Question about Amana RanARG7302 Gas Kitchen Range
Oven will not light
I have an amana gas oven model #675wj-kvw (i think thats the #) anyway I can't get the oven to turn on...the little bar will light up but the gas won't come through..everything on top works...
thx patty young
paydy55@yahoo.com
    Scholar:
  • 85 Answers
Most likely your oven igniter is faulty. When they get worn they will heat up but not get hot enough for the gas to turn on.
Part number is 7432P062-60
Posted on May 18, 2009
Whirlpool oven wont start, is there away to light the pilot?
You don't say what model you have. That being said, I highly doubt it uses a pilot light. It most likely uses a glow bar igniter to ignite the gas. Take the bottom of the oven cavity off (remove the racks and you'll see a couple screws in the back on the bottom. Remove those and the bottom of the oven cavity should lift up).
Once you have the bottom cover off, turn on your oven and watch the glow bar. If it glows bright white, it's good and your gas valve is most likely bad. If it doesn't glow at all, or it's not very bright, or it has one bright white spot on it and the rest of it looks a little yellowish orange, then you need to replace the glow bar igniter.
Anyway, that's where I'd start.
Nov 04, 2014 | Whirlpool Ovens
Amana gas oven not working
SOUNDS LIKE U HAVE A WEAK BAKE IGNITIOR REPLACE THE BAKE IGNITIOR IT WILL SOLVE THIS ISSUE
Aug 31, 2009 | Amana ARGS7650SS Gas Kitchen Range
The ignitor may be too weak to open the gas valve. If you have a volt/ohm meter capable of reading AMPS you can hook up to a ignitor wire and turn the oven ON. If you read less than 3.5 amps replace the ignitor. If 3.5 amps or more are read,replace the gas valve.
Aug 30, 2009 | Amana ARGS7650SS Gas Kitchen Range
Amana gas range trouble with starting
not a sensor, but more likely a bad oven ignitor(glow bar) its located under the ovne floor and mounted to the side ofthe bake bar. simple emough to unscrew and unplug, replacethepart yourself
Mar 18, 2009 | Amana ARGS7650SS Gas Kitchen Range
The oven doesn't work ,the ignator doesn't light up. no gas coming oven doesnt work. it wont ignite. i smell no gas coming in. burners work fine
ok try your broiler if it lights change the glow bar in the lower oven the glow bar acts as a safty if it doesnt reach a certain temp the safty valve wont alow gas to enter the broiler and bake are on seperate ignighters if neither work change the safty valve
Feb 11, 2009 | Amana ARGS7650SS Gas Kitchen Range
Amana Range ARG7300W
yep open the oven door unplug the range remove the racks on the bottom liner should be some screws remove them then take the liner up and out if there is a flame spreadder on the burner tube remove it at the back of the burner bar should be the ignighter most new ones are generic you just cut the wires on the old one and splice the new one on with cerramic wire nuts make sure the wires are away from the burner bar reverse dissambily turn oven on should light within 30 secs if ya pluggedit back in
Dec 29, 2007 | Amana RanARG7302 Gas Kitchen Range
Amana RanARG7302 Gas Kitchen Range Logo
279 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mike Carew
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
