Question about Dell Inspiron 1545 Notebook
Startup problems factory start
Why does my notebook samsung np-nc10 beep on startup?
some laptops and desk tops beep on start up.but some beep when it has ram problems.
May 06, 2014 | Samsung NP-NC10-WAS1US Notebook
Stuck windows startup screen
Please turn off the computer, start hitting F8 at the startup and then choose last known good configuration. If this does not work, choose Safe mode options. If nothing works, please restore it to factory settings by holding down CTRL key and hitting F11 key up and down at the startup.
Jun 01, 2013 | Dell Inspiron 1750 Laptop
HP G71-340US NOTEBOOK FACTORY RESTORE
There should be a disk that came with the machine to do that. You have to insert the disk and do startup from that before restoring. There is actually a factory restore on the hardrive if you can find a way to get to it. Will this laptop start in safemode? Try F8 on startup screen to see menu and choose "safemode". Let me know, may can help you do this.
Mar 13, 2013 | HP VM114UA notebook
RECOVERY FACTORY
Hi there!
Here are the steps to restore your computer to factory default:
Windows XP
- Turn on Computer
- during startup you will see the Dell logo, press <Ctrl> <F11>
- click Restore then Confirm
- let the computer finish starting
Windows Vista
- Turn on Computer
- during startup you will see the Dell logo, press <F8> several times
- select Repair your computer
- select keyboard layout then next
- log-in as local user
- click Dell Factory Image Restore
- Click Next and confirm data deletion
- wait until it finish
Apr 11, 2011 | Dell Vostro 1710 Laptop Computer PC...
I need to rest my acer aspire 3680 to the factory sitting
factory recovery
if the computer is booting to windows, then click start and open a folder named as 'acer' listed in ' all programs '.You will find the ' Acer e-recovery managent ' in that folder.You can open it and click allow for the user account controls.Please click 'restore ' for the next screen and the select the first option, 'completely restore to factory defaults '.Follow the on screen instruction to initiate the Recovery.
The Alternate method for starting the Recovery on startup is using the combination of ALT+F10 ( some models its ALTgr ) on startup.Press and Hold down the ALT( Left hand of space ) and at the same time keep on tapping the F10 key till you get the message " Windows is loading files".Just follow the On screen Instructions to start the Recovery.
Oct 23, 2010 | Acer Aspire 3680 Laptop
How do i reboot my laptop back to factory settings
To reboot to factory setting you need to have the restore disk from the computer, put it in the drive and restart with the cd in the drive, if the startup screen does not start right away you need to type f11 or f6 to change startup order to cd first the the restore screen will startup and click restore factory settings
Jun 04, 2010 | eMachines eMD620-5133 Notebook
My VAIO Laptop screen keeps freezing when i run windows normally
If your screen freezes after a normal startup, it sounds like a memory problem.
If you have a virus problem or currpt or missing files, you will experence the same problems.
Depending upon how much memory you have and what programs are loading when computer starts, is important.
Reloading you software will only prolong the problems and they will return.
At the run window on xp, Type msconfig enter, tag mormal startup on the fisrt line. and in the upper right hit startup next to tools.
Next you will see a list of programs that startup will unit boots.
Remove anything that says, adware or any known programs that you know should not be running.
You can go to microsoft for much more infomation on this.
Good luck
Sep 22, 2009 | Computers & Internet
IBM ThinkPad R50 restore factory settings
You might have deleted the Hidden partition within the drive .So you will not get the restore factory setting option
Dec 13, 2008 | IBM ThinkPad R50e Notebook
I have a acer aspire 9300 and im trying to reboot it back to factory settings as it has slowed down to the pace of a snail since we added msn. i tried to get rid of msn but im still having the same...
yr problem is not factory settings. these what yu will do get it solved. aafter booting, click on start then click on run. yu now type in MSCONFIG in the space provided. a window will come out then u chose the option startup. after clicking on startup, u now click on disable all. then ok it n restart yr system. i shoulkd move faster if it doesnt then i ,might have a virus on yr system, yr ram drive is low in memory or yr hard drive has some bad sectors.
hope this helps
thank u
May 29, 2008 | Acer Computers & Internet
Dell Inspiron 1545 Notebook Logo
29 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
