigidaire FRS3R5EMB Side by Side...
We had a power outage for about 45 minutes a few days ago. Ever since then the Powerware 3110 has been beeping. I turned it off and left it plugged in overnight and when I turned it back on the beeping...
This could be several things, fortunately the device should actually be helping you to diagnose the issue. There are different beeps for different issues. They are as follows:
1 Beep Every 5 Seconds = Power Outage\Loose Plug Connection\Tripped Circuit Breaker\Power Cord Damage or Failure
2 Beeps Every 5 Seconds = Low Battery Alarm
3 Beeps Every 5 Seconds = Battery Needs Charging\Service\Replacement
3 Beeps Every 5 Minutes = The Battery is discharged and battery power is unavailable (If this continues battery replacement may be necessary)
1 Beep Ever 1/2 Second = Power Requirements exceed the UPS Capacity (remove some equipment to lighten the load on the unit)
Continuous Beep = Short Circuit / Input Voltage out of Range / UPS Fault (Likely replacement of entire unit)
That should help diagnose the actual issue. If it turns out the battery needs to be replaced they can be found online for around $20. A simple google search for Powerware 3110 Battery should return what you're after. Good luck!
May 05, 2011 | Powerware 3110 UPS System
WE HAD A LOT OF POWER OUTAGES,NOW PHONE HAS MESSAGE SAYING PLACE IN CHARGER
Try powering OFF the base and then leaving it for a minute. Then plug it in again to the power socket to turn it on. Next, remove the battery from the handset and leave it also for a minute before returning it back. Then place it to the base to start charging.
Mar 01, 2011 | Vtech Lands Phones
It starts running and after about 15 seconds it shuts down with a message of service then what i see as an alarm 7 and shuts down
If it is a evaporative cooler that is breezair, coolair or braemar it will be because it has to low or too high a voltage supply. another problem could be the capacitor is the wrong size
Feb 09, 2011 | Mastercool 67680 Evaporative Cooler Air...
Mastercool 67471 Evaporative Cooler Air Conditioner Logo
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
acrman404a
Level 1 Expert
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
