Question about HP VP6121 Multimedia Projector
Multimedia projector display too pink
Multimedia projector displays what's on my computer monitor onto the big screen. On my monitor, the color is fine. On the big screen, it is tinted pink. I've tried playing with the color mode button on remote. This is not the solution.
    Problem Solver:
  • 12 Answers
Check the vga cable, usualy its a broken wire inside
Posted on May 18, 2009
  • Alicia Estrada
    Alicia Estrada May 14, 2014
    I have the same problem but when I connect any other product- my document camera or another computer the display is fine.
Tighhtening a loose connection was a solution.
Posted on Dec 08, 2009
Sony lcd pink color
Check your connections / cables. Sometimes VGA cables will display color hues if not firmly attached.
Nov 10, 2013 | Sony VPLFX52 Vpl-Fx52 Mmproj Lcd-W/...
My Windows XP is connected to my Epson Powerlite S3, but the screen is blue with the words Source: Computer (Auto) No Signal on it. When I click "Help" on the projector, it takes me to a screen...
'No signal' and 'unsupported signal' messages mean 1 of 2 things, either the VGA output is off(laptop) or the display resolution is set too high(laptop and desktop). Assuming the VGA cable you are using is good, try this:
Desktop: hook the computer back up too your computer monitor & set the computer to the basic VGA resolution. For windows XP, right click a blank area on the desktop, click 'properties' on the dropdown menu, click settings. Write down the numbers in the 'screen resolution' and 'color quality' boxes!
Drag the 'screen resolution' all the way down to then 'less' side. Then change the 'color quality' to the lowest setting. Click apply, then answer yes (the display will look UGLY - don't worry!!) Now connect your computer back to your projector. If it works, then the resolution you use on your desktop monitor is not supported on your projector. Experiment with different resolutions to see which one looks best on your projector. You will need to change the settings each time you switch monitor to projector.
Laptop: by default the VGA connector on your laptop is off. To turn it on, look for a blue symbol on one of your function (F1, F2, F3...) keys. It looks like an old TV with a line on both sides 'O' (F4 on HP) Press & hold the blue button (on the lower left of the keyboard, usually to the left of control ) and tap the bleu button you just found. Let go & give you're a computer a few seconds to change over. If the laptop screen goes blank, you found the correct button! The display image should now be visible. Repeat this 1 to 2 times to change it back to laptop display.
If you did not see the display on the projector, 2 other issues are possible. First, verify that the VGA output on the laptop is working - connect the laptop to a regular computer monitor & change the display resolution to the lowest settings (see desktop above), then try it again on the projector. If you cannot get an image on a computer monitor, your laptop settings may need to be adjusted in the same dialogue box as the settings. Monitor #1 is the laptop display, Monitor #2 is the external output.
Happy viewing :)
Jun 12, 2011 | Epson PowerLite S3 Multimedia Projector
Laptop display will not project onto screen
A couple of possibilities...
Connect a separate monitor to your laptop and verify that your laptop's external monitor port is functioning properly.
If yes, connect and power up the LP120. Press the source key on keypad. You should see the projector switch from video to computer.
Last option, does the projector display an "out of range" message on the screen. If so, reduce your laptop resolution to 1024 x x768.
Apr 05, 2010 | InFocus LP120 / 1000 Lumens / XGA / DLP...
I cannot get a picture onto the projector
Make sure that you have the secondary monitor enabled on your computer. Check your display driver configuration program or the Windows display properties.
Example: Intel Display Clone
Feb 06, 2010 | InFocus LP70+ Multimedia Projector
My projector does not display my laptop screen
Follow the step by step procedure if you are using win 2000 or XP or 2003 :
Start menu -> Settings -> click Control Panel.
In Control panel double-click the Display icon.
On the Settings tab, click the image of the second monitor, and then select the Extend my Windows desktop onto this monitor check box.
Your problem will resolve.
Regards
Ashly
Feb 05, 2010 | Toshiba TDP-S8 Multimedia Projector
Projects pink display
change the settings.
go to the signal menu and change computer input to rgb.
May 20, 2009 | Office Equipment & Supplies
Display is not the right color
This generally means there is a fault with the cable between pc and projector. If you have a spare VGA lead try it and see if that fixes it.
Also make sure that the cable is tightly pushed onto both ends
Jan 08, 2009 | Epson PowerLite S1 Plus Multimedia...
Pink/burgandy dots or shadow on display screen
Normally one of 2 things will cause this.
  1. One if the small LCD panels inside has dead/stuck pixels. There are 3 individual panels that make up red, green and blue.
  2. Dust has entere the system and is sitting on the back of the polariser. This is a thin colour film ontop of the small LCD panel that sends the right colour light through the LCD.
If it's the first one, then it will be covered under warranty.
If it is the second they will normally cover it under warranty since their dudst filters have failed to keep the dust out of the projector.
Call the number in the back of your user manual for your area and they will arrange it all with you from there.
Apr 19, 2008 | Sanyo PLC XU48 Multimedia Projector
No picture
You may need to reduce the resolution on your comptuer screen. Try going to Control Panel, Display, and Settings and lowering the resolution a notch or two.
Also, you must make sure that the computer is set to send the signal to the external monitor,. That usually means holding down the Function key and pressing the F5 key or the one with the picture of two monitors on it. You will see several options for display. Toggle with the F5 key to the one that shows the computer screen and the external monitor at the same time.
Dec 19, 2007 | CTX Optoma EzPro 580 Multimedia Projector
Permanent Coloured tint
When the image turns pink, we find that replacing the cable between the projector and the lap top fixes the problem.
Sep 10, 2007 | Sanyo PLC-XU47 Multimedia Projector
HP VP6121 Multimedia Projector Logo
1,973 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
