Question about Crosley CR49-TW Tweed Traveler Turntable CD Player
Bought a new needle for my traveler Crosley an NP-4 I believe? It skips on every record new or old
  • 157 Answers
SOURCE: Crosley traveler turntable noise
Hello attaboy. You may need to check you ac cord if the noise is in turntable, radio, & cassettte mod. If it has a 3 prong plug than you are missing a GND connection, in the cord or inside the unit. If it has a 2 prong plug than take it back or open it up and replace filter capacitors or bridge rectifiers in units power supply.
Posted on Sep 19, 2008
  • 17 Answers
SOURCE: Needle slides across the record on Crosley 5 in 1 player
you have unscrewed the suspension screw?
also check the needle for dirt and dust... try blue tacking a 5p coin to the top on the needle to give it a little more weight, if the needle stays in place then the arm balance if off, and unless there is a mechanism to adjust that on this turntable then i guess its a return!
Posted on Feb 12, 2009
  • 23 Answers
SOURCE: I have a crosley rochester
see if you can gently straighten the handle into the proper alignment.
Posted on May 13, 2011
Grubhead
  • 5113 Answers
SOURCE: I just bought a replacement
It might be that you have caused an earth wire to the cartridge to come off or loose. Check the connections to the cartridge.
Posted on Jun 14, 2011
Grubhead
  • 5113 Answers
SOURCE: Record skipping despite new needle
It could be something to do with the turnatable's platter. Is the matt that the record sits on faulty. Does the platter wobble up and down with no record on it? If you can see this happening you might need to check the platter out. If it's a belt driven the belt can come out of position causing such problems. Also objects can get stuck inside the platter. Especially if you have small children in the house!!!
Posted on Mar 02, 2013
Crosley CR6019A turntable skips
Hi
Being a portable model, it is very easy not to have the turntable level. It is very important that it is level as a tilt can lead to the head "skipping", amongst other things.
You can get a full User Guide here
http://0bee184f253cf7f48610-d2b1caba160808a264f409f8f32a9b54.r0.cf3.rackcdn.com/Crosley%20CR6019A%20%20Executive%20Turntable.pdf
Another possible problem is that the balance has become upset by being moved around. The correct balance is achieved b the positioning of a weight on the tone arm on the opposite end to the needle. This can usually be moved short distances to balance the tone arm so that the needle is held in the record groove, by the minimum necessary weight on the needle.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 26, 2014 | Audio Players & Recorders
Why is my brand new crosley turntable keepsake hunter skipping tracks?
The turntable may not be level. Also, the stylus could be damaged or defective. The stylus pressure may not have been set correctly in production or may have been affected by shipping.
May 05, 2014 | Crosley Keepsake USB Turntable
New Records sound is bad
Very strange! Apart from the fact that new albums could be faulty which seems unlikely, the only thing I can suggest is that they could be building up static. So I should look into ways of getting shut of that. If not you could adjust the weight on the arm, to see if that cures the problem.
Jun 26, 2013 | Crosley Audio Players & Recorders
Record continously skips after 4 or 5 seconds.
You need to apply more pressure to the stylus. This is done by adjusting a weight on the other end of the arm. See your manual for more details.
May 12, 2013 | Crosley Cr6001a Turntable
Feb 28, 2013 | Crosley Cr704 Audio Shelf System
I just bought a replacement needle for a Crosley CR66 4 in 1 record player and now my records sound distorted and far away
Jun 08, 2011 | Crosley CR248 Turntable
Every record we play skips, even the brand new ones
the needle/stylus needs to be replaced.
http://www.needledoctor.com
Apr 23, 2011 | Crosley Conductor CR73 Turntable
The speakers are so scratchy sounding, even without playing a record on it. Just received it as a gift, so bummed!
static noise coming from the needle. reomve the needle and the speakers should go silent. if this works replace the needle
Feb 20, 2010 | Crosley Traveler Turntable
Crosley CR49-TW Tweed Traveler Turntable CD Player Logo
24 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
