How to disable the score in megavision - Audio Players & Recorders
Tip
I have a megavision 19" flatscreen monitor. The color is all screwed up. It has...
The discoloration problem is due to the near by magnetic field appliances like speakers which are very near to monitors ...
so what you have to do is just keep some distance to the monitor from the speakers and other magnetic appliances and then press menu button & just give degauss..
on Feb 13, 2008 | Sony SDM-HS73P 17" LCD Monitor
How to upgrade megavision 500Gb karaoke player?
Can anyone please help me.. may megavision ako, I connect it to my sony tv and sony home theatet system pero pag kumanta ako may delays sa voice ko.ano po pwede ko gawin para mawala yun please helppp...
Feb 15, 2014 | Audio Players & Recorders
Where can I find a Megavision MV173 LCA01F "monitor to computer" connection cord?
Isn't it a VGA cable?(15 pins-3 rows of 5 pins,slightly staggered.There is a 15 pin D-sub connector(2 rows of pins)-usually for extending a joystick cord on a PC.
Dec 16, 2012 | MegaVision MV173 (Black) 17 in. Flat Panel...
Message: Virtual Memory is too low. The pc is too slow to work.
You may need more RAM. Right click My Computer > General.
Or, open Control Panel > System. RAM will be noted. You can run / see Windows Experience in Win 7. Your score is based on lowest score. Check RAM score.
Win 7 works best with at least 2GB of RAM
Another trick is to disable startup programs from loading in the first place. Go to Start > Run (search in Win 7) and type MSConfig > Startup tab and uncheck anything that you don't want Windows to load automatically.
Sep 25, 2012 | Dell Vostro 220 PC Desktop
The monitor goes dark within a few seconds of turning it on. Is this something that can be fixed or do I need to replace?
Try replacing the power cable. (assuming that the monitor has not lights when it turns off) After replacing the power cable if that doesnt work try a different outlet.
If there are lights try seeing if you can replace the data cable from the monitor to the computer. If that doesnt work then you will want to look into getting a replacement.
Mar 01, 2011 | MegaVision Hyvision Megavision 191 19"...
Power supply bad
Hi there.
have you tried changing the power cord you are using?
Nov 28, 2010 | MegaVision Hyvision Megavision 191 19"...
My monitor has a blue cast over everything!
Check all the pins at both ends of the cable and make sure they are seated properly, also try it with another PC to make sure it is not the PC video card problem.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Sep 29, 2010 | MegaVision Hyvision Megavision 191 19"...
My HyVision LCD TV Picture disappears after a few seconds
It seems that the "backlight" has gone bad. "Backlight" is the device that allows to see the picture in an LCD TV, when they are about to go bad the symptom that you describe is very usual. It depends on the tv manufacturers and model to expect how long the "backlight" is going to last in a tv.You can shop around for a replacement part and try to do it yourself or take it to an especialized technician. Good luck..
Jan 03, 2010 | MegaVision Hyvision Megavision 191 19"...
I ran a Belarc Advisor test on my computer today. The score result was just 3.13 & fairly low. The Belarc Advisor performed a security audit of my system using the CIS Level-I benchmark appropriate...
OS means Operating System.
On your machine, disable Windows Firewall as it is known to conflict with Norton's Firewall and leave you disabled.
Also, go to windows.com click on the Continue Button start downloading Windows Defender and install it.
Then rerun your protection score and post back any change.
Belarc is not considered to be the software to own and use for benchmarking your computer's vulnerability.
Regards,
Worldvet
Aug 18, 2008 | Computers & Internet
47 people viewed this question
 Grubhead
Grubhead
