Question about Mercedes Ml Ml320 Ml350 Ml550 Ml63 Chrome Exterior Accessory Abs Molding Trim Kit Set 2006 2007 2008 2009 2010 2011
Hi my ml350 1999is now ok after fitting the radio it started like a dream the only problem i have now is that the triangle light comes on when i am driving then the car stops pulling and losses powr then the light goes off then the car picks power and moves
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 71 Answers
When the radio was installed.... the wiring must have been affected... even a single wire not connected properly does give u problems like that.... So do what you have to do... to fix the wiring problem
Posted on Jan 13, 2014
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Changing the battery, which side does the positive face - up or down?
The battery holder may have been designed so that the battery only fits one way.
Oct 10, 2014 | Sony Dream Machine Icf-c350 Am/fm Dual...
Sony dream machine manual
Hi Fred,
You can download the manual in pdf here.
Hope this helps.Thanks!
Please rate this answer.
Nov 29, 2011 | Sony Dream Machine FMAM radio with...
Sony dream machine
Hello
Send your Email Address to me by FixYa comment box. I've the user manual to your clock radio. I can't send it to you by this window as it does not allow me to upload PDF files by it. If you send your Email ID to me, I'll send a copy of it to you by return mail. OK.
Nov 17, 2011 | Sony Icfc8wm Dream Machine Alarm Clock...
Hot tub no heater or pump heater light flashing
Thank you for posting your question here on Fixya.com.
Start with the pump. If it is bound up and not starting nothing else will work. Close off your valves and disconnect the pump unions. Once free, reach in with the pump unplugged and try to turn the impeller by hand. Will it turn? If not, you'll need to free it or get the pump repaired. Once the pump is working and water circulating your heater should start working.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Mar 10, 2010 | Qca Spas Dream Series Dream Master Hot Tub...
Mini cooper Warning lights for abs, low tire,traction comes on
Ok, check the brake fluid level for a start. This could mean a few things. Your brake pads might be worn down, which would bring a yellow warning light on(triangle), at the same time with the pads being low it will have displaced the fluid, making the level low, this would be a red light on. Now because of this the body control module has detected these faults, will have turned the abs off, hence the abs light.
If brake fluid is low, this could confirm my theory.
If its low, top up with dot 5 brake fluid and take to garage to have new pads fitted.
TL
Jan 24, 2009 | 2007 Mini Cooper S Convertible
Mercedes Ml Ml320 Ml350 Ml550 Ml63 Chrome Exterior Accessory Abs Molding Trim Kit Set 2006 2007 2008 2009 2010 2011 Logo
145 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
Timllfixit
xxxxxx xxx
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
