Question about Craftsman Garden
The new battery on my Craftsman LT1000 18hp riding mower will not charge. Anyone have any ideas?
The battery on my LT1000 Craftsman riding mower will not charge
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 11 Answers
If you replace the Battery and it does not charge you need to test the stator or as I call it the alternator with a multitester.the stator is located underneathe the fan\flywheel and requires a fly wheel puller to pull off fly wheel and to bolt new stator underneath.but i would test it with a multi meter.they are about 50 new.you will see the red wire for stator coming out of engine aboutr midway down unplug it and test it.
Set the multi-tester dial to AC VOLTS or DC AMPS.
Insert the black multi-tester lead into the tester's COM receptacle.
  • For AC VOLTS, connect the other end to ground, such as an engine bolt or cylinder fin.
  • For DC AMPS, connect the other end to the battery's positive terminal. (NOTE: The battery must be grounded to the equipment frame of the engine block to create a complete circuit.)
  • Insert the red lead on the multi-tester into the tester's receptacle (labeled AC VOLTS or AMPS).
  • Connect the red lead to the appropriate stator output wire.
  • go to this link on the briggs site for youre engine so you know what volts or amps are good. also note that some lower HP briggs engines have a regulator that they threw in the mix and I believe any engine below 16hp does have a regulator so it would be need to be tested as well.any engine over 16hp has a battery and stator and no regulator.
  • http://www.briggsandstratton.com/us/en/support/faqs/charging-system-alternator-test
    Posted on Jun 29, 2015
    • 61 Answers
    Ck for blown fuse, ck for broken wire.
    Posted on Sep 06, 2009
    I need to check electrical system in my riding mower
    Check your battery cables all ends. and see if they are loose or corroded. Just an Idea. Check all fuses if you have any.
    Dec 07, 2016 | Craftsman Garden
    Will not crank DEAD but lights come on
    Riding Lawn Mower Won't Start ' ThriftyFun
    www.thriftyfun.com/tf666549.tip.html
    Question: Lawn Tractor Won't Start. I have a John Deere LA125. I bought it new in 2009. After sitting unused in the garage for the winter (5 months) I couldn't get ...
    Craftsman Riding Mower Won't Start ' ThriftyFun
    www.thriftyfun.com/tf68077908.tip.html
    Why will my Craftsman lawn tractor not start with a new battery, new spark plugs, new gas, gas filter, .... Question: 18.5 hp Craftsman Lawn Tractor Won't Start.
    Riding lawn mower will not start - Household Repair Series ...
    ? 3:41
    https://www.youtube.com/watch?v=DFDSvWtXwBk
    Jun 21, 2013 - Uploaded by Robert DIY
    This video will explain how I got a riding lawn mower started. Always check the basics. ... Lawn Tractor Won't Start--Any Ideas? - Duration: 2:04.
    Jan 21, 2016 | Garden
    Why doesn't craftsman mower tractor yt 3000 charge?
    If the battery is below around 11.8 volts it never will charge. The charging systems on these mowers are made to "maintain" the charge. Check the battery, if below 11.8 volts charge the battery with a battery charger. Then see if the mower will maintain the level. If not, you may have a bad battery. Your local automotive store can check it for you.
    Jul 08, 2014 | Craftsman YT 3000 42" Briggs & Stratton 21...
    Craftsman dlt 3000
    You need a new alternator...Alternators regulate current to the battery to keep it charged.
    May 19, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
    Craftsman riding mower clicking noise - wont start
    RIDING MOWERE JUST CLICKS AND WON'T START HOWEVER IT WAS RUNNING FIND JUST 5 MIN. BEFORE I TURNED OFF.
    May 22, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
    Battery will not charge
    IS THE BATTERY GOOD,IF THE BATTERY IS BAD IT WONT CHARGE IT,IF ITS GOOD THERE SHOULD BE A 20 AMP FUSE FOR THE GHARGEING SYSTEM
    Mar 24, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
    Engine wont turn over. too much compression. ehaust valve is opening. new starter and battery.take out plug and it will start. put back in , nothing
    jtd ride on mower wont start will turn over a little but if i take the sparkplug out it will turn over no problem any ideas please
    Jun 16, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
    Where is the fuse for Craftsman 17.5 HP 42 Riding Mower
    I'm not sure the solenoid/relay would even energize at 10 volts (so you may not hear the clidking).
    The battery is essentially dead at 10 volts -- try charging again for 4 hours or so, and then measure the voltage.
    If it's not up near 12 volts, you have a dead cell and need a new battery.
    May 03, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
    Garden Logo
    1,045 people viewed this question
    Top Craftsman Garden Experts
    Wade Mobley
    Wade Mobley
    Dean Gruber
    Roland W VanLue
    Roland W VanLue
    Are you a Craftsman Garden Expert? Answer questions, earn points and help others
