Question about Garmin Forerunner 910xt Fitness Watch Sports Waterproof Trainer Biking Swimming
My watch is stuck and can't move with "software loader" on the screen
Htc one x plus is stuck on the white htc quitely briliant screen
hold the power button down all the way until the screen goes black. then reboot it it should solve the promblem
Mar 16, 2013 | Cell Phones
This is an error in the ink loader.
It usually means the ink count sensors are stuck, after using 2 - 3 ink sticks. Your code shows that the yellow ink loader is stuck.
Features on the bottom of Xerox ink sticks actuate the ink loader sensor located at the end of each ink loader channel. The sensor detects the movement of the ink sticks to keep a record of ink usage.
Damaged, or Non-Genuine ink sticks may not actuate the sensors. Or using older Phaser 8400 model ink will also cause the 9,03x.4x errors.
  1. Check the ink sticks are genuine, and for the correct model.
  2. Manually verify that the ink stick is able to move in the ink loader chute. Check for broken or incorrect ink sticks.
There is a small chance that the ink count sensor is faulty, or the ink heater has blown.
This fault has to be cleared by running the Clear ISC Fault function, in the Service Diagnostics Menu.
Service Diagnostics > Function Menu > Clear ISC Fault
To enter the Service Diagnostics Menu, start with the power OFF.....
1. Turn the printer power On.
2. Wait for the Xerox logo to begin moving across the display.
3. Before the logo is centered on the display (stops moving), press and hold
the Back and Help buttons on the Control Panel.
4. Hold both buttons until the display reads Beginning Service Mode
Initialization. Release the buttons and the printer reboots into service
Have Fun!
May 11, 2010 | Xerox Phaser 8560DN Laser Printer
Stuck on boot loader,phone code sig error v3i r47a_g_08_d8_89r''
I Charged the battery up using another motorola phone,and then I did a software upgrade, and this has fixed the problem.The phone is working great now,all photos or videos were saved.
What i think caused this error is that the phone was doing an upgrade and then I got a message at the same time,I think these clashed some how and prevented the upgrade from completing,hense causing an error on the boot loader.
Hope I helped
Chris
Dec 26, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Magellan RoadMate
The map software has become corrupted..
Please rate my help++++Thanks for using FIXYA
Oct 09, 2009 | Magellan Roadmate 760 GPS Receiver
Whirlpool top loader washing machine - agitator does not turn
If it does not drain, I'd check the water pump first (for an obstruction - I found a sock in my pump and that fixed my problem) ... see this video - the top is getting to the WM drive shaft (transmission), but it shows you how to remove the pump first: http://www.youtube.com/watch?v=WLPGs2UMUJc&feature=related
If it does drain ... Is it just the TOP part of the agitator not working, or the whole thing (agitator is in 2 parts)? If just the TOP, you probably just need new "dogs" (agitator dogs). Check this out:
http://www.youtube.com/watch?v=V5wIN1J70-Y ... it shows you what to do.
If it is the whole agitator that is stuck, that video will show you how to remove it (remove a single bolt) and you can see if there is an obstruction keep the agitator from moving.
If there's no obstruction or the water pump isn't stuck, you might be looking at a new drive/transmission = expensive. Good luck
Jul 02, 2009 | Whirlpool Washing Machines
Kenmore 80's series top loader only works on wash and rinse cycle
This is a problem with the pump being stuck so the motor cant turn the whole thing. Turn the washer on its side, underneath you can acces the pump, which is connected to the motor by two long clips. remove the pump and take out the colg that caused it to get stuck.
Jul 01, 2009 | Washing Machines
Stuck on boot loader code corrupt
my motorola v3i stuck on this screen "BOOT LOADER 0A.30 R47A_G_08.D8.35R" and is also not charging the battery.battery is also dead.i have heard of flashing the phone but how it is done.plz help.plz reply on my mail id "volumelight@gmail.com"
thnx
Jun 28, 2008 | Cell Phones
Error: 09,035.43:27650
You have a Cyan ( blue) ink stick stuck or a broken ink stick in the ink loader.
Check the cyan slot carefully, one of the sticks has not moved properly, The machine is not seeing the ink loader moving indicating a stuck cyan stick, Here is the info.
Ink stick count faults (error code 09,03x.4x) are declared when the printer melts 2.5 ink sticks without tripping the color's ink out flag. The ink out flag is used to physically count ink sticks passing thru the ink loader.
Verify that the ink sticks are Xerox 8500/8550 ink sticks. Manually verify that the ink stick are correctly loaded and are able to advance in the ink loader chute. Check for broken ink sticks which can fool the ink out (ink stick counting) sensor.
The ink stick count fault can only be cleared by powering up the printer in internal diagnostics mode. Then scroll and to the Functional menu item Clear ICS Fault.
Dec 19, 2007 | Xerox Phaser 8500/DN Printer
Garmin Forerunner 910xt Fitness Watch Sports Waterproof Trainer Biking Swimming Logo
182 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
