Question about Philips Audio Players & Recorders
Philips FW630 HI FI SYSTEM
Ive got a FW630 for a christmas present A couple a problems First when i turn it on it jump from cd to tuner to tape decks and continue in every two minutes in between /SECOND Problem Ive got lots of MP3 Digital ecording cds even original ones none of them play it says on screen NO DISC not impress
    Top Expert:
  • Philips Master
  • 39,384 Answers
Sounds like a defective system.
Posted on Dec 28, 2013
  • 93 Answers
SOURCE: CD Changer & Tape Deck
Check for dirt on CD laser lenses. Also transmission on tape player.
Posted on Oct 03, 2007
  • 223 Answers
SOURCE: CDs won't play RCA RS2651
I think the laser is mis-aligned or the laser unit needs replacing. If you are able to check this for yourself otherwise find a competant technician. Hope this helps.
Posted on Oct 06, 2008
SOURCE: My Sony Hi Fi System also turns itself off-when I try to play cDs
Check if you can see for the belts on the cd deck and change them
Posted on Jul 04, 2009
  • 4234 Answers
SOURCE: I have a NSX-V70 stereo. Tapes and CD do not work, FM/AM is fine
Your unit needs a little TLC. Let me address the likely problems/solutions:
1) Tape deck stuck - The most common problem here is that the belt has gotten slippery. This has prevented the mechanism from resetting to a known position and that is what prevents the door from opening. Hopefully when you pried it open, nothing bot broken.
2) Both tape drives run from the same motor and use different belts. The same applies to the second deck as the first. The belts are sliping and need to be replaced.
3) The CD lens is probably dirty and needs to be cleaned. The fact that the CD stops and an attempt is made to play it suggests that the optics are working enough to detect the disc. Clean the lens using a cotton swab and alcohol and that should resoplve the CD problem.
If you have not opened up these before, I would not suggest you start without someone around who has. There are 3 belts that need to be chagned for the cassette section to work. Plan on $15-$20 for the belts.
Dan
Posted on Feb 23, 2010
SOURCE: i cant find the operators manual for Panasonic audio rack system
That hifi is not an old model,it was made in 2005,try contacting the head panasonic office in japan,they may help you
Posted on Sep 20, 2011
Sony HCD-GT222 Hi-Fi CD and cassette deck with tuner, suddenly started to shut itself down at volumes higher than 50%, after three years of flawless operation.
It's thermal; protection is happening probably due to bad ventilation. Fuzz and dust can block air vents.These need to be vacuumed out now and then.
Jan 22, 2014 | Audio Players & Recorders
Sony Mini Hi-Fi Systwm shuts down at high volumes
You need to have the fan in the check,possibly its not working anylonger
Jan 22, 2014 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
No sound when I play my CD on my Micro Hi-Fi System
you have cd output sound before or never you get sound from cd if you never get sound from CD then u call Service Center
May 21, 2012 | Audio Players & Recorders
I´ve forgotten in what order I should connect my old (80´s) separate modul hifi system´s remote cables. It shuts down imadiatly when you try to start it with the remote. If I disconnect the...
I would have thought that it should go from the amp to the tuner,then the tape deck and finally the CD deck.
I'm suspecting that your tuner is faulty and thats whats causing the system to shut down
Aug 27, 2010 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
Tape deck door problem
The mechanism would not have reset to allow the door to latch on. it could be a possible failure of the main/dirve belt. you will also have to check if the hinges are broken or if any freign particles have logged in. Removing the deck mechanism and changing thebelt will require a little expert work and so be very careful in removing.
Apr 23, 2009 | Audio Players & Recorders
Radio on my sony rx d7 hi fi 3 cd changer
check to maks sure you have an fm antenna connected
Dec 19, 2008 | Audio Players & Recorders
Kenwood tuner/graphic equalizer c-h6
sound output section trouble.can you remoove and shall we start rectifing the problem.
nuwan
Dec 04, 2008 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
128 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
