Question about HP Photosmart C5180 All-In-One InkJet Printer
C5180 error 0xc19a0006
How to repair
HP Photosmart C5180 All-in-One Printer: Error oxc19a0021
Hi hp_dis,
This error represents a failure on the printer itself. HP considered it a total hardware failure and the unit had to be replaced, as it was unrepairable in the field and parts to repair them are pretty non-existent for ordering. Here's the link from HP about this specific problem and you may need to contact them directly if the machine is still under warranty so they may help you with the replacement of your machine.
Hope it helps.
Thank you for using FixYa.
Dec 10, 2010 | HP Photosmart C5180 All-In-One InkJet...
Error ink system failure on photosmart c5180
The "ink system failure is a common error on HP printers, it is caused by air in the ink cartridges or ink feed tubes. YOu will need to do a ink purge routine to clear the error. We have several pages on our web site explaining what causes the problem and how to clear it. The link is: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/
This should get you up and printing in no time at all.
I hope this helps you, if so please rate our solution.
CCL Tech
Corporate Computer
www.ccl-la.com
Oct 10, 2010 | HP Photosmart C5180 All-In-One InkJet...
I have an error message on my HP Photosmart C5180 All-in-One printer stating: Ink system has failed. Unable to print. Refer to printer documentation. Error: 0xc18a0201
Hi!
Ink System Failed is displayed becuase the printer head can not communicate with the main board of the printer and this can happen due to print head failure there is nothing you can do except repairing the printer.
Aug 10, 2010 | HP Photosmart C5180 All-In-One InkJet...
My HP Photosmart C5180 all in one is displaying this error Ink system has failed refer to printer documentation OXC 19a 0035 cannot find out what it means?
The "Ink System Failure" is caused by air in the ink feed tubes. This problem can happen if you allow your ink to run all the way out or if you use poorly refilled ink cartridges that have air bubbles in them. To clear the error you will need to perform a purge on the printer. We have a step by step guide to this procedure posted on our web site at: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/ This should get you back printing in about 10 minutes.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jun 19, 2010 | HP Photosmart C5180 All-In-One InkJet...
Ink system failure message on HP photosmart c5180 all in one
tengo una impresora photomart c5180 hp y me produce un error 0xc18a0107
Nov 07, 2009 | HP Photosmart C5180 All-In-One InkJet...
My HP Photosmart C5180 printer keeps coming up with an error message 'Ink System Failure. Does anybody know what is needed to solve the problem.
The "Ink System Failure" error is causes by air in the ink feed tubes. We have a step by step guide purging the air from the feed tubes posted on our web site. Go to our site at: www.ccl-la.com, click on the printer repair link and then the HP link. Follow the steps and you should be back printing in no time at all.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Nov 01, 2009 | HP Photosmart C5180 All-In-One InkJet...
On HP Photosmart C5180 Error Message 0xc18a0201
call hp total care 1800 4746836
u knw i cn tell u the steps but if u do even 1 of the steps wrong ,ur printer wont work anymre so contact them
...hp technicians will be able to take care of u
thanhks
Aug 07, 2009 | HP Photosmart C5180 All-In-One InkJet...
Hp photosmart c5180 error code oxc18a0501
i domt know wgat the error is, but most likely its cheaper for a new. Service repair will be at least $45 + parts
May 08, 2009 | HP Photosmart C5180 All-In-One InkJet...
Error: 0xc18a0107 Printer HP C5180 All in One
I had the same problem for a few days.
Each time, I switched on my HP C5180 printer, the Oxc18a0107 message was displayed.
I tried the solution that I found on the net (power off, power on while holding on OK and HELP keys) unsuccessfully ...
Then I bought new ink cartridges and I put them after resetting the printer.
No more error message ... It works well now.
Abbesses
Apr 09, 2009 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C5180 All-In-One InkJet Printer Logo
140 people viewed this question
Seeker5211
Seeker5211
