Question about Watches
Having difficulty setting time on Roots athletics Watch RY 2208 model. Following instructions, but can't figure out what I am doing wrong.
2 Suggested Answers
le_t_mai
SOURCE: How do you set the time on the Roots Womens's Mai
Press and hold "MODE". Press MODE 2 times (after the first time, the alarm time flashes, after the 2nd time, the second flashes). Press ADJ to change seconds. Press ST/STP to switch from seconds to minute. Press ADJ to change minutes. Then press ADJ to change hours. Press MODE when done.
Posted on Nov 20, 2012
How To Set Time
The first very important thing to figure out is what caliber movement are you trying to set, a lot of people get frustrated when attempting to set their watch because they were using the wrong set of setting instructions.
Citizen released 2 versions of the Blue Angels Skyhawk, the only difference is one is titanium and the other stainless steel, both have very similar model numbers: JY0040-59L and JY0050-55L. The same caliber movement was used in both models, which is the caliber U60 atomic timekeeping movement.
NOTE: The watch must be able to detect radio waves during setting.
Citizen provides excellent and easy to follow setting instructions on their website, simply go to http://citizenwatch.com confirm your location, input your watch model in the search box located in the header section of the site, in this case we are searching for Skyhawk. Select your timepiece from the search results and click on the setting instructions link located below the image of the watch. There is a .pdf version and a video clip I would recommend to familiarize yourself with both. We're here to help, if you encounter any difficulty along the way give us a call at (212) 840-0441, or visit our website http://www.watchrepairny.com/our-services/
Nov 26, 2013 | Citizen Blue Angels Skyhawk Watch
How to change time on roots watch ry2203
Apr 06, 2013 | ROOTS Athletics Wrist WATCH Water...
How do I set the date on my Roots MAI TAI RY2142 Watch for Women?
Start by holding in the mode button (bottom left) until the first number blinks, then let go. You are actually in the alarm mode right now, now press and release the mode button and enter the time setting mode, the seconds will be flashing. Now press and release the start/stop button (top right) and the minutes will flash, again for hours, again for the month, and again for the date. When the parameter you want to adjust is flashing just press the adjust button (top left) to change the numbers. When your finished simply press the mode button to exit the setting menu. Worked for me, hope it does for you too. Most of the other setting changes are tricky as well, just ask for help again if you want to change the alarm or 12 or 24 hour clock etc....
Jan 03, 2013 | ROOTS MAI TAI Ry2142BLK Watch
I cannot set the time on Armitron All Sport 45/6999 watch or Pro sport 49/1018. Came w/ no instructions and can't find this model # on Armitron website
I found instructions here. http://www.livestrong.com/article/306545-armitron-black-red-womens-sport-watch-instructions/
Although, I can't figure out how to turn off the alarm.
Dec 29, 2011 | Watches
Athletic works watch that is stuck on military time
With my old watch (from Walmart), all i had to do was go into the time settings and cycle through the hours until it went past the military time's midnight and it would start going through "normal" AM/PM times.
I hope this is enough information.
Feb 15, 2010 | Watches
Feb 05, 2010 | Watches
I have a Athletic works watch and I can't get it off military time.
When in the set time mode press the A button this will toggle between standard and military time. I had the same problem, dscovered it by trial and error, not in instructions.
Mar 27, 2009 | Bulova Watch
Athletic Works Watch
With time displayed:
Press lower right, then upper left.
Mar 12, 2009 | Oakley GMT OAK0531 Wrist Watch
CAN'T SET TIME
I have an AW 150 watch. I looked everywhere for a solution to setting it. I found nothing. It appears that all types of this watch are hard to set. I happened upon the correct procedure for at least setting the watch.
My watch has 4 set buttons that you can push. 2 on each side. Hold the upper right hand button until something starts flashing on the watch. On mine it was the seconds. Then release the button. Now each time you push that button for a very short moment, the flashing part of the watch will progress through each area (minutes, hours, date, etc). When you get to the area you want to set/adjust, use the bottom right hand button to move up/forwards and the bottom left hand button to move down/backwards. When you have fixed one function push the upper right hand button to move to the next function you want to change and repeat the procedure. When you are done, hold the upper right hand button in until the watch quits flashing anywhere and then release the button. Your watch is no longer in the adjust mode. Hope this works for you. It drove me nuts until I figured it out.
Feb 28, 2009 | Oakley GMT OAK0531 Wrist Watch
I just bought an Athletic Works watch at WalMart that is identical to the Aquatech watch I bought there some years ago. My band got hard and cracked so I needed to buy a new one as the band is not available. For $9 the entire watch is probably cheaper than a band. I used the instructions from my Aquatech to set the stuff on the AW. I found the instructions on the internet. Here is one site that has them.
http://www.ehow.com/how_4587869_set-aquatech-watch.html
Give it a try.
Clem S
Sep 23, 2008 | Watches
Watches Logo
95 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
