Question about Husqvarna Zero Turn Mower Z5426
Zero turn mower dies when put in foward gear
Engine dies when put in forward motion
5 Suggested Answers
  • 33 Answers
SOURCE: husqvarna yth1842xp 2005 ride on mower won't move in gear
your linkage came apart from the way it sounds. most all these riding lawn mowers are simple machines. you need to fallow the(flopppy lever) and see where it go's it is supposed to attach to a rod or cable and must have came unhooked
Posted on May 02, 2009
wentlanv
  • 710 Answers
SOURCE: Model Rider155 Will mover slowly back and
Hi aywon,
These symptom point to the engine speed being set too low.
If adjusting the engine speed does not help, check to be sure your mower deck isn't too low. Also, the chute could be blocked.
Most probably the engine speed should be set higher.
I hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Posted on May 05, 2011
  • 640 Answers
SOURCE: MY CRAFTSMAN DYT4000 RUNS GOOD WHEN THE PTO IS
It sounds like your mower is equipped with a reverse safety switch. This switch will prevent you from mowing in reverse by killing the engine, like any safety switch. You just need to investigate it and decide if you will disengage the blades to back up or if you will disable the safety switch. You mentioned that there were wires cut. Do you know what they were? How many were cut? I suggest that you trace them out to see what they are, where they go. The previous owner may not have wanted to deal with the safeties for a number of reasons.
In regards to the reverse safety switch, many mowers do not have them. As in they do not come on all mowers, historically. I do not know if they are designed into all the newer ones or not. I work on older mowers and whether or not they are on a mower seams to depend on the manufacturer (on older mowers). My seven or eight year old Craftsman does not have one, while a twelve year old MTD may.
I hope this is helpful for you.
Posted on Aug 22, 2011
Testimonial: "thanks will try to check for a switch,,and abought all the wires were cut by a dog i got a wireing ***, and reconected and reran all new wires "
H2_Brad
  • 425 Answers
SOURCE: When going forward on husquvarna zero turn, my mower shuts off......what could be the problem
First thing to check would be a seat safety switch. There are probably a number of safety switches on your unit and those are easy to test with a multimeter. Using the ohms scale you should have almost no resistance in one position and no reading at all in the other.
Posted on Aug 24, 2012
Starts and runs fine but when I put it in gear it dies
Riding Mower Dies When Put in Gear ' ThriftyFun
www.thriftyfun.com/Riding-Mower-Dies-When-Put-in-Gear.html
It starts fine, but when I put it in gear to go forward or reverse it dies. It also dies ... The engine on my riding mower will start and run while the clutch is pushed in.
Starts and Runs but Dies When put in gear - YSR 50 ' South Bay Riders
www.southbayriders.com > ... > Community > Maintenance and Repair
Aug 25, 2010 - 15 posts - ‎4 authors
The bike will start and run perfectly fine. However, the moment I put it into gear it dies. ----------------- How we got to this point:...
Engine dies in gear, runs in neutral - Hot Rod Forum : Hotrodders ...
www.hotrodders.com > Tech Help > Engine
Jan 4, 2010 - 12 posts - ‎10 authors
But if I drop it into any gear besides neutral or park, the engine will ... In this case, it shifts fine, and on time, however acceleration is ... start. the engine idling rough and wanting to stall when put in gear is the indicator to me.
Jan 21, 2016 | Garden
Why does my riding mower die when put in gear or engage the blades
Check out the grass box safety switch. if not fully depressed it will apply brakes to the blades when in gear. Most mowers are designed with a safety switch to stop the blades, or forward motion if the grass box is not fitted correctly.
Aug 23, 2015 | Garden
It will not go forward it is only 1 year old and yes it starts my husband past away and I don't know what I am doing wrong
After the engine starts you must put the mower into gear so that it moves. Look for the gear shift lever or whatever.
Aug 02, 2015 | Ariens Zoom 42 In 165 HP Briggs Stratton...
Was cutting and stop moving forward and back wards belt in good condition
Could have broken the shear pin in the drive pulley. If one of the pulleys turns when you put it in gear but the other pulley does not turn then the shear pin is broken or missing.
Apr 04, 2015 | Husqvarna Rz4623 46" Ztr Lawn Mower Zero...
The transmission won't move in forward but will in reverse?
get the OBD codes read as will point you in the direction of the fault
Oct 15, 2014 | 2007 Hyundai Elantra Limited Sedan
Why does my mercruiser engine die when put in forward?
Something is too close to the coil wire , CAbles(steering and throttle ) either up front or on the engine do flex when moved.Checkthe movement and operating clearnces at both full and idle positions. All tests can and should be done with engine off, due to Dangerous prop exposure. Good Luck and I would like it if you tell me what you ultimately find. _Ned_
Aug 03, 2014 | Mercury Marine Mercruiser 120 140 3.0 470...
Zero turn mower is sputtering and dies
Check everything is clean. Check the air filter is clean, check that the engine cooling fan, cutting blades and cutting deck are free of grass. Check all the drive belt pulleys to ensure accumulated grass is not jamming anything. Check the fuel filler cap is clean and the breather hole works.
Jun 27, 2013 | Husqvarna Zero Turn Mower Z5426
Husqvarna Zero Turn Mower Z5426 Logo
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
