Optoma hd2000X (C1E)
Hi My Optoma hd2000X (C1E) show, when it starts, regular vertical lines and seems unstable when i scroll through the menu. Poor signal and image disappear. It does not help when i change the test mode to none or unplug it and restart . Please someone who knows what its wrong and how to Solveig the problem? Kind regards Milad
SOURCE: Vertical white line
My EP719 had the same problem. Did it once, briefly, soon after I bought it, then not again until recently, when the line came back more frequently and wider.
The projector was 20 days past warranty, and the company would not honor. So much for customer satisfaction and loyalty. Last piece of Optoma equipment I will ever buy!
Anyway, I found a web item on another model of Optoma projector with the same problem. The solution this guy tried was -- I kid you not -- rapping on the thing. With nothing to lose, I tried this on mine. Tapped lightly on the top and noticed a change in the width of the line. Hmmm ... it was sensitive to this.
Tapped harder. The line got narrower. Rapped pretty hard -- thump! -- and the line disappeared.
Since then I have been running the projector for hours, turning it on and off, letting it cool down, starting it up again. And the line seems to be gone. It may come back, of course, so this gonzo fix may not be permament. But if it works while I'm using it at a presentation, think of the amusement it will cause!
Posted on Oct 18, 2007
dhiman
  • 115 Answers
SOURCE: EP 757 Intermittent powering down
Pls check if the lamp is not so old that is giving the same problem. If lamp is almost new, then you can have a check with the Ballast unit card and then the loose connection in the Power supply or may be overheating and tripping.
Viren
Posted on Nov 19, 2007
Benimur
  • 6966 Answers
SOURCE: no signal optoma ep739
One good thing is that you are running XP. Will work on the premise (that you have posted) worked before and the driver (ForceWare91.31) was the only thing changed.
Let's try the easy ones first. Activate twin/dual view in your Display Properties. Right click on any clear area of your desktop, click on Properties, click on Settings tab, select monitor 1 or 2 depending which is your primary and which is your projector. Check (or uncheck-whichever works) on box "Extend....". Apply, OK.
or
do the same with nView Properties.
The hard ones are registry and/or inf editing, though I am reluctant to even suggest.
Incidentally, there is an application that is supposed to facilitate twin or dual view configuration, UltraMon. This may be better/safer way to address your concern.
If all else fails, you may have to rollback/downgrade your driver.
Cheers.
Posted on Jan 20, 2008
SOURCE: White vertical line on left side of screen
omg, I just figured out why OUR projector was doing this! There was an adaptor plugged into it that we use to hook it up to cable to watch games/tv shows sometimes...once I unplugged that from the projector the lines dissapeared!
Posted on Oct 02, 2008
projdoc
  • 2236 Answers
SOURCE: vertical lines on DLA-G10E projector, image
first try to reset the settings to factory default. if that doesn't work, you have a main board issue.
Posted on Dec 28, 2009
Vertical lines showing up after being on for awhile
Eh, I can't be too sure, but it sounds like it's either a heat issue, a signal issue, or a backlight issue. Either way, if it's still under warranty I'd send it in.
May 06, 2013 | Sharp LC60LE835U AQUOS Quattron 60" 3D...
Optoma HD81-LV ... white lines on projected image
this has happened to many of these tvs, I would return it if you can, this isn't worth it to get fixed. I'm sorry if you can't return it, yours lasted less than many I have heard of
Mar 25, 2008 | Televison & Video
Unstable signal on a SONY KDF-50E2000 08760591
Can you please explain what you mean by an unstable signal? Without details, the problem can be anything from a weak signal being presented to the tuner to a defective tuner to poor signal processing later on. Also, check the picture and sound using different inputs to the set. If hte problem is the same regardless of hte input signal, that tells us that the problem is in the video signal processing circuitry. Also, place a menu on the screen. Is the instability present with the menu display?
Thanks,
Dan
Nov 04, 2009 | Sony KDF-50E2000 50" HDTV
Vertical lines showing. it is an Optoma HD70
If the lines present in the menu when displayed this indicates device mounting troubles. Possibly loose in socket. If you change aspect of displayed image do the lines move, if they do, its an electronics problem, if they are constant, and nothing is displayed in the lines. Tighten device in socket, or seek professional service.
Jul 07, 2009 | Televison & Video
Screen shows blurry vertical lines instead of image
It is failure of ccd imager chip in your Sony DSC-T1 camera and Sony will repair it free of cost.
Click Sony CCD Imager Support for details.
May 20, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Unstable image on television screen: Hitachi Model # 27CX3B
Check for poor soldering around Vertical Driver Ic.
Nov 11, 2008 | Televison & Video
Help me please Optoma HD72 DLP
In the menu you can change the phase of the signal or the tracking. In Menu - Setup
Jul 05, 2008 | Optoma HD72 Multimedia Projector
Vertical Green Lines
Hi Jon
Check if the lines shows on both PC & Video inputs. If it shows on both you could be in for a new Mainboard.
If it only shows on the one signal and not the other it could only be a loose connector that needs soldering.
Mar 26, 2008 | Office Equipment & Supplies
Vertical white line
Oct 08, 2007 | Optoma EP719 XGA DLP PROJECTOR 2000L...
223 people viewed this question
k24674
