Question about Crosman M4-177 Air Rifle
Not pumping, seems like the gas tank is punctured or broken
2009 ultra starting problem bike fires runs for approx 1 second stalls fuel pump runs fires again same thing sometimes 5 times sometimes 20 timessometimes 50 times and all at once it will fire and keep...
Hmmm ,it seem to be a fuel problem!
Even if you hear the fuel pump,it may come from the fuel line inside the gas tank feeding the injectors.
Check inside the gas tank to see a broken line or perforated!
Oct 13, 2013 | Harley Davidson Motorcycles
Tip
Keurigs with Side tank not pumping water
Those of you having a pumping problem with the Keurigs with side maounted tanks. It seem that the screen in the base when you liftout the tank you can see it, has a tendency to vapor lock due to the small mesh and pump height. I corrected this by putting 4 larger holes in the screen which is plastic with a pointed object just be careful not to go to far down or you will puncture the hose for the pump. After doing so I have not had a problem with my pump supplying water for the last 2 weeks to the heat tank, if your pump is not humming or working this will not work. This is a fix for those that remove the tank and set it back and the pump works when this is done you are forcing water through the screen breaking the vapor lock so try it, if it works fine
on Feb 10, 2011 | Keurig Platinum B70 Coffee Maker
I have an 05 Avalanche gas is running down from the top of the tank is this the fuel pump or something else?
You'll have to drop the tank to find out, it could be the filler hose or one of the hoses connected to the fuel sender assembly. Another possiblity is if you mounted something in the bed section with self tapping screws you may have punctured the tank.
Mar 19, 2011 | 2005 Chevrolet Avalanche
Can this code p0442 be the gas cap?
Common Problems That Trigger the P0442 Code
  • Defective or damaged fuel cap
  • Distorted or damaged Fuel Tank Filler Neck
  • Small tear or puncture in the Evaporative system hose(s) and/or Carbon Canister
  • Defective Fuel Tank Sending Unit gasket or seal
  • Small split in a seam of the Carbon Canister
  • Defective Evaporative Vent Valve and/or Evaporative Purge Valve
  • Defective or damaged Fuel Tank
  • Defective Fuel Tank Pressure Sensor
  • Defective Leak Detection Pump
  • Slightly loose and/or worn clamps or hardened O-rings anywhere in the EVAP system
Dec 30, 2010 | Toyota Avalon Cars & Trucks
I am not getting good fuel economy for the last 2 months. Performance and acceleration are good and the same but since I had a low impact front end collission at about 10 mph where I rear-ended a big...
only the mechanic can answer that, he's the one looking at the car. If he diagnosed a bad valve, get it fixed., then see if it made a difference.
Nov 16, 2010 | 2001 Chrysler PT Cruiser
I have a gas leak on my 2005 dodge caravan. it's coming from the top of the gas tank at the back, passengers side . i think thats where the fuel pump is ? could it just be a gasket leak?
check the gasket. and return fuel line. or the filter maybe clogged. or u may have a puncture in the tank itselfor something is causing pressure to build up
Sep 12, 2010 | Dodge Caravan Cars & Trucks
My sons 1998 GMC Jimmy was leaking gas all over the garage floor. Just had the fuel pump replaced.
Either the fuel tank was punctured or a fuel line is not properly connected. They are quick connect fittings, an O-ring may have been damaged.
Sep 19, 2009 | 1998 GMC Jimmy
Error code p0442
EVAP Emission Control System - Small Leak Detected (1.0 mm). This code can be set when 1. fuel filler cap is not completely tight, 2. when various hoses get punctured or the canister close valve does not seal completely, 3. there is an actual leak in the charcoal canister, fuel tank, or other EVAP system component, 4. if any one of these components are malfunction (a), fuel tank pressure sensor, (b) purge control solenoid valve, (c) canister close valve, or (d) fuel cap. An engine vacuum leak would not set this code.
Solution: Take the vehicle to a Hyundai Dealership for proper diagnosis/repair.
May 23, 2009 | 2001 Hyundai Santa Fe
Fuel guage reads half way and the truck runs out of gas
The float that helps detect fuel level is most likely broken. You or a mechanic will have to remove the fuel pump from the gas tank and check and possibly replace the float. Merry Christmas.
Dec 23, 2008 | 2001 Chevrolet S-10
Crosman M4-177 Air Rifle Logo
Top Crosman Optics Experts
Martin Clarke
Martin Clarke
raysaw
Are you a Crosman Optic Expert? Answer questions, earn points and help others
